Posted 05 April 2013 - 05:33 AM
Posted 05 April 2013 - 05:40 AM
Posted 10 April 2013 - 04:05 AM
Posted 29 June 2013 - 10:11 PM
Perhaps explain the external selected at 4:24 in this video then. I'm having the same issue. I cannot select the external for a backup but this how to clearly shows it selected on my exact same razr maxx. Please have another look.
#5 Guest_BDH_*
Posted 29 June 2013 - 10:15 PM
What version of safestrap are you running?
What slot are you trying to backup?
What have you done so far to try to fix this issue?
Posted 17 July 2013 - 05:42 PM
that's cause RAZRs have a different partition table than bionic, i had the same problem with lense recovery but the internal wouldn't work instead.
in recovery use adb to try mount
adb shell busybox mount /dev/block/emstorage /sdcard
Also tagged with one or more of these keywords: sdcard
