Droid RAZR M Boot Animation Won't Display After Being Resized
Boot Animation RAZR HD Maxx HD
22 replies to this topic
#1 GillRigged
GillRigged
  • 121 posts
  • Twitter:@GillRigged
  • LocationNW WI
  • Current Device(s):Droid RAZR Maxx HD, Droid RAZR M
Posted 04 April 2013 - 04:47 PM
Okay, so I like my girlfriend's boot animation on her Droid RAZR M which is full screen on her phone (540 * 960). This plays fine on my Droid RAZR Maxx HD however, it doesn't display full screen on my phone (720 * 1280). I re-sized each fricken picture, optimized them with RIOT and changed the desc.txt to no avail. In fact, I have to restore from backup in Safestrap to get my boot animation to work again. WTF???
I'm including the RAZR M stock bootanimation.zip, custom - re-sized zip and the audio file for the animation. Can someone help me out making this work full screen on my RAZR Maxx HD, please?
  6.3MB   29 downloads
  5.74MB   10 downloads
  115KB   53 downloads
  • mrf582 likes this
#2 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 13 April 2013 - 09:09 AM
Got this figured out (not that anybody seems to care). It was just a matter of how I was zipping the files up. I have 7Zip, jZip and WinRAR-all of which have the ability to zip with zero compression (or "store"). Here's the properly zipped boot animation 720 x 1280 version (audio that goes with it up above).
  5.93MB   84 downloads
  • BionicMan69, KaChow and mrf582 like this
#3 mrf582
mrf582
  • 44 posts
Posted 13 April 2013 - 06:32 PM
How do we install this?
I guess we just replace the existing file in the 'system/media' folder and set permissions accordingly?
#4 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 13 April 2013 - 06:49 PM
Pretty much. Probably would wanna change the original to .bak extension after the zip so that you have it for a backup. I use ROM Toolbox Pro for most of my customizing. And with permissions just make a note of what the settings are of the stock animation zip. Also, the audio just gets placed in the same folder and no need to do anything with the stock boot audio file.
Sent from my rooted Droid RAZR Maxx HD using Xparent Cyan Tapatalk 2
#5 KALMANI
KALMANI
  • 16 posts
  • LocationSan Diego,CA
  • Current Device(s):Motorola Droid Razr Maxx HD
Posted 14 April 2013 - 03:04 PM
Can you please help me my stock bootanimation sound will not work and I've tried everything from permissions, compressions. volume up and nada.  My original link for this problem is here:
Please Help? :unsure:
#6 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 14 April 2013 - 08:22 PM
Is your animation audio file in /system/media like the bootanimation.zip? And NOT the droidsm folder. Should look like this:
  48.57KB   27 downloads
Note the Permission settings also:
  44.62KB   28 downloads
#7 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 14 April 2013 - 08:46 PM
Is your media volume up? Settings > Sound > Volumes (Top one):
  22.24KB   22 downloads
#8 KALMANI
KALMANI
  • 16 posts
Posted 14 April 2013 - 10:39 PM
Yes its there and the permissions are correct and the audio doesn't play  How about ownership and what should they be?
The volume is all the up and still nothing!
Btw, thank you for replying and helping me out.  I appreciate it. :)
#9 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 15 April 2013 - 10:03 AM
Hmm. Does the boot animation work and just not the audio?  What audio are you trying to have play (The stock for Maxx HD or the M)? The stock audio for Maxx HD is droidpu.ogg You may also want to view the desc.txt file by viewing the zip file with ES File Viewer and then viewing the txt with ES Note Editor. Make sure its like this for the Maxx HD stock boot annimation:
  44.59KB   17 downloads
#10 KALMANI
KALMANI
  • 16 posts
Posted 15 April 2013 - 12:36 PM
Boot animations works great but not the audio.  The audio that I am trying to the play is the stock audio for Maxx HD.  The desc.txt does not open with ES Note Editor, so I opened it with root explorer and here's the screenshot of it below:
  117.9KB   15 downloads
Btw, I have not edited nothing in the desc.txt file.   That is the orginal.
#11 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 15 April 2013 - 12:42 PM
And the audio is droidpu.ogg?
#12 KALMANI
KALMANI
  • 16 posts
Posted 15 April 2013 - 12:55 PM
Yes
#13 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 15 April 2013 - 03:21 PM
Yes
Well, try this. Raname both of those files with .bak extension then take these files and place them there. if that doesn't work then try Fix permissions in recovery. If that doesn't work then I don't know what to tell ya.
  3.74MB   14 downloads
#14 KALMANI
KALMANI
  • 16 posts
Posted 15 April 2013 - 05:32 PM
How do you fix permissions in recovery?
#15 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 15 April 2013 - 05:49 PM
Stock Maxx HD Boot Animation.zip
Don't do anything with ownership and for fixing permissions goes, you go into your recovery and its one of the options. Might be in Advanced or something like that. What recovery are you using? Safestrap, TWRP, CWM or stock?
#16 KALMANI
KALMANI
  • 16 posts
Posted 15 April 2013 - 06:31 PM
Your bootanimation.zip didnt work for some reason so I used another stock one and the animation worked but the sound didnt.  I figured how to fix permissions on twrp but still nothing.  Yes sound was up and the file droidpu.ogg did test out and play but just doesnt play on boot.  Anywayz thanx for the try.
#17 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 15 April 2013 - 07:00 PM
You could always wipe your phone and then restore your apps with Titanium Backup Pro, ROM Toolbox Pro or some other backup app. I know that once I installed a bad file in system for boot animation I had had to do just that to get anything to work again.
#18 megahertz1970
megahertz1970
  • 228 posts
  • Google+:markw4itg@gmail.com
  • LocationPiscataway, NJ
Posted 18 April 2013 - 10:44 PM
The mistake I made was I didn't extract the audio file first. Once I figured that out it worked like a charm. Thanks for this.
#19 GillRigged
GillRigged
  • 121 posts
  • LocationNW WI
Posted 19 April 2013 - 07:50 PM
It's waaay better than the Maxx HD stock animation, that's for sure. And then this is my boot image I put together:
  84.63KB   16 downloads
And sometimes I switch over to this one:
  209.51KB   22 downloads
  • GillRigged likes this
#20 y2kbadbug
y2kbadbug
  • 35 posts
  • LocationLas Vegas, Nevada
Posted 25 April 2013 - 11:52 PM
I have been trying to fix the sound with stock animation sound, can you elaborate on what you meant with that please.
Also tagged with one or more of these keywords: Boot Animation, RAZR HD, Maxx HD
