How To Keep The Button Lights On
2 replies to this topic
#1 probbiethe1
probbiethe1
    Writer/MOD
  • 14 posts
Posted 23 March 2012 - 11:21 PM
I was excited to get the HTC rezound but that excitement changed to disappointment when i couldnt see what buttons to press. See the Rezound requires the ambient light to be at a certain level before it will turns on the lights for the buttons ( you can test this by holding your finger over the top of the Verizon swoosh V the lights should turn on) This made me very unhappy so i went searching for a way to fix it. I finally came across an app called
, it isnt the best solution but it does the trick and made me a very happy man. All you have to do is download the app and check the box for Lock on bklight, I also checked the box for only when screen on.
  • koreanschoolkid likes this
#2 VantenKiest
VantenKiest
    Guru of Insanity & Tech support
  • 668 posts
  • LocationPittsburgh PA baby
Posted 24 March 2012 - 07:07 AM
hey thats very interesting.. i have this issue now and then with the razr with the lighting in here
#3 Rycix
Rycix
    Bouncing Ball Of Energy / Android Rescue Squad
  • 107 posts
  • LocationNew England, USA
  • Current Device(s):XT912
Posted 25 March 2012 - 05:13 AM
That's funny...I always want to turn it off. Try adj brightness, it has keep lights on always option. Root dim may have it as well, not sure. (I believe adj worked for my razrs soft keys, but support dropped for it a while ago, and it might only work on motorola devices only.)
  • andlaw likes this
Droid Razr XT912, cooling down with ICS on 6.16.211
