Official OTA Overclock Modules - 98.72.16
Overclock OTA Modules
39 replies to this topic
#1 East2West
East2West
  • 20 posts
Posted 30 March 2013 - 01:35 PM
Not sure if this has been done, but I've recompiled the overclock modules from whirlyeyes over at
Testing working using the deodexed stock rom.
Init.d Install
Doesn't look like these work anymore. Follow the guide
to enable init.d or use scriptmanager to load the modules. [Only follow step 2]
**UPDATE***
Added cm10.1 kexec modules. You can use the same Init.d install.
I also added a link to whirleyeyes Tweakerz.apk that acts as a front end GUI For overclocking. Changes will not persist on reboot but it can help when you are trying to dial in the best settings.
Example Script
  • chiahead52, disturbed58, lifeisgood and 2 others like this
#2 nailbomb3
nailbomb3
  • 195 posts
Posted 01 April 2013 - 08:06 PM
Much thanks!
#3 Einsteindks
Einsteindks
  • 340 posts
Posted 01 April 2013 - 08:08 PM
Great fodder for an overclock/undervolt tutorial, yes? Hint hint
sent via RazrMaxx over Tapatalk, y'all!
#4 nailbomb3
nailbomb3
  • 195 posts
Posted 01 April 2013 - 08:39 PM
Will this work for hash codes current kexec stuff?
#5 iaminflames
iaminflames
  • 62 posts
  • LocationFindlay OH
  • Current Device(s):DROIDX, RAZR Maxx
Posted 02 April 2013 - 05:53 AM
Sent from my Motorola RAZR MAXX using Tapatalk 2
#6 iaminflames
iaminflames
  • 62 posts
Posted 02 April 2013 - 02:53 PM
I tried it on hashcodes cm10.1 builds and it changes nothing.
#7 iamhugger
iamhugger
  • 296 posts
  • Locationsouth dakota
  • Current Device(s):droid razr
Posted 02 April 2013 - 04:02 PM
modules added but no script to oc
#8 East2West
East2West
  • 20 posts
Posted 02 April 2013 - 04:08 PM
Updated post with new modules for cm10.1
  • iaminflames likes this
#9 East2West
East2West
  • 20 posts
Posted 02 April 2013 - 04:09 PM
Left that out on purpose. You can use either script manager to run on boot or add a new file to the init.d folder
#10 iaminflames
iaminflames
  • 62 posts
Posted 02 April 2013 - 04:19 PM
Tried out the kexec modules and they worked like a charm! Thanks!
  • East2West likes this
#11 nailbomb3
nailbomb3
  • 195 posts
Posted 02 April 2013 - 05:40 PM
Hot damn! Thanks!
I seem to remember doing it on my. DROID 2 but how do you enable init on a stock rooted Ron?
#12 iamhugger
iamhugger
  • 296 posts
Posted 02 April 2013 - 05:54 PM
u dirty dog, cool, thanks for ur work
#13 iaminflames
iaminflames
  • 62 posts
Posted 03 April 2013 - 06:48 AM
First day using the modules on cm10.1 with the pegasusq gov and sio scheduler I get no deep sleep.
#14 East2West
East2West
  • 20 posts
Posted 03 April 2013 - 07:03 AM
Your best bet would be to contact whirlyeyes over at xda. I'm not sure how the modules are coded. I only recompiled :)
#15 dtomlin
dtomlin
    Droid Elite
  • 1,557 posts
Posted 03 April 2013 - 07:17 AM
Mines going right into deep sleep with that combo
#16 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 03 April 2013 - 07:57 AM
Downloaded and will try it out at some point today ;) thanks!
Edit: I should be getting ready for work, but couldn't wait LOL. The governors loaded up perfectly :)
Sent from my DROID RAZR using Xparent Skyblue Tapatalk 2
#17 East2West
East2West
  • 20 posts
Posted 03 April 2013 - 09:52 AM
Hot damn! Thanks!
Just install the init.d zip and copy your start up scripts to /system/etc/init.d/ with executable permissions.
#18 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 03 April 2013 - 10:08 AM
What are you using to maintain the freq? I have init.d scripts and have found I need to run it in smanager with SU and then I have to use set CPU to set it and create a profile to enable it during screen on times. This is because the frequencies will revert to minimums when the screen has been off for a few minutes.
What permissions are you using for the script? And what app are you using to set the frequencies? Just wanting to know if there is an easier way :)
Donate? Click on signature :)
#19 East2West
East2West
  • 20 posts
Posted 03 April 2013 - 10:44 AM
Hmm. looks like the init.d file i posted wasn't working. Updated original post with a link to a different method of enabling it as well as an example script to use. I haven't come across the frequency problem though. I keep my frequencies the same but change the voltages, but I'll keep an eye out to see if they revert. Permissions can be set with
and I use the tweakerz app to change voltages and frequencies. Try and load your modules outside of it though using init.d or script manager as it crashed for me when inserting cpu_control.ko
#20 GodfatherIP
GodfatherIP
  • 27 posts
Posted 03 April 2013 - 12:29 PM
So to use this we simply flash the update.zip in safestrap and then use script manager (or a script placed in init.d for settings on boot) to load the kernel modules and set the frequencies/voltages using a script similar to the one you posted above, right?
Also tagged with one or more of these keywords: Overclock, OTA, Modules
