![Photo](http://www.gravatar.com/avatar/5d0c01a5c29a493e8b3bdc42b788b759?s=100&d=http%3A%2F%2Fwww.droidrzr.com%2Fpublic%2Fstyle_images%2Fdark_matter%2Fprofile%2Fdefault_large.png)
Motorola Droid Razr [European Version] Sbf Leak (Not For Verizon)
#21
Posted 01 December 2011 - 06:38 PM
#22
Posted 01 December 2011 - 06:39 PM
#23
Posted 31 December 2011 - 02:34 AM
I'm softbricked with a Optus AU RAZR
![:(](http://www.droidrzr.com/public/style_emoticons/default/sad.png)
#24
Posted 31 December 2011 - 02:00 PM
Just extract it. Open RSD Lite. Browse to the folder. And there should only be one file in there you can chose to flash.Does anyone have steps for the use of this SBF with RSD lite?
#25
Posted 31 December 2011 - 07:54 PM
Link wouldnt load before but all good now
#26
Posted 31 December 2011 - 11:37 PM
cant get into recovery either
if anyone could give me a hand with this that would be great !
#27
Posted 01 January 2012 - 06:27 AM
You can try flashing .flashed this with rsd lite and now im bootlooped
#28
Posted 01 January 2012 - 05:53 PM
I think its all over
![:wacko:](http://www.droidrzr.com/public/style_emoticons/default/wacko.png)
#29
Posted 01 January 2012 - 06:47 PM
Any other ways to get into recovery or flash fastboot?
#30
Posted 16 February 2012 - 07:04 AM
#31
Posted 16 February 2012 - 07:05 AM
i am from India . i am using Indian CDMA nework on verizon razr. how do i use GSM on this?
could someone help me.i am exprt in CDMA workshp application , if it is possible with this software?
#32
Posted 21 February 2012 - 06:43 AM
currently i am stuck on the ap fast boot screen, no matter what i do i come back to this. I cant even perform fast boot as its says battery low....what do i do...? can someone please help..
this is what i get on my screen
AP FASTBOOT FLASH MODE (S) (FLASH FAILURE)
OA.6C
TO RETURN TO NORMAL MODE - FIRST PRESS POWER KEY TO POWER DOWN
DEVICE IS LOCKED. STATUS CODE: 0
BATTERY LOW
CANNOT PROGRAM
CONNECT USB
DATA CABLE
i cant even charge my phone..it would be great is some one can get me out of this mess...I am such a NEWB
#33
Posted 21 February 2012 - 05:59 PM
You will have to find the right fast boot files for your version, download and it extract it and then point rsd lite to the XML file from it. Also make sure you have the motodev drivers loaded so that rsd recognizes your device.
Sent from my.....whichever phone I am using at the moment with Tapatalk
#34
Posted 22 February 2012 - 12:56 AM
B_ren8
Thanks bro, but i tried to charge it thru wall adaptor and PC for over 12 hours,,, same screen still
Any ideas?
Rizzla
#35
Posted 22 February 2012 - 02:43 AM
B_ren8
Any ideas?
Rizzla
you need a factory cable, search for razr factory cable on google you might find how to make your own.
#37
Posted 22 February 2012 - 11:40 PM
I have given the phone to moto tech i know, may be he has a factory cable, if not i will have to order it myself and sort it out..
Peace out for now
#38
Posted 03 March 2012 - 04:33 AM
