Help Needed with Bricked Droid Razr Maxx
Posted 28 March 2013 - 06:04 AM
So, with my phone locked I tried the 1.8 utility and it did not work. Tried it twice.
Of course, I have no idea what to do to fix this but really would like to unlock and update my phone. Can anyone help me? Thank you
Posted 28 March 2013 - 06:22 AM
Posted 28 March 2013 - 06:41 AM
Posted 28 March 2013 - 06:49 AM
just tried it..nothing...when it says it will wipe my phone, nothing happens. Then phone stays on same screen and still says locked:(
Your phone will always say locked as we have locked bootloaders....sounds like your not running the utility correctly. Option 1 and 2 need to be done in Fastboot mode. Are you running as admin assuming you are on windows, using a Moto cable, with the correct drivers installed? did you try enabling USB Debugging?
Should work pretty easy if your using the utility in the link.
Posted 28 March 2013 - 07:29 AM
Posted 28 March 2013 - 08:01 AM
Ok, re- did download, un-zip, this time i had a flash on my phone and the utility says waiting for device, but now its stuck?
Not sure, but the utility is simple and straightforward....you can try and unplug and replug phone, or try the utility again.
Posted 28 March 2013 - 08:26 AM
Posted 28 March 2013 - 08:32 AM
Update...Since I had some movement that time, I went back and tried the 1.82 utility and it ran fine. Now I am trying the update once again...hopefully, it will go through:) Thanks so much
Youre welcome, hopefully it all works "as advertised"
Posted 28 March 2013 - 03:48 PM
Any Luck...
Also tagged with one or more of these keywords: 4.0.4, 6.16.211.xt912, ics
