Will I ever be able to downgrade from Jellybean to ICS?
xt912 raxr maxx downgrade ics
9 replies to this topic
#1 timbuktoo
timbuktoo
  • LocationMacon, GA
  • Current Device(s):XT-912
Posted 23 March 2013 - 10:34 PM
Like a lot of unfortunate folks, I made the wrong errant click and have been upgraded to Jellybean. (Razr Maxx XT-912) Now my 4G signal is spotty at best. As that my phone is my only available internet source, out in the sticks, I am indeed in a pickle. So, my question is this: Is there or will there ever be a way to go back to Ice Cream Sandwich? I hope that there is or will be...
If anyone has any good ideas or options, no matter how crazy, I'd be thankful to hear them.
Tom in Macon, GA
#2 Guest_BDH_*
Guest_BDH_*
Posted 24 March 2013 - 01:04 AM
Tom in Macon, GA
Not possible, not now, not ever. Sorry to be blunt but unfortunately that's the only answer I can give you. It just simply won't be possible.
  • IAmMarino likes this
#3 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 24 March 2013 - 02:39 AM
Tom in Macon, GA
BigDaddyHicks in correct No Turning Back...However, Most of the Dev's are also moving away from ICS so its Best to be on Jelly Bean with more Opportunites to Modify your device...
I too was on ICS and realized chosing the JB Update their was no going back...No regrets...
Have you checked your settings for Data Usage...Goto Settings...Chose More...Mobile Networks...Then Network Mode...You have 3 option settings...
Mine is currently set on Global...
Most on the forum may be set on LTE/CDMA...I cover a lots of Rual States so signaling/Radio output is important for Device connections...
Playing around with those settings for a while no promises but it might help your Radio Signals or Output...Who knows maybe their will be an Update...
Its Bubba
#4 Brooks99
Brooks99
  • LocationMidlothioan, VA
  • Current Device(s):Motorola Razor Maxx
Posted 24 March 2013 - 11:36 AM
I lost my free Wifi spot when I got the JB update. I WANT ICS back! :unsure:
#5 cmh714
Posted 24 March 2013 - 12:54 PM
Id recommend using Matts new JB utility with the fastboot files and start over....at least you can start with a clean JB flash....
  • The Persuader likes this
#6 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 24 March 2013 - 01:30 PM
You'll be buying a New Car :o before that happens going back to ICS... :D :P
As far as going back to ICS....theirs an Old Saying out there...
"That Dog Don't Hunt"....another words its NOT Happening...Good New is...JB is the Dev's choice for Modifying ROMs my friend
Its Bubba
#7 IAmMarino
IAmMarino
  • 25 posts
  • Twitter:DearDanno
  • Current Device(s):Galaxy Nexus, Razr Maxx, Nexus 7
Posted 03 April 2013 - 07:07 PM
ICS is gone forever.
-Sent from Marino's Maxx-
-Galaxy Nexus, Nexus 7, and Droid Razr Maxx-
#8 aktrazer
aktrazer
    SMod/News Team Leader
  • 537 posts
  • LocationGreensboro, NC
  • Current Device(s):Smasung Galaxy Note 2, ASUS TF700T
Posted 04 April 2013 - 04:42 AM
You didn't lose it, you just have to do it a different way.
If you have UNLIMITED data, you'll need to use the SQLite hack, which will allow you to use the normal "Mobile Hotspot" from Verizon with no issues.
If you have a TIERED data plan, the hotspot is free to you anyways, so there's no need to hack it.
#9 coletrane09
coletrane09
  • 236 posts
  • Twitter:coletrane09
  • LocationHart, MI
Posted 04 April 2013 - 05:46 AM
Tom in Macon, GA
find a used one on ebay and if your lucky it has been collecting dust for a few months
  • androidmaster likes this
#10 androidmaster
androidmaster
  • 9 posts
  • Locationpakistan,karachi
  • Current Device(s):DroidRazr HD XT926 KK
Posted 18 June 2017 - 01:10 AM
hello guyz please can you help meee
im using droid razr xt912 running jb official stock
i have otg cable
but its not working on my droid razr
i download OTG SUPPORTED ? APK
so i scan so result = SUPPORTED
i cant understand what i do showing supported and not working any thing
i try another usb not work i try mouse . keybourd , usb , and all otg supported things
not working i check my otg on my brother tablet so all things working howwwww!!!!!!!!!!!!!!!!!!!!
                                               :(  why only not working on me ??? :(
please help meee
Also tagged with one or more of these keywords: xt912, raxr maxx downgrade, ics
