Restore 4.1.2 Firmware / Unbrick Verizon DROID RAZR HD
85 replies to this topic
#61 livinginkaos
Posted 17 November 2013 - 04:31 AM
No. The only thing you need in order to use rsd is to be booted into fastboot. Just keep in mind that you cannot flash firmware older than what was/is on there now.
Sent from my G2
  • aejacobs likes this
#62 integrate
integrate
  • 11 posts
Posted 17 November 2013 - 10:43 AM
Sent from my G2
Oh, that's a bummer.   However, I can install fastboot if I'm not rooted?
I'm on 9.30..you're saying I can't flash anything older than that?
THanks.
#63 jcyoun33
jcyoun33
  • 8 posts
Posted 17 November 2013 - 11:01 AM
That's right Integrate. I fastbooted my device back to 9.20 and then just updated 9.30.
I've decided to leave the device alone; not even gonna root it or meddle with it.
Still a great device and battery life. It's unfortunate Motorola has made it difficult to change things up!
#64 jcyoun33
jcyoun33
  • 8 posts
Posted 17 November 2013 - 11:02 AM
Btw, I was able to get my phone working and it's great! Thanks for all the help guys. :)
#65 integrate
integrate
  • 11 posts
Posted 17 November 2013 - 12:29 PM
Were you already on 9.20 when you fastbooted?
I updated to 9.30, but I want to fastboot back to a system version that is rootable.
Chrome is so terrible that I want to install the normal android browser.
#66 livinginkaos
Posted 17 November 2013 - 12:43 PM
That is not possible. Before ICS they had lacking security that allowed that but not any more. We were able to trick it with motochopper 1.3 bit they patched that. Speaking of which, do NOT attempt 1.3 as that will give you the improper boot.IMG.
Sent From My DEV X
#67 integrate
integrate
  • 11 posts
Posted 17 November 2013 - 12:51 PM
Sent From My DEV X
Thanks for the clarification!  I came from the GS3, so all that was possible.  Shucks!  Just have to wait for bootloader/root for 9.30 I guess!
#68 jcyoun33
jcyoun33
  • 8 posts
Posted 17 November 2013 - 07:03 PM
Uhhh, well judging on the development as far as unlocking the bootloader now, there won't be any for 9.30.
There wasn't anything available for 9.20 either...
#69 flygizzle
flygizzle
  • LocationCali
  • Current Device(s):Note 3
Posted 06 January 2014 - 11:27 AM
No valid PIV block in SP for System
piv validation failed (system)
Fastboot Reason : Boot Failure
usb connected
This is my error message, does anyone have any idea why I could have possibly get this code after it had loaded 16/27 files?
#70 cmh714
Posted 06 January 2014 - 11:48 AM
Sounds like you have the incorrect files is my guess. You didnt provide any information for us really to help.
Start with your device (we will assume an HD since thats where you posted), and System or Build Number. The files in the OP are for MR2 and are dated.....
  • johnthehillbilly likes this
#71 flygizzle
flygizzle
  • LocationCali
Posted 06 January 2014 - 12:56 PM
AP Fastboot Flash Mode (S)
10.9B(*) (sha-1e9f557, 2013-09-26 12:31:42)
eMMC Info: 32GB
Device is LOCKED, Status Code : 0
Transfer Mode:
USB Connected
usb connected
That's what is on my screen.
#72 johnthehillbilly
Posted 06 January 2014 - 01:01 PM
Like cmh said.... We need the system version you were on and not just 4.1.2. Jelly Bean..... It was a number that looked similar to 9.20.1 Also..... What exactly did you attempt to flash.....
#73 cmh714
Posted 06 January 2014 - 01:12 PM
Hmm, thinking about it, he may not be able to get that far to get the info.....Ok, we can see that your Locked, now the question is did you have Root previously? Depending on what we flash depends on what you had last and you may lose root forever. Of course, right now you probably dont have a working device so losing root to get the device back may be your only option.
#74 timdog68
timdog68
  • 34 posts
Posted 14 January 2014 - 06:52 AM
Ok I boogered my phone up big time
I tried to flash latest file and im stuck in fast boot.
Device is locked status:0
downgraded security version
update gpt_main version failed
failed to hab check for gpt_backup: 0x35
failed to load gpt
cid read failure
invalid cid status 0x69
no sp partition found
fastboot reason: invalid gpt
usb connected.
Just need to get my phone working could care less about unlock or root......help!!!!!!!!!
#75 cmh714
Posted 14 January 2014 - 08:50 AM
your using an older file than whats on your phone, find the right files.....
  • timdog68 and johnthehillbilly like this
#76 timdog68
timdog68
  • 34 posts
Posted 14 January 2014 - 09:52 AM
Bad gpt partition has been fixed thanks
#77 timdog68
timdog68
  • 34 posts
Posted 14 January 2014 - 10:33 AM
problem solved
#78 timdog68
timdog68
  • 34 posts
Posted 14 January 2014 - 11:32 AM
Had a bad partition and used the gpt fix of matts seems to have worked
thanks!
  • cmh714 likes this
#79 cmh714
well that is the latest file
#80 aks2590
aks2590
  • Locationnew delhi india
  • Current Device(s):moto razar xt926 maxx
Posted 14 January 2015 - 02:46 AM
Dear developer
I am from india New Delhi,
i have xt926 Maxx with bootloader locked and i bricked my mobile.
now please help me even i am ready to pay you, i know how to root but soemone tell me only stock firmware will  work with this even it was a rooted device.
plz help me plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
kindly mail me @ akstyagi@rocketmail.com
