Restore 4.1.2 Firmware / Unbrick Verizon DROID RAZR HD
85 replies to this topic
#41 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 17 May 2013 - 02:42 PM
You could just use the Utility.
  • irysh13 likes this
#42 myersjesse
myersjesse
  • 6 posts
Posted 15 June 2013 - 05:19 AM
jughead75, on 12 Apr 2013 - 6:40 PM, said:
Having trouble with RSDLite 6.1.4. not recognizing my MaxxHD and could use a little help. Any suggestions/help?
How did you resolve this problem? I am having the same one.  Thanks
#43 mmckaibab
mmckaibab
  • 5 posts
Posted 02 September 2013 - 06:44 PM
mattlgroff, on 22 Mar 2013 - 02:33 AM, said:
Verizon DROID RAZR HD 4.1.2 Fastboot Firmware:
Filesize: 614 MB (644,349,440 bytes)
Use RSD Lite 6.1.4 to flash:
I've tried every ROM on the site listed and none of them work. Every one hangs immediately after the first setup phone screen and all of them leave me without a baseband.
#44 cmh714
Posted 02 September 2013 - 07:56 PM
Never heard of that. Sounds like possible hardware issue....does everything work on Stock
EDIT you meant on stock if you used those files.....probably hardware then
#45 Epsilon7
Epsilon7
Posted 29 September 2013 - 05:21 PM
well the RSD software doesnt see my phone please help
#46 cmh714
Posted 29 September 2013 - 06:02 PM
Gonna need more info than that.
#47 7eregrine
7eregrine
  • 163 posts
Posted 01 October 2013 - 10:55 AM
If someone does this and goes back to stock, do they get the warning message about the Bootloader?
/Curious in case I ever need to return mine to Assurion.
#48 cmh714
Posted 01 October 2013 - 12:49 PM
The message is just a logo file so without looking at Matts script, I would think yes it will remove the message. If not, then you can just flash the logo yourself to remove the message.
#49 jcyoun33
jcyoun33
  • 8 posts
Posted 15 November 2013 - 07:18 AM
The link to Droid-Developers SBF only has the RAZR HD's firmwares. Is that ok to use on the Maxx HD? A little noob to the Motorola way of Android. Thanks for you replies.
#50 Memnoch73
  • 5,016 posts
Posted 15 November 2013 - 07:27 AM
Yes sir. Both the HD and Maxx HD have the exact same software
  • jcyoun33 likes this
#51 jcyoun33
jcyoun33
  • 8 posts
Posted 15 November 2013 - 08:10 AM
So I download the firmware and get this:
usb connected
downgraded security version
update tz version failed
preflash validation failed for tz
help! Thanks :)
#52 livinginkaos
Posted 15 November 2013 - 08:17 AM
Failed TZ means you are trying to flash backwards in security.  Can't be done.  Gotta flash at least what the last stock version was..
#53 jcyoun33
jcyoun33
  • 8 posts
Posted 15 November 2013 - 08:36 AM
Do you know where I can get a later firmware? The one on the site is the latest I believe they have...
#54 johnthehillbilly
Posted 15 November 2013 - 08:45 AM
A later firmware?.... sbf developers does indeed have the most current firmware(s)
You just need to double check to make sure you are flashing the proper one :)
#55 cmh714
Posted 15 November 2013 - 09:45 AM
Post your Build number and maybe we can help better.
#56 livinginkaos
Posted 15 November 2013 - 11:34 AM
Here are the 4.1.2 links - newest to older
4.1.1 -
#57 livinginkaos
Posted 15 November 2013 - 11:35 AM
Many folks go to the device specific page and they have not updated those lately, so the newer builds are actually posted on the home page.
#58 jcyoun33
jcyoun33
  • 8 posts
Posted 15 November 2013 - 12:52 PM
Ah gotchya. Thanks man! Is the top link the one for the lates OTA update (I think it was 9.30 right?)?
Really appreciate the links man.
#59 jcyoun33
jcyoun33
  • 8 posts
Posted 15 November 2013 - 12:54 PM
My build number is 9.8.1Q-79-1. Figured out which link to download.
Trying now and will post back. You guys are quick to respond! Super cool :)
  • johnthehillbilly and livinginkaos like this
#60 integrate
integrate
  • 11 posts
Posted 17 November 2013 - 02:23 AM
rebretz000, on 28 Mar 2013 - 10:57 PM, said:
heres a link just make sure to use the 4.1.2
Do you have to be rooted to use RSDLite and revert your phone?
