* * * * * 2 votes
DROID RAZR M Utility 1.10 --- Windows/Mac/Linux
87 replies to this topic
#1 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 21 March 2013 - 11:21 AM
This is ONLY for the DROID RAZR M XT907 and the DROID RAZR M XT907 Developer Edition.
Deprecated! You can grab the latest @
- Windows Instructions
  • Extract .zip to its own folder on the Desktop.
  • Install the required drivers. The folder with the drivers is called "Drivers [WINDOWS ONLY]" and is included in the Utility folder.
  • Double click the ".bat" file. This will be called "WindowsUtility.bat" the image is just for reference.
- Mac & Linux Instructions
  • Extract the .zip to any folder you like, the /Downloads/ or /Desktop/ folder should work just fine.
  • Open a Terminal window. (On Mac: Applications > Utilities > Terminal)
  • Learn your 'sudo' password. This is almost always your Admin password on a Mac computer. On Linux you should already know what this is, its yours account password if your account is an admin as well.
  • Type the following code into the Terminal Windows, places where it says ***DRAG HERE*** are telling you to simply drag the folder there. For example: cd ***DRAG FOLDER HERE*** then press 'Enter' after each line.
  • You will be asked for your sudo password at least once in the Utility process, so make sure you followed the instructions to learn it.
Functions of the DROID RAZR M Utility 1.10:
Number 1 Explained -- This option requires your phone be in AP Fastboot mode. It will flash the official Jellybean firmware to your device.
Number 2 Explained -- This is Dan Rosenberg's DROID RAZR M 4.0.4/4.1.1 exploit called 'motofail2go'. This option requires your phone to be booted normally, with USB Debugging enabled.
Number 3 Explained -- This option requires your phone to be booted normally, with USB Debugging enabled. It will install Voodoo's OTA Rootkeeper App.
Remember, do not run this utility unless your phone is at 100% battery OR you have bought yourself one of Team Black Hat's Factory-Style Programming Adapters.
Thanks to Djrbliss for motofail2go!
  • Bmplekan, neckchop, jamminjon82 and 9 others like this
#2 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 21 March 2013 - 11:25 AM
Thank you yet again, Matt. The hard work is always most appreciated
#3 Beanerman
Beanerman
  • 23 posts
  • Current Device(s):RazrM
Posted 21 March 2013 - 07:12 PM
Awsome work! As usual. Thank You for all your hard work.
#4 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 21 March 2013 - 08:15 PM
Very nice. Thanks Matt.
#5 Monster
Monster
Posted 22 March 2013 - 11:42 AM
Just wanted to say you're awesome, thanks for this!
  • neckchop likes this
#6 Beanerman
Beanerman
  • 23 posts
Posted 23 March 2013 - 07:52 PM
Very nice work, as usual. I enjoyed your work with the DX over on XDA. Thank You for all your hard work.
And Thanks to Dan for his work too.
#7 mrc00lbreeze
mrc00lbreeze
  • 7 posts
Posted 27 March 2013 - 12:20 PM
Worked perfect. Have had my M for 5 months now and glad I waited for something like this. Thank you.
#8 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 10 April 2013 - 11:26 PM
Looks like I'll be using this today. Need to clean up everything after unlocking, and fastboot will probably be the answer.
#9 mrc00lbreeze
mrc00lbreeze
  • 7 posts
Posted 11 April 2013 - 05:02 AM
Could you please let me know how it goes?
#10 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 11 April 2013 - 05:38 AM
Thanks for this awesome utility! I used it today after messing around too much with my unlocked RAZR M and it worked flawessly. Followed all the steps and within 1 hour I am completely back to where I was before unlocking. As a note, it does not remove unlock. Thanks to this awesome dev and the others for there individual work.
  • neckchop and RikRong like this
#11 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 11 April 2013 - 05:50 AM
Will do.
edit: I will have to say that's the fastest Fastboot I've run. Running through RSD is nerve racking, this was painless. MrcOOlbreeze, fastboot worked, the root method worked. I now have TWRP (the older version that's in the RazrM Devleoper Section) installed. I tried to flash Eclipse and that failed. Then I flashed Flying Jelly, it's working.
  • timpohladthomas likes this
#12 mrc00lbreeze
mrc00lbreeze
  • 7 posts
Posted 11 April 2013 - 07:41 AM
Will do.
Ikr? Rooted with SS installed. Thinking of unlocking but will probably use utility to go back to original stock then unlock. Seems like people are having issues with uninstalling SS. Then install TWRP.
Edit: Forgot to say thank you.
#13 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 11 April 2013 - 08:04 AM
I would unlock, then use the utility. It doesn't really matter what order, though. NP, I've learned a lot in this process. Flashing on my Samsung Tablet is easy, this phone is a moody beotch. ;)
#14 GillRigged
GillRigged
  • 121 posts
  • Twitter:@GillRigged
  • LocationNW WI
  • Current Device(s):Droid RAZR Maxx HD, Droid RAZR M
Posted 21 April 2013 - 11:58 AM
Use a Download Manager such as "Orbit Download Manager" for best downloading results.
Mirrors:
Filesize: 565 MB (592,972,056 bytes)
MD5: 02AA630EB5E39DF6DF230F1CC8E59472
Will the DROID RAZR M Utility 1.20 be coming out soon with 4.1.2?
#15 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 21 April 2013 - 02:17 PM
Once they put up the fxz. :)<br /><br />Sent from my XT907 using Tapatalk 2<br /><br /><br />
#16 Beanerman
Beanerman
  • 23 posts
Posted 21 April 2013 - 02:57 PM
U unlocked the non-developers edition??
and if so, How? Fastboot?
Any info appreciated.
#17 neckchop
neckchop
    pluh!
  • 477 posts
Posted 21 April 2013 - 03:42 PM
I tried to copy the link, but tapa talk was acting up on me. If you read through the forums here, there is a thread about Motorola boootloader being unlocked with link and download. For the utility. Read the instructions thoroughly before using the utility, and feel free to ask for assistance if needed, either in the thread or via pm. There's lots of helpful info if you read through the thread, or send a pm. :-)
  • Beanerman likes this
#18 Beanerman
Beanerman
  • 23 posts
Posted 21 April 2013 - 04:01 PM
Thank u neckchop.
#19 neckchop
neckchop
    pluh!
  • 477 posts
Posted 21 April 2013 - 04:20 PM
Any time dude. Did you manage to find the thread?
#20 Beanerman
Beanerman
  • 23 posts
Posted 21 April 2013 - 05:02 PM
Neckchop, I found this with a link to it.
