Alright so I have noticed that there are a few similar posts but I cant seem to find a solution for me in any of them.
SO.. I really messed up installing a new rom via BMM, and I had accidentally (stupidly) deleted the Main rom and then rebooted, which in turn got me stuck in AP flash mode.
I get,
Device is LOCKED, Status Code: 0
Battery OK
Ok to program
Transfer Mode:
USB Connected
Invalid CG OTV (CG: system): Invalid SP Data
Invalid CG HAB (CG: system, status: 0X0056)
I have tried all sorts of different ways of trying to Unbrick, RSD Lite, Eternity Project and a few others but not sure they had actual names to them.
I can get RSD lite with a Rogers fastboot file to at least try to flash but I always get to 6/21
or more precisely
"failed flashing process. 6/21 flash cdt.bin "cdt.bin_signed" ->Phone returned FAIL"
ANY help would be greatly appreciated.
nEmo
XT910 Bricked
nemofunk
, Mar 19 2013 08:15 PM
6 replies to this topic
Posted 19 March 2013 - 08:15 PM
Posted 19 March 2013 - 08:19 PM
Can you get to recovery?
~Corona63976~
Posted 19 March 2013 - 08:25 PM
I can get into the Boot Mode selection menu, but when I click on Recovery, it goes into the Moto boot image and then takes me back to the AP boot menu, same with the BP tools selection. So I would say No (?).
I also forgot to mention I had to make a factory cable and did so successfully.
Posted 21 March 2013 - 07:28 PM
Alright so I have made a *little* bit of progress, but still not able to install a rom or recover almost anything.
I have atleast gotten to the point of when trying to boot up it gives me the Moto symbol, where as before it was
just giving me the ap boot menu. as I said small progress but its something.
Posted 21 March 2013 - 09:11 PM
Another update, I have successfully recovered my Phone, I believe what ultmately got it running was first running Droid Razr Utility which gave me back the Moto symbol and then from there I tried a a few fastboot files which is what eventually got back working. I am relieved but it also gives hope to others that are having the same problem, considering this I will be more active with posts and giving others help.
nEmo
nEmo
Posted 03 April 2013 - 04:41 AM
I get,
Battery OK
Cannot program
Transfer Mode:
USB Connected
I am a n00b to all of this and when mine actually tries to boot it gives me Encryption Unsuccessful.
Can some one give me some detailed instructions on what my next move should be????
Battery OK
Cannot program
Transfer Mode:
USB Connected
Posted 03 April 2013 - 12:30 PM
Ultimately I had to get 2 different utilities to get my phone at least to a state that I can use it.
I used Droid Razr Utility, and RSD lite.
Im sorry I do not have links but a good google search should lead you to them,
I ran the Razr Utility, I also had to search for a compatible fastboot file that worked with my phone,
which took ALOT of searching to find one that actually worked.
Well good luck, best suggestion is be persistant and keep hacking away at it till you get it working.
nEmo
nEmo
