[Rom]Miui-V4 Beta (6/15/12)
rom MIUI MIUI
309 replies to this topic
#1 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 09 March 2012 - 07:54 AM
Here We go today i have a unofficial MIUI-V4 using DHACKER29 and HASHCODE ICS base.
It is in a Alpha stage. I am ask any devs. out there willing help would be greatful to get the bugs worked out, thanks.
HUGE Thank goes out to:
Hashcode for his knowledge and skills
STS-Dev-Team for the awesome contribution for the Moto phones
DroidTh3ory
ANY DEV working hard to make roms and awesome Apps
DROIDRZR.com for a nice site tou call home
Everybody that likes MIUI themes should check www.miuithemes.com
ICS Base from STS-Dev-Team - So You have to be on a 17x. system for this rom to work
STILL ON GB KERNEL.
changelog:
Initial Release;
3/9/12:Fix Applying Theme issue
3/14/12:
Add Front Facing Camera fix (thanks to rapmv78)
Added Missing MIUI apps that had to be translated---(thanks to DroidVicious)
cleaned up system and the init.d script
3/17/12:
Updated MIUI Base system to 2.3.16
Added all updated MIUI Apps-Yes i know some are in chinese-
Updated MIUI Home - there are more options for the launcher in /launcher settings
New Lockscreen-change the lock wallpaper if it looks weird on first boot-
Torch is working - Tip can hold Home button at lockscreen and torch will come on.
status bar options added in settings
*broke usb mass storage switch- but have a work around app installed for you Called USB Mass Storage*
3/20/12:
fixed usb mass storage connection to computer
translated MIUI app: Monitor and Antispam
add File Manager back
add CM gallery - MIUI gallery doesn't read external Sd
Updated Google Play Market
3/24/12
update system to 2.3.23
added new alarm clock app
add new settings
minor clean up
3/30/12
update to 2.3.30
Fixed alarm not snoozing and stoping sound
Optimise password-protected applications do not appear in the recent Task list
Optimisation of the recent task pane click-able area to resolve a mistaken click problem
Repair to clear the "Settings" no lock screen data leads to abnormal operation
Repair in some cases cannot ROOT
Repair screen vertex does not display rounded corners, the status bar interface displays the wrong information
Repair removing settings data leads to lock screen display issues, also launcher becomes unresponsive
Repair MoboPlayer playback FC issues
Update ALL MIUI APPS
4/20/12
update to 2.4.20
Fixed Phone FC on boot
update MIUI Framework
new MIUI System UI
Updated all apps to MIUI 2.4.20
updated lib files from MIUI
and other MIUI features
4/27/12
update to 2.4.2
Optimisation to improve the call log loading speed
Fix service provider to show owner information, information displayed incorrectly
Optimisation of Telecommunications number attribution
On-line picture library support for choosing contact photo via Theme Manage
Optimisation of merge duplicate contacts UI interaction
Fix in some cases, you cannot open the dial-up message dialogue page
Fix FC when selecting contact to send a new messag
Fix contact number attribution issues numbers stored with +44 / 07 for same contact do not show contact name
Fix problems sending Mms messages
Optimisation of new SMS time format method
New SMS / MMS application priority option to choose which application will receive the message first
5/4/12
update to 2.5.4
Optimisation to increase efficiency of loading list of installed applications
Fix problem setting Custom status bar notifications leads to FC error
Fix in some cases when recovering data operation is completed successfully, the result will be displayed as 0Bytes restored
etc
5/11/12
update to 2.5.11
New system search with set of sub search options
Optimisation of text editing interactions
Optimise Chinese Phonetics in T9 database
Optimised support for V4 Themes
etc
5/18/12
update to 2.5.18
New text editor function for magnifying glass by long-pressing text will show highlighted words in preview pane
Optimization to further improve interactive gestures in the text editor mode (will not display when the input box is empty when you press the cursor and Optimize double-click selection criteria)
Optimize text editor copy operations
Added quick entry to Calendar functions by opening status bar area and pressing on the date (left of screen) will directly open Calendar
Fix lock screen display delay issues
Added quick access to System Settings in status bar
Added new app switching animation transitions
etc
5/25/12
update to 2.5.25
Fix Exchange FC issues
Added when manually installing an application the system will automaticall scan the app for viruses and security issues
Optimisation of the switch controls to replace the ideographic check controls
Fix problem during call, cannot recognise some headphones when they are pulled out
Optimisation of T9 to improve the search, synchronisation, update and import efficiency of contacts and reduce space and memory usage
Optimise the alarm interface resources package is deleted will cause the alarm to FC
Fix problem setting LED light colours do not take effect
etc
*to let you i know i have noticed that some widgets this week don't work. for me I saw my Gmail widget never loaded properly*
6/01/12
Fix some applications, pressing the back key player gif results in locking
Remove the "Disable" button to disable the system applications on app info page to prevent incorrectly shutting down core services which may lead to stability problems
Optimise light-sensor strategy to tackle screen lighting issues
Optimise (CDMA) call ended still shows the green return to call information
Added support for displaying music spectrograph animations
Optimisation without SIM card will display the phone in Airplane mode
Optimisation of lock screen to provide 720P HD support
NEW Allow to show / hide system FC error messages (See developer options for further details)
fix widgets showing on desktop
New Monitor apk look
softkey fix incorporated
6/8/12
update to 2.6.8
fix T cdma64 to Verizon Wireless
Optimisation - when adjusting the clock minute selection, the clock does not automatically add / subtract
New call, new call reminder supports notification tone, can also be set up with prompts e.g.
New functions for stopping current program (press return key) with a longer response time
Add support for majority of original factory settings
etc
6/15/12
update to 2.6.15
Optimized 12-hour time-phased by the "AM / PM" to "morning, noon, afternoon, evening, and midnight,
Optimisation of third-party calling, allow the proximity sensor to turn on or off the screen
Fix in some case the wrong session is displayed from the search results page
Optimisation of desktop frame rate
Fix problems with gallery library FC issues
Optimisation of SMS keyword (spam) filtering rules
etc
* Here is a link to Full MIUI changelog, some changes don't pertain to are phone *
SoftKey Fix zip:
install zip after Intial install of MIUI
wipe cache
wipe dalvik cache
flash softkey fix zip
reboot
READ THIS:
please do a wipe data, wipe cache and wipe dalivik cache
You can use both Bootstrap and Safestrap to install this rom
You don't have to install GAPPS they are include
Known issue in the Rom:
  • Camcorder
  • External SDcard doesnt mount-temporly i left file manager so you at least find files
  • Data doesnt come on by itself you have to go in to phone info and toggle gsm only mode: but there is a phone info shortcut on one of the pages. to toggle back to gsm/cdma auto Or you can dial *#*#4636#*#* to get to phone info to toggle the radio
  • When downloading anything your phone will warn you that you about downloading using data. To change :Downloads -> Menu button -> Settings -> Data Download ------ Thanks to (TSON)
MIUI-V4: (3/9/12 2:30 est)
Link:
md5:069cd2042ba6d23029c01b993186314f
THanks Mattlgroff for mirror
MD5: 069cd2042ba6d23029c01b993186314f
Link:
MIUI-V4:update 3/14/12
Link:
MD5:611495cce58ad097c512749a6a0d2191
MIUI-V4-Aplha:MIUI Update 2.3.16:
link:
MD5:a659ad73f71bbdf2777952d8c34edd37
MIUI-V4-Alpha: (3/20/12)
link:
MD5: a58c2db4aca4b67aff2f94a3daa2664f
MIUI-V4-Beta:MIUI Update 2.3.23
link:
MD5: 385d64c032b9277ba0b016ccc2861e0f
MIUI-V4-Beta:MIUI Update 2.3.30
link:
MD5: 5b6f0e250170bf5c3de1da2cbc9c5478
MIUI-V4-Beta:MIUI Update 2.4.20
link:
MD5: fe10f98b21de546242d3fa53eb465a71
MIUI-V4-Beta:MIUI Update 2.4.27
link:
MD5: 421179e16dded89240dc73456a3172f8
MIUI-V4-Beta:MIUI Update 2.5.4
link:
md5: 5978504148fc6568a465e93d5ccb3200
MIUI-V4-Beta:MIUI Update 2.5.11
link:
md5: 386561147d8e68aebab820fb4d54b988
MIUI-V4-Beta:MIUI Update 2.5.18
link:
md5: 07bd2ed334c149026263178fb96e5b80
MIUI-V4-Beta:MIUI Update 2.5.25:
link:
md5: dad551abcf4dd6556e9ea82be3629f48
MIUI-V4-Beta:MIUI Update 2.6.1:
link:
md5: 5642118ebe7020b66e25e6804adf834e
MIUI-V4-Beta:MIUI Update 2.6.8:
link:
md5: 77ef76192a81a1e9d1c66314beaeaa0c
MIUI-V4-Beta:MIUI Update 2.6.15:
link:
  • wyld, mattlgroff, Nubia1 and 10 others like this
Lets the sun and the moon collide! eclipserom.com
#2 en7gm4
en7gm4
  • 137 posts
  • Twitter:https://twitter.com/#!/en7gm4
  • LocationtEXas
Posted 09 March 2012 - 07:58 AM
oh yes cant wait.
#3 Z32CM
Z32CM
  • 41 posts
  • LocationWisconsin
Posted 09 March 2012 - 08:08 AM
Oh how I love MIUI. Can't wait.
#4 Baby Duck
Baby Duck
  • 61 posts
Posted 09 March 2012 - 08:43 AM
Nice!
  • gundeeee likes this
#5 JungleKing76
JungleKing76
  • 446 posts
Posted 09 March 2012 - 09:24 AM
This is what I have been waiting for!
Sent from my XT875 using Xparent Purple Tapatalk
#6 mudthestud23
mudthestud23
    made of water, dirt, rocks.
  • 511 posts
  • Twitter:@mudthestud23
  • Google+:mudthestud23@gmail.com
  • LocationMinnesota where its really cold!
  • Current Device(s):droid razr hd maxx, droid razr 4, droid razr maxx
Posted 09 March 2012 - 09:28 AM
i guess i can stop theming now. awesome!
#7 en7gm4
en7gm4
  • 137 posts
  • LocationtEXas
Posted 09 March 2012 - 09:29 AM
@mud just means you can start miui theming.
#8 (TSON)
(TSON)
  • 529 posts
  • Themes don't Apply
#9 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 09 March 2012 - 09:34 AM
Says files not found.
DL link works fine.
:-D :-D
#10 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 09 March 2012 - 09:40 AM
I think that was mostly directed at the themes that come with the ROM.
:-D :-D
#11 simon_lefisch
simon_lefisch
  • 265 posts
  • Current Device(s):Razr Maxx
Posted 09 March 2012 - 09:44 AM
MIUI for the razr?!?! wtf?! damn it. now i have to flash this. damn you people making me a crackflasher!! lol j/k guys. loved MUIU on my D2 so im def gonna have to give this a whirl. thanks skiwong :D
  • biggiesmalls657 likes this
#12 mudthestud23
mudthestud23
  • 511 posts
Posted 09 March 2012 - 09:48 AM
i could but theres already a gazillion themes.
#13 Muteki
Muteki
  • 132 posts
Posted 09 March 2012 - 10:21 AM
FINALY Some Love from Miui THANKS!!!!!
#14 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 09 March 2012 - 10:34 AM
Fixed the Applying theme issue. getting up in a little!. not everything applys in the theme but the lockscreen, icon and wallpapers change work.
#15 DroidAddict101
DroidAddict101
  • 259 posts
  • LocationBinghamton
Posted 09 March 2012 - 11:00 AM
Yes!!!!!! So excited to get home!!!!!
#16 simon_lefisch
simon_lefisch
  • 265 posts
Posted 09 March 2012 - 11:06 AM
so how does data hold up? any drop outs?
#17 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 09 March 2012 - 11:19 AM
Data has been holding up good for me. but have to see other areas i am in a strong 4g area.
Theme manager is fixed here it is
changing link in op now
#18 uberbdon
uberbdon
  • 367 posts
Posted 09 March 2012 - 11:27 AM
Hell yeah!
#19 aalopez10
aalopez10
  • 35 posts
Posted 09 March 2012 - 11:33 AM
If the sd external dont work...does taking pictures work & save on the sd card n if downloading stuff also..?
#20 Gotsaved289
Gotsaved289
  • 9 posts
  • Google+:aarontblum
Posted 09 March 2012 - 11:39 AM
This looks sweet.
Also tagged with one or more of these keywords: rom MIUI, MIUI
