([ROM]) wWidow HD for XT926 (3|20|13)
#121
Posted 09 April 2013 - 09:01 AM
- andlaw and BladeRunner like this
#122
Posted 09 April 2013 - 06:32 PM
#123
Posted 09 April 2013 - 06:37 PM
I unlocked the bootloader, installed twrp, and flashed white widow back on and lost my power toggles again. Same thing happened a couple weeks ago on black widow. When I long press power it just instantly reboots, I have no option to power off. Any idea what can cause this? And I keep getting clock force closes on boot up.
I unlocked my boot loader, loaded twrp, mounted system in advanced, flashed the wWidow ROM, booted up and have been running since last night and everything from the get go has been flawless.
only thing I can think of is wipe wipe wipe and wipe again, reflash the ROM... and don't restore any old data, should be good to go.
#124
Posted 09 April 2013 - 09:08 PM
if you did a back up to wWidow, after mounting the system and wiping everything just restore your back up dont to not start from the beginning, that is what i did and it works flawless
#125
Posted 10 April 2013 - 06:14 PM
Thanks in advance.
Edit#1: I tried wiping cache and dalvik, dirty flash, rewipe both again, and same issue. I dont use either G+ or foursquare that much, so its not a huge deal, and it does not seem to be affecting anything else I use, even other google apps work right. Was just seeing if anybody had any ideas as to what would cause that.
#126
Posted 12 April 2013 - 06:07 AM
#127
Posted 12 April 2013 - 06:15 AM
Anyone know this clock?
.... 4.2 google desk clock.
#128
Posted 12 April 2013 - 06:55 AM
#129 Guest_Megaroad_*
Posted 13 April 2013 - 09:16 AM
#130
Posted 13 April 2013 - 09:18 AM
Question - what does "Hot Reboot" do?
reboots straight into the ROM instead of safestrap menu... shaves like 20s or so off the boot time....... mainly used for testing and or whatever~
#131
Posted 19 April 2013 - 09:52 PM
You don't really need to download the whole sdk. Just use matt's utility for the HD. Drop the stocklogo.img in the folder. Install (or install repair) the drivers just to be sure (again, they are in matts's utility), open a command prompt window from that folder, put phone in fastboot mode type fastboot flash logo stocklogo.img . When it's done type fastboot reboot and you're done
Dude, you rock! Thanks for the advice. Been searching for this solution for days.
#132
Posted 24 April 2013 - 08:04 AM
I am pretty sure I have stated this. as I updated the current builds I removed all mods, and as I released the updates, I continued to redo the Mods, Honey comb circle is the only battery Mod I have not converted to white yet..... and I am currently in the process of moving, I won't be updating or releasing anything for another month... so enjoy what I have to offer or move along to BW where I have more mods available ~
Heya bud just a quickie for ya. I know you had alot of crap going on with the move and so forth. Since then things have changed alot obviosuly with the unlock & custom recoveries. That said was just curious if you still have plans on updating wWidow moving forward for use with TWRP, and getting it updated to 4.1.2 instead of the older 4.1.1 base currently being used.
#133
Posted 24 April 2013 - 08:09 AM
it installed just fine for me using TWRP on my unlocked MAXX HD.?
I highly doubt it as I don't have the time to go back through and redo everything for a base.. which you can flash the kernel from the new base if you want/need to.. android is not at the top of my list on things to do anytime soon unfortunately~
#134
Posted 29 April 2013 - 07:27 PM
If i understand correctly, in order to flash this ROM, I need to flash the 4.1.1 kernel since im on 4.1.2.
So where can I find the 4.1.1 boot.img ?
#135
Posted 30 April 2013 - 08:05 AM
I'm almost positive I was running it that way.
Doug B.
#136
Posted 30 April 2013 - 08:10 AM
This should work with 4.1.2 kernel.
Doug B.
correct
#137
Posted 30 April 2013 - 08:19 AM
No need for the 4.1.1 kernel. Devs build works fine with the 4.1.2 kernel
#138
Posted 30 April 2013 - 08:22 AM
Yeah i know I've been using your builds on my Dev edition since long before the consumer units were even unlocked for use with a custom Recovery. I'm just not a fan of running old SW builds with newer kernels and so forth. Fully understanding not updating tho as it is a HUGE time sync to say the least.
- andlaw likes this
Also tagged with one or more of these keywords: Deodexed, Debloated, Zipaligned, JB 4.1.1 blur based, AOSP apps, 4.2 camera, 1% Accurate battery, Widow Butter tweaks
