JB 4.1.2 Fastboot files for XT912
Posted 15 March 2013 - 05:42 AM
- nafman likes this
Posted 15 March 2013 - 07:07 AM
Posted 15 March 2013 - 07:35 AM
Via Tapatalk
- mtsalheen likes this
Posted 15 March 2013 - 07:42 AM
That file courtesy of The Firmware Team, I believe.
Via Tapatalk
And its in Matts new utility.....
Posted 15 March 2013 - 08:47 AM
Posted 15 March 2013 - 10:45 AM
, thanks for the clarification .... What Should I do now?
Posted 15 March 2013 - 10:48 AM
I thought that would fix all my errors popping up, but I am still getting them. I tried everything that I know of.
Posted 16 March 2013 - 05:07 PM
Posted 18 March 2013 - 02:02 AM
Posted 18 March 2013 - 05:39 AM
Has Anyone Actually Used These These Files Yet To Go Back ?
These files are in the new Utility There do not seem to be any problems using the utility although not all scenarios have been tested. People on JB have went back to stock with a data wipe without issue
Posted 18 March 2013 - 02:00 PM
Yeah it totally saved my butt, worked great. For some crazy reason I trued to go back to ics after the ota update. I used mats utility (1.82) and the process completed, went to reboot, and crapped out after the motor m logo. I used rsd and it work perfectly
#13 Guest_BDH_*
Posted 19 March 2013 - 02:26 AM
Sure have.
Sent from my Barnes & Noble Nook HD using Tapatalk HD
Posted 28 March 2013 - 12:19 AM
- #root# likes this
#15 Guest_BDH_*
Posted 28 March 2013 - 12:37 AM
you use RSD lite. 2 install Fastbook files correct?
Yes v5.6 and above.
Posted 29 March 2013 - 01:41 AM
Posted 17 February 2015 - 11:49 PM
Hi could not download it
my browser shows the message below:
File not found.
Sorry, the page you are looking for is currently unavailable.
Please try again later.
If you are the system administrator of this resource then you should check the
for details.#18
Posted 17 February 2015 - 11:50 PM
File not found.
for details.#19
can anyone share a link for fastboot files for verizon droid razr 98.72.165.xt912
Posted 21 February 2015 - 08:03 AM
go grab SamuriHL's House of Moto - those should work fine.
- johnthehillbilly likes this
