[Cdma Razr][Gingerbread] Tranquil Ice V7.xx - Bringing Ice Cold Heat To The Razr
179 replies to this topic
#41 iDroidGuy
iDroidGuy
    :D Taco!
  • 650 posts
  • Twitter:iDroidGuy
  • Google+:Stephen Wilmot-Doxey
  • LocationHopewell, VA
Posted 04 March 2012 - 12:05 PM
I can't even get any data from teh start. I used bootstrap. Could that be the issue?
If you'd like to buy me a Mountain Dew just PM me for my PayPal info. Thanks :)
#42 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 04 March 2012 - 12:10 PM
Quite a few of the apps i have purchased or used in the past show up as incompatible? Any thoughts?
#43 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 04 March 2012 - 12:24 PM
*#*#info#*#* then toggle
thanks, got it.
#44 Tmc363
Tmc363
  • 182 posts
  • Twitter:@tmc363
  • LocationHouston, Tx
Posted 04 March 2012 - 12:25 PM
Quit a few of the apps i have purchased or used in the past show up as incompatible? Any thoughts?
not sure y but some don't work or aren't in there twicca Is one in particular I couldn't find but all the plug ins for it are there.
All please remember this is P3's first release for tranq rzr any custom rom is a work in progress some things may not be perfect but this rom offers a ton of options for the user to customize to their liking. Make sure you follow all instructions from op and wipe EVERYTHING THEN FLASH Thanks P3 for the hard work!
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here: http://www.droidrzr....-custom-titles/
#45 iDroidGuy
iDroidGuy
    :D Taco!
  • 650 posts
  • Twitter:iDroidGuy
Posted 04 March 2012 - 12:32 PM
It is an ICS ROM and some apps still haven't been converted by their devs to work on ICS
#46 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 04 March 2012 - 12:59 PM
If your just now joining us read the post I made I think its 39
  • The Kid likes this
#47 mgarney26
mgarney26
  • 116 posts
  • Twitter:mgarney26
  • Locationmobile alabama
Posted 04 March 2012 - 01:06 PM
has anyone gotten usb to work on this?
#48 Tmc363
Tmc363
  • 182 posts
  • Twitter:@tmc363
Posted 04 March 2012 - 01:18 PM
I do not believe USB works on this release
#49 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 04 March 2012 - 01:26 PM
OK first off I've been running this rom for a few days its great.
- yes you can flash in bootstrap and safestrap. I flashed in safe strap. I wiped data/catch + dalvik and formatted system and installed . It booted in 37sec. **I would recommend using the newest safestrap 1.09**
-Data is stable most of the time. It seems that if the phone gets low on juice, the data will go out. Download from the market LTE switch, from the market, yes i no its for the tbolt, just use it. If you have issues with data go to app, select GSM mode wait 5 seconds or so till you see ppp value in kb go up and switch to CDMA auto PRL or GSM/CDMA auto PRL. It will work in GSM mode sometimes
If that fails leave it on GSM/cdma auto PRL and reboot. Then follow the instructions.
- battery life is great. On my maxx I got with Heavy use about ten hours with the screen on for 7 hours.
- to take a screen shot hold down and power at the same time.
- If you need to get into the advanced wifi options, use the pull down bar, and hold the wifi toggle, Same with network settings, long press the 3G 4G button.
- Yes some of your apps will not work or will be available on the market to to that app not being updated by the develouper.
- Do not use the Front Facing Camera aka FFC , it will force close, If you do touch it, go into camera and force stop and clear data and cache.
- If you are having problems installing it , You are doing something wrong , i tested this rom in both SS and BS . There is no way of getting around it you have to wipe data . Always make sure you download is compleate and check the MD5 sum.
- If you are installing this via safestrap , you DO NOT have to back up webtop on the initial back up. Yes before you flash this in SS make a backup. I always clear cache and dalvik before i make any backup.
****** The data question will be asked a million times I'm sure, so please refer ppl to this post. #39****
@P3Droid and @Droidjunk have put ton's of time into this rom. Everything will not be 100% There will be updates till this rom reaches perfection, well as close as you can get to it. So let's thank them for giving us a great first edition into Tranquility.
updated
#50 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 04 March 2012 - 01:50 PM
1. Change Log in About does not match the OP and the text is too dark.
2. Soft buttons are off and have to be turned on with Display toggle....but turn back off once you lock and unlock phone.
#51 P3Droid
P3Droid
    Android Legend/ Mentor
  • 29 posts
  • Twitter:P3Droid
Posted 04 March 2012 - 01:53 PM
We will look into piecing together the broken parts, and this is your first release.. have patience
#52 iDroidGuy
iDroidGuy
    :D Taco!
  • 650 posts
  • Twitter:iDroidGuy
Posted 04 March 2012 - 01:54 PM
How do you check an MD5 Sum?
Sent from my Galaxy Tab using Tapatalk
#53 tyrthas
tyrthas
    CassDroid's Personal Stalker
  • 455 posts
  • Twitter:@tyrthas
  • Google+:Ron Becker
  • LocationMissouri
Posted 04 March 2012 - 01:58 PM
If I'm doing it on my phone I use MD5 Checker.
Here:
Sent from my AOKP AXI0M [R]
#54 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 04 March 2012 - 02:00 PM
No sd-ext support ? nothing showing up in my gallery ! lol
#55 P3Droid
P3Droid
  • 29 posts
  • Twitter:P3Droid
Posted 04 March 2012 - 02:01 PM
Err what I mean, is that an error report is not necessary..
#56 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 04 March 2012 - 02:04 PM
Works for me. Root Explorer and Gallery and QuickPic.
#57 iDroidGuy
iDroidGuy
    :D Taco!
  • 650 posts
  • Twitter:iDroidGuy
Posted 04 March 2012 - 02:05 PM
Here:
I just select the file from my SD Card?
#58 mgarney26
mgarney26
  • 116 posts
  • Twitter:mgarney26
Posted 04 March 2012 - 02:09 PM
as with all new releases there will be bugs. i for one think this rom has potential though and i appreciate all the work that went into this p3droid! thanks!
#59 wyld
wyld
  • 845 posts
Posted 04 March 2012 - 02:11 PM
nope not for me i cant see anything from sd-ext pics,videos,music ! maybe bad download or bad flash ? was coming from Eclipse v1.3
i can see my sd-ext from Root Explorer. just not from gallery or music player.
#60 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 04 March 2012 - 02:50 PM
Been rocking this ROM since it's release, and it's by far the best ROM I've ever used. It's seriously leaps and bounds ahead of any ICS ROM out there at the moment. Tranquil really shines once it has settled a bit.
Thanks P3, this bad boy is incredible.
Sent From Optimus Prime
:-D :-D
