[Cdma Razr][Gingerbread] Tranquil Ice V7.xx - Bringing Ice Cold Heat To The Razr
#21
Posted 04 March 2012 - 10:38 AM
#22
Posted 04 March 2012 - 10:40 AM
- gunrunnintrucker likes this
#23
Posted 04 March 2012 - 10:42 AM
My RAZR Bleeds Awesomeness!!
#24
Posted 04 March 2012 - 11:17 AM
Edit. Got 4g on first boot without toggle.
#25
Posted 04 March 2012 - 11:23 AM
#26
Posted 04 March 2012 - 11:24 AM
#27
Posted 04 March 2012 - 11:44 AM
#28
Posted 04 March 2012 - 11:47 AM
you canWhy wouldn't we be able to flash thru Bootstrap?
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here: http://www.droidrzr....-custom-titles/
#29
Posted 04 March 2012 - 11:50 AM
it doesIt's in the TBH app already just wish it work with bootstrap any testers.
AOKP AXIOM [R]AZR AB8 I GOT THAT FIYAH!!!
#30
it isThe OP says SafeStrap or BootStrap ! And im gonna assume this is a .173 based rom ? the OP does not specify ! lol
#31
#32
#33
Posted 04 March 2012 - 11:53 AM
check network settings probly reverted to gsm does it on axiom ab8 aswellI got 4g on first boot. But applied a boot animation, rebooted and it took and now can't get 3g or 4g, lol wifi now.
#34
Posted 04 March 2012 - 11:54 AM
GSM not an optioncheck network settings probly reverted to gsm
- artcer19 likes this
#35
Posted 04 March 2012 - 11:57 AM
#36
Posted 04 March 2012 - 11:59 AM
#37
Posted 04 March 2012 - 12:00 PM
*#*#info#*#* then toggleGSM not an option
#38
Posted 04 March 2012 - 12:01 PM
did u wipe everything. Try booting into stock recovery and wipe data factory resetinstalled fine, but won't boot up to it... what am I doing wrong?
#39 Guest_DirtyDroidX_*
Posted 04 March 2012 - 12:05 PM
- yes you can flash in bootstrap and safestrap. I flashed in safe strap. I wiped data/catch + dalvik and formatted system and installed . It booted in 37sec. **I would recommend using the newest safestrap 1.09**
-Data is stable most of the time. It seems that if the phone gets low on juice, the data will go out. Download from the market LTE switch, from the market, yes i no its for the tbolt, just use it. If you have issues with data go to app, select GSM mode wait 5 seconds or so till you see ppp value in KB go up and switch to CDMA auto PRL or GSM/CDMA auto PRL. It will work in GSM mode sometimes
If that fails leave it on GSM/CDMA auto PRL and reboot. Then follow the instructions.
- battery life is great. On my maxx I got with Heavy use about ten hours with the screen on for 7 hours.
- to take a screen shot hold down and power at the same time.
- If you need to get into the advanced wifi options, use the pull down bar, and hold the wifi toggle, Same with network settings, long press the 3G 4G button.
- Yes some of your apps will not work or will be available on the market to to that app not being updated by the developer.
- Do not use the Front Facing Camera aka FFC , it will force close, If you do touch it, go into camera and force stop and clear data and cache.
- If you are having problems installing it , You are doing something wrong , i tested this rom in both SS and BS . There is no way of getting around it you have to wipe data . Always make sure you download is complete and check the MD5 sum.
- If you are installing this via safestrap , you DO NOT have to back up web top on the initial back up. Yes before you flash this in SS make a backup. I always clear cache and dalvik before i make any backup.
****** The data question will be asked a million times I'm sure, so please refer ppl to this post. #39****
@P3Droid and @Droidjunk have put ton's of time into this ROM. Everything will not be 100% There will be updates till this ROM reaches perfection, well as close as you can get to it. So let's thank them for giving us a great first edition into Tranquility.
- MrFrankRazr, mugsy77, jtelander and 1 other like this
#40
ahh... I was coming from eclipse ROM. Just thought I could wipe via CW. I'll try that later.
