[Rom][Razr - Gsm][Cdma Port] Cm9/aokp #givesomelovetogsm
ICS AOKP CM9 GSM
20 replies to this topic
#1 spryte
spryte
  • 28 posts
Posted 03 March 2012 - 06:35 PM
Hey guys,
here is some Ice Cream Sandwich for you :)
Finally, after having eliminated most problems, also here available.
Of course, all credit goes to
and everyone else who works on ICS for the Razr
CM9 and AOKP, both roms have the same working functions and bugs.
Working now: phone calls, SMS, DATA, camera (photo), adb, Bluetooth (must come from rom mentionned in installation instructions, thanks
Not working: camera (video, panorama)
Flash only if you are aware of the consequences and know how to restore your original system!
This is not ready for daily use (especially not on GSM) and I am not responsible for any damages.
If you have FCs or random reboots, try to flash the 2.3.6 rom from the instructions first!
CM9 as well as AOKP are AOSP based roms by dev teams with different features.
KANG by Adlx based on work of Dhacker, Hashcode, Droidth3ory CM(sources) with fixes by shahulvm, Adlx.xda and me
Download:
Latest KANG from developers Dhacker, Hashcode, Droidth3ory and AOKP(sources)
Download:
Download:
based on the work by shahulvm, Adlx.xda and me
Download:
Installation from the scratch:
- BACKUP your system via Bootstrap
- wipe your phone via MOTOROLA Recovery (System + Data)
- flash
rom (necessary to get BT working) via RSD or with the tool provided
if have the newest bootloader
- enable usb-debugging and installation from unknown sources
- root with your preferred method
- install
- wipe data, cache, dalvik-cache and format system (THIS IS NECESSARY!)
- flash your preferred rom
-(flash the patch when you install AOKP)
- flash Gapps before first boot
- reboot into ICS :)
- set APN manually in network menu
More, like optional on screen buttons, etc. to come soon...
  • Mickey_J and Ramdanih like this
#2 spryte
spryte
  • 28 posts
Posted 03 March 2012 - 06:36 PM
Changelog by me:
03.02.2012:
- updated gApps
02.03.2012:
- data fixed with fixes by shahulvm, Adlx.xda and me
- IMEI, IMEI SV now shown
28.02.2012:
- no android.phone error any more
- no unknown sim error any more -> better compatibility
- network status under settings is now shown as connected
- (for me) internet worked after entering and saving APN
#3 mgarney26
mgarney26
  • 116 posts
  • Twitter:mgarney26
  • Locationmobile alabama
Posted 03 March 2012 - 09:54 PM
this wont work on a cdma phone will it?
#4 Ramdanih
Ramdanih
  • 35 posts
  • Twitter:Ramdanih7
  • Google+:Ramdanih
  • LocationIndonesia
Posted 04 March 2012 - 07:41 AM
This is awesome ROm for GSM version..
Thx to all developers.. ;)
#5 spryte
spryte
  • 28 posts
Posted 04 March 2012 - 08:52 AM
This is the port from the roms in the CDMA section in this forum, you can use these versions.
#6 Razroid
Razroid
  • 80 posts
  • LocationSingapore
Posted 19 March 2012 - 03:01 AM
erm, bootstrap is not working for me? i get stuck on the dualcore tehcnology screen when i press reboot recovery, help please D: im on gsm btw
#7 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 19 March 2012 - 09:52 AM
Nice job man, thanks for the hard work.
No one cares where this was sent from
:-D :-D
#8 Mickey_J
Mickey_J
Posted 22 March 2012 - 02:34 PM
just got AOKP installed, so far so good :)
muchos kudos to everyone involved!
maybe include the direct root for 2.3.6 link in op?
#9 Mickey_J
Mickey_J
Posted 24 March 2012 - 04:36 PM
i've flashed aokp two times now, did excactly as instructed (+ frasertags ics root & bootstrap_v2) boots up fine after install, but then it bootloops when i reboot :/ and keeps rebooting till i reflash 2.3.6, even after i hold vol down + power:/
zup? :(
#10 Razroid
Razroid
  • 80 posts
  • LocationSingapore
Posted 24 March 2012 - 09:14 PM
you need to flash the patch+gapps too, you also needa wipe cach,factory reset and format /system
#11 Arsic
Arsic
Posted 25 March 2012 - 06:09 AM
So can I not flash this on my 651.73.250 LATAM RETAIL en.BR (originally the Canadian Rogers ROM and there were no other fastboot files). The ROM provided here looks like it's EU?
#12 Razroid
Razroid
  • 80 posts
  • LocationSingapore
Posted 25 March 2012 - 06:23 AM
it will be better if you could fastboot over to EU to make sure installation passes, i heard BR had a different kernel signature
#13 Mickey_J
Mickey_J
Posted 26 March 2012 - 03:43 PM
tried flashing aokp again. It boots up nicely directly after flashing, but again it enters the seemingly infinite boot upon rebooting.
randomly left it booting last night and woke up into ics :) but then there were no keyboard to enter the pin with..
also cm9 wont boot -.-
- installed both roms from scratch 2.3.6
- in cwm: wiped data/factory reset, wiped cache, wiped dalvik, then formatted /system
- flashed the rom (+gsm patch when flashing aokp)
- then installed the gapps zip (does this even matter for booting?)
will the gsm patch work with gummy 0.9.0 or any cdma gingerbread roms?
thanks you spryte for all your(and everyone else's) hard work, hope you eventually will get this working smoothly :)
#14 Razroid
Razroid
  • 80 posts
  • LocationSingapore
Posted 26 March 2012 - 09:59 PM
yes, the patch works with gummy, as for cm9, you might wanna try flashing the patch too, the patch might not work with all roms but i can confirm that it works with gummy
  • Mickey_J and Furthestprism like this
#15 rlex
rlex
Posted 07 April 2012 - 11:13 AM
I always see only two bars no matter how good signal is. However i can see edge/hsdpa and other network types. Bug?
BTW, does razr have HSPA+? Because i _know_ there is HSPA+ coverage, but i see only "H" network - when my honeycomb tables shows "H+"
#16 B.L.E.A.K
B.L.E.A.K
  • 64 posts
Posted 26 June 2012 - 02:29 AM
same here...the signal has only two bars..but it is by far the best ROM...I am making one ROM from our RaZr taking everything from Galaxy Nexus ROM...lets c how it turns out... :)
#17 B.L.E.A.K
B.L.E.A.K
  • 64 posts
Posted 12 July 2012 - 10:34 PM
Is there a patch that works with ICS kernels??
#18 dtrail
dtrail
  • 94 posts
Posted 14 July 2012 - 03:32 AM
nope, not yet. But the latest ICS gives multi roaming functionallity to our Razr (global mode). If upcoming roms are compiled to the latest ICS base rom, we don't need an patch anymore..
  • B.L.E.A.K likes this
#19 B.L.E.A.K
B.L.E.A.K
  • 64 posts
Posted 14 July 2012 - 11:27 PM
But there is a catch...The multi-roaming functionality will and can be used if the phone boots. I tried flashing the INFEKTION ROM and it didnt even boot. Was stuck at the splashscreen logo...and to install a CDMA ROM you need safestrap...again something that is incompatible with XT910s...lots of hurdles even after we sort the patch issue.
#20 kevinarjun
kevinarjun
  • 11 posts
Posted 23 July 2012 - 05:50 AM
razr gsm ics safestrap is released on rombot.droidhive.com...but dunno if it will work
Also tagged with one or more of these keywords: ICS, AOKP, CM9, GSM
