[Rom][GSM/CDMA][Razr][Jb] Rage Rom v2.8 (4/7/2013)
14 replies to this topic
#1 Guest_BDH_*
Guest_BDH_*
Posted 10 March 2013 - 07:28 PM
RAGE ROM
The BEST stock ROM, made by one of the most popular devs here! :)
ONLY FOR THE JB 98.72.16 (OTA Version)
noname81 - LMT Launcher (Pie Controls)
prstorero - gps toggle fix
KrYpToNiTe - 1% battery and toggles
Nitro - original toggles
andlaw - power menu mod (reboot menu)
tomtreas - sending me a system dump :)
wacocapretto - tester & screenshots
hascode0f
sparkyman
dhacker
vtwinbmx
Gerland
Extirpate
I am not responsible for your phone imploding on itself or dividing by 0 or starting thermo-nuclear war with North Korea!
Everything
All bugs fixed in v2.3
Goo Manager Support (OTA Push Notifications)
Fully Deodexed
Super Debloated
Full init.d support
PIE Controls
Fully Themed Messaging App
New wallpaper (thanks to wacocapretto)
Battery Saver init.d tweaks
Koush's Superuser App
1% Battery Mod
Notification Pulldown Toggles baked in
Gapps baked in
Added Apex Launcher
Added Ad-Free
Added Apollo Music Player
Extreme build.prop tweaks
Increased Dalvik VM Heap Size
Disabled Kernel Logging for speed
"To-Do" List:
Center Clock Mod
You Must Be On The Jelly Bean Kernel 98.72.16 To Flash This Rom!!!
IF YOU FIND THAT TEXTS OR MMS AREN'T SENDING, GO TO THE DIALER AND ENTER *#*#4636#*#*, THEN SELECT "PHONE INFORMATION" SCROLL DOWN UNTIL YOU SEE THE WORDS "SELECT PREFERRED NETWORK" (they're there, trust me). MAKE SURE THE OPTION BELOW THAT IS SET TO "LTE/CDMA/EvDo" then go back to your System Settings and toggle Airplane Mode on then off. (thanks to satman80 and waco for the find :)
Download:
CDMA Rage Rom v2.8 (301 MB)
Download:
UMTS (GSM) Rage Rom v2.8 (315 MB)
Activate ANY ROM Slot
Go into SafeStrap (3.07 or 3.11)
Delete Rom Slot 1
Recreate Rom Slot 1
Wipe "system"
Factory Reset
Wipe "cache"
Wipe "Dalvik Cache"
Flash ROM
Reboot
Profit!
OLDER VERSIONS:
Rage Rom v2.7:
Rage Rom v2.6: NON-WORKING BUILD
Rage Rom v2.5:
Rage Rom v2.4:
Rage Rom v2.3:
Rage Rom v2.2:
Rage Rom v2.1:
Please take a second to click the "Like" Button!!
  • jcontrera87, maxi_risso, Sedariya11 and 7 others like this
#2 Guest_BDH_*
Guest_BDH_*
Posted Image Posted Image
#3 Guest_BDH_*
Guest_BDH_*
Posted 10 March 2013 - 07:29 PM
//Changelog\\
(4/7/2013)
Supporting UMTS (GSM)
Fixed Goo Manager Still Reporting An Update After Flashing The Latest Version (CDMA)
Fixed updater-script not installing /data/app packages (CDMA / GSM)
(4/1/2013)
Reverted to Stock Moto Lockscreen
Cleaned up build
Updated build.prop
(4/1/2013)
Moved LMT Launcher (PIE Controls) to /data/app
Added Goo Manager for OTA Push Notifications / App Downloads
Updated build.prop to reflect Goo Manager downloads
(3/30/2012)
Added PIE CONTROLS (To use PIE Controls, open app drawer and go to LMT Launcher, then select (Start/Stop TouchService)
Fully Themed "Rage" Messaging App
(3/26/2012)
Loopy Smoothness Tweak
AOSP JB Lockscreen
Full init.d Support
Allow full screen rotation
Custom Lockscreen Ring
Removed Boot-up Sound
Custom "Low Battery" Text
(3/24/2013)
Fixed ALL issues
Updated build.prop
New wallpaper (thanks to waco!)
(3/16/2013)
Updated Apex Launcher to 1.4.4
Fixed Reboot Menu(thanks to andlaw :) )
Fixed GPS Toggle FC (thanks to prstorero)
(3/13/2013)
Added 1% battery mod (blue battery, white text)(thanks to kryptonite)
Added Notification Pulldown Toggles (thanks to kryptonite)
Added Power Menu Mod (Reboot Menu)(thanks to andlaw :) )
(3/10/2013)
Updated base to Jelly Bean Soak Test version
Removed all themeing
(1/17/2013)
Notification Toggles
Enabled Lockscreen Rotation
Themed Toggles
Themed Signal Icons
Themed Battery Icon
Themed Wifi Icon
Themed Power Menu Mod Icons
Themed Lockscreen
Custom "Rage" Unlock Button
Custom "Rage" Default Wallpaper
Themed "4 Bar" Signal Icons
Themed "Verizon Wireless" Pulldown Logo
Themed Clock & Date In Notification Pulldown
Themed "Blue Bar" In Notification Pulldown
Themed Clock In Statusbar
Themed over 300 Other Various Icons In SystemUI
(1/10/2013)
Power Menu Mod (Reboot)-------- screenshot in post 2
1% Battery Mod----------------------- screenshot in post 2 (thanks to vtwinbmx)
Enabled All Screen Rotations
New Default Wallpaper (RAGE) (Not sure how to set it yet but it's in there.)
(1/7/2013)
Initial Relase
Fully Deodexed
Extremely Debloated
Added No-Frills
Added Power Toggles
Added Apex Launcher
Added Ad-Free
Added SMSFlash
Implemented No-Frills and Power Toggles into Settings Menu
#4 Guest_BDH_*
Guest_BDH_*
Posted 10 March 2013 - 07:33 PM
ENJOY!!!!
#5 Guest_BDH_*
Guest_BDH_*
Posted 13 March 2013 - 08:10 PM
GSM Version updated to v2.1!!!!!!
Please check Post #3 for changes!!!!!!
#6 xtam
xtam
Posted 14 March 2013 - 08:15 AM
I know this is probably time consuming and hard but could you make another version of this rom, compatible with this kernel:
JB 982.124.14.XT910.Vodafone.en.EU
available here
or here
If yes - ok, if not -ok, just small suggestion... for european users, but i do not insist on it.
thanks anyway for your work:)
#7 Guest_BDH_*
Guest_BDH_*
Posted 16 March 2013 - 09:34 PM
Rage Rom updated to v2.2 and the link is LIVE!!!!!!!!!!
Check Post#3 for changes :)
#8 Guest_BDH_*
Guest_BDH_*
Posted 07 April 2013 - 11:40 AM
ROM Updated to v2.8!!!!!!!!!!!!!
#9 linxuan727
linxuan727
Posted 26 April 2013 - 06:50 PM
Where is 3.0?
#10 Guest_BDH_*
Guest_BDH_*
Posted 26 April 2013 - 07:28 PM
The GSM build is no longer supported. I cannot support GSM because I know nothing about it. Only CDMA builds. Sorry!
#11 linxuan727
linxuan727
Posted 26 April 2013 - 11:01 PM
What a pity! Anyway, Thank you very much.
#12 radu
radu
  • 5 posts
  • LocationRomania
  • Current Device(s):RAZR MAXX GSM
Posted 29 April 2013 - 12:39 PM
European version here as well, and GSM :|
No worries, but a pity indeed... wish I could try this one.
#13 jerigar
jerigar
Posted 31 May 2013 - 04:48 PM
Can I install this rom with rogers kernel using the Boot Menu Manager?
#14 lordjobo
lordjobo
Posted 18 June 2013 - 08:48 AM
I've tried the text fix and I still can't send :(  any other suggestions?
#15 qq674930949
qq674930949
Posted 28 February 2015 - 06:48 AM
ROM很好看  感谢楼主             (Translated) ROM look great thanks landlord
