ROM Compatibility Flasher Tool! Switch between Jellybean Kernels with ease.
133 replies to this topic
#121 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 06 June 2013 - 11:45 AM
I have no idea what I'm doing wrong but here is what happens:
I thied the utility the first ti8me using AP Fastboot instruction - It said all was good, rebooted phone but I still don't have the .16 kernel
I then tried the ADB selection - Found device, Sending 'boot' writing 'boot' rebooting . . make sure to install a jellybean Official . . .   Whne the phone reboots I still have the .8 kernel.  What am I doing wrong?
You have to fastboot the .16 Kernel then go directly to safestrap and install a rom that runs on that Kernel and boot that up.
#122 mik32tall
mik32tall
  • 9 posts
  • Current Device(s):droid razr
Posted 29 June 2013 - 03:46 PM
does anyone have the driver file for this? i downloaded the utility and cant find the drivers file in the one i downloaded from here someone plz help. im on 98.72.16 and want to go back to 98.72.8 so i can try the jellywiz rom
#123 johnthehillbilly
Posted 29 June 2013 - 04:05 PM
Here are the latest Motorola drivers ...
32 bit ...
64 bit ...
Should help you out ;)
  • FastKatt likes this
#124 mik32tall
mik32tall
  • 9 posts
Posted 30 June 2013 - 02:21 PM
thank you so much i was going crazy trying to find it
  • johnthehillbilly likes this
#125 mik32tall
mik32tall
  • 9 posts
Posted 30 June 2013 - 02:34 PM
im still having truble. im on the ota .16 jb and am trying to go back to .8 ive downloaded the utility and now the drivers and it still wont work for me i dont understand what im doing wrong. if anyone could help it would be great thank you
#126 johnthehillbilly
Posted 30 June 2013 - 02:38 PM
So what's it not doing? :) .... is the computer not recognizing you phone...
Is the utility "stalling" ....
Is it running thru but not installing the proper kernel....?
What version of windoze are you using? :)
#127 mik32tall
mik32tall
  • 9 posts
Posted 30 June 2013 - 02:41 PM
when i try to run the utility it says moot fastboot is not recognized as an internal or external command
#128 mik32tall
mik32tall
  • 9 posts
Posted 30 June 2013 - 02:43 PM
and im on windows 7.
#129 johnthehillbilly
Ok.... it sounds like you have not extracted the utility completely..... use WinZip or winrar to extract the utility.... then run the .bat file from the folder :)
#130 mik32tall
mik32tall
  • 9 posts
Posted 30 June 2013 - 02:47 PM
i used winrar and extracted the zip to a folder on my desktop and when i open the utility and hit enter it comes up for a sec n closes
#131 mik32tall
mik32tall
  • 9 posts
Posted 30 June 2013 - 02:55 PM
do you have a differnt download link for the utility? ive never had this much truble b4
#132 cmh714
Posted 01 July 2013 - 03:55 PM
Try this method instead, it doesnt require a PC so in that sense its "better"
#133 MaximizedRazr
MaximizedRazr
  • Twitter:xXTee_GarXx
Posted 12 August 2013 - 03:58 PM
For some reason it didn't work this way for me. I ran the utility in AP Fastboot, then installed ROM, got stuck in bootloop every time. But when I installed the ROM first then ran utility it worked fine, Running batakang now. Maybe I'm just an idiot and forgot if I was on leak or ota.
#134 cmh714
Posted 12 August 2013 - 04:27 PM
if your running batakang then your on the xmas eve leak
