[Rom] Motoblur 98.72.16 (Stock Deodexed)
84 replies to this topic
#1 mhous33
mhous33
  • 480 posts
Posted 07 March 2013 - 09:13 PM
the op was made when there was only a system dump of 98.72.16. now that the fxz is out, you can easily make your own rom base...
get the fxz here:
get hashcode's original motoblur base here:
 (motoblur-98.72.8-XT912.zip)
get koush's superuser here:
 click "more", there is a download link
extract system.img from the fxz and then extract the contents of system.img (i use winhex) and put them in directory named "system"
add Superuser.apk to /system/app
add su binary to /system/bin (you can put it in /system/xbin but you'll have to edit the updater-script line that sets permissions for it)
extract the META-INF folder from hashcode's motoblur base and delete the 3 files "CERT.RSA" "CERT.SF" and "MANIFEST.MF"
zip the system directory and the META-INF directory (i use 7-zip with ultra compression), naming it whatever you like.
for extra credit, you can sign the package; or you can just disable signature verification in recovery.
  • OldBaldy, dubsx, disturbed58 and 14 others like this
#2 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 07 March 2013 - 09:21 PM
thanks to hashcode for safestrap and the safestrap base
thanks to darkmiasma for the system dump
thanks to koush for superuser
You got this done quick, don't need to do my own now. :)
  • thefathindu likes this
#3 mhous33
mhous33
  • 480 posts
Posted 07 March 2013 - 09:24 PM
yeah it should work, i don't own a razr to test with, so not 100%. let me know if you have any issues...
  • papanut likes this
#4 kenbrownstone
kenbrownstone
    noobie on tha boobie
  • 314 posts
  • Twitter:@Brownvols
  • LocationTennessee
  • Current Device(s):droid razor xt912
Posted 07 March 2013 - 09:32 PM
What is this?
**** SIGNATURE MADE BY: RINKLE MCBALLY ****
#5 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 07 March 2013 - 09:34 PM
What is this?
Title says it all dude...
  • andlaw likes this
#6 kenbrownstone
kenbrownstone
  • 314 posts
  • LocationTennessee
Posted 07 March 2013 - 09:35 PM
So I can flash just like other ROMs?
  • justin75 and Ryan303 like this
#7 ryankliber
ryankliber
  • 103 posts
Posted 07 March 2013 - 09:39 PM
Links don't work for me
#8 kenbrownstone
kenbrownstone
  • 314 posts
  • LocationTennessee
Sorry I just don't want to mess up and lose root or brick it
#9 kenbrownstone
kenbrownstone
  • 314 posts
  • LocationTennessee
I just got done loading one
#10 mhous33
mhous33
  • 480 posts
Posted 07 March 2013 - 09:42 PM
just tested the links, working fine for me...
#11 ryankliber
ryankliber
  • 103 posts
Posted 07 March 2013 - 09:43 PM
Is it more than 177 bytes? That's all I get..
#12 kenbrownstone
kenbrownstone
  • 314 posts
  • LocationTennessee
Posted 07 March 2013 - 09:44 PM
Change to another downloader Its 402 mb
#13 mhous33
mhous33
  • 480 posts
Posted 07 March 2013 - 09:49 PM
i added approximate sizes and md5 hashes to the op so you can verify your download...
#14 kenbrownstone
kenbrownstone
  • 314 posts
  • LocationTennessee
Posted 07 March 2013 - 09:57 PM
What's difference in the two. Sorry don't know what dioxide means yet I'm new..lol
#15 mhous33
mhous33
  • 480 posts
Posted 07 March 2013 - 09:59 PM
#16 ryankliber
ryankliber
  • 103 posts
Posted 07 March 2013 - 10:01 PM
Tried opera browser since it has its own downloader, and it almost instantly fails. Home Internet is out too so if a mirror could be tossed up I would greatly appreciate it.
#17 kenbrownstone
kenbrownstone
  • 314 posts
  • LocationTennessee
Posted 07 March 2013 - 10:05 PM
I used opera and it says it was 402 mob and completed load
#18 ryankliber
ryankliber
  • 103 posts
Posted 07 March 2013 - 10:07 PM
Rebooted to try again and the file is busy
Edit:working now tethering to my pc
#19 kenbrownstone
kenbrownstone
  • 314 posts
  • LocationTennessee
Posted 07 March 2013 - 10:55 PM
Mine loaded just fine but got a security failure and tells me to turn off . something about modules
#20 mhous33
mhous33
  • 480 posts
Posted 07 March 2013 - 11:12 PM
sorry, can't help as i don't have a og razr.
