I ran the unbrick tool an then ran 1.9
Ok try this, as it was what I did:
Unbrick again, then use the 1.82 tool. to laydown the ICS/Christmas Leak
Posted 09 March 2013 - 06:10 AM
Posted 09 March 2013 - 06:15 AM
Roger thatOk try this, as it was what I did:
Posted 09 March 2013 - 06:20 AM
Posted 09 March 2013 - 06:28 AM
I never took the Christmas leak. Do you think that it would benefit me to do a clean install of ICS via Matt's V1.82 first and then use Matt's V1.9 to go to Christmas leak and finally Christmas to OTA?
Posted 09 March 2013 - 06:36 AM
Posted 09 March 2013 - 06:47 AM
I'm having problems rooting my phone using the utility below any ideas what I am doing wrong
Posted 09 March 2013 - 07:04 AM
It cant hurt to do that, if you are having problems??
You are still on ICS??
I had issues from some non moto stuff install when I was on ICS, and I had to flash ICS, before I could do the Christmas Leak back in December.
Posted 09 March 2013 - 07:05 AM
This sounds exactly like something I read, looking for it but cant find yet. It said when trying to Root, make sure "ADB.EXE" is not running in the background and and hit ctrl/shift/esc to see the task list to see if it is running.
Plus I used the Root tool in Matt's 1.9 tool, and you run it with the phone booted up normal
EDIT - Found it
Just scroll down to 2. How to Root using New JB Exploit
Posted 09 March 2013 - 07:09 AM
Yes I am still on ICS. I am rooted but haven't gone JB as I was waiting for OTA.
My phone tried to take the christmas leak/OTA but it failed I had frozen apps in Titanium Back Up and I am not certain if that is why the Christmas leak/OTA failed or not.
Thus I tought to do a clean ICS then go to JB
Posted 09 March 2013 - 08:15 AM
Not sure what's going on. I cant get anything to boot (other than fastboot)Ok try this, as it was what I did:
Posted 09 March 2013 - 08:36 AM
After running 1.82, I reboot and get Andy with the spinning molecule thing in his middle but it goes black again
Posted 09 March 2013 - 09:17 AM
Something is still wonky Satman. I ran junbrick and 1.9 util (option 1) and the update still wont take (error 7). DamnYour bricked because you used the 1.82 tool for ICS only.. use jbunbrick if still fail to load JB OTA from SD card, then used the 1.9 utility and you should be good to go
NOTE: to all, 1.82 is for ICS ONLY you cannot go back from any JB update to ICS or you will BRICK
Posted 09 March 2013 - 09:32 AM
Posted 09 March 2013 - 09:36 AM
And nothing will boot
Also, when I try to reboot after running 1.9, i get a device not recognized error on the laptop and the phone shows E:\ mount errors
Posted 09 March 2013 - 09:47 AM
Posted 09 March 2013 - 10:02 AM
Posted 09 March 2013 - 10:43 AM
Posted 09 March 2013 - 01:09 PM
Posted 09 March 2013 - 01:59 PM
Posted 09 March 2013 - 02:56 PM
