New (JB OTA) Help for Beginners
148 replies to this topic
#1 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 07 March 2013 - 12:16 PM
POPULAR
Before we begin make sure you know if your on ICS 6.16.211 (ICS 4.0.4 Official OTA Software) Or (JB LEAK from xmas)
  • FULL Battery, Do not attempt anything without a full battery
  • What Tools do I need? Get all our tools in order first also before you begin..
  • VERY IMPORTANT! Make sure your on Unsafe Side (STOCK Side) then Disable Safe Strap Before you Uninstall it
Backup your Pictures, Music, etc.
  • Connect phone to your PC and place it in Mass Storage Mode then copy and paste all the files you wish to save to a safe location of your choice. (Computer/Network/USB stick)
  • Unplug phone from PC
JB OTA Tools & How To's & Tools
_____________________________________________________________________________________________________________________________________________________________________________
New Soak OTA locations & Installations
Method 1
"To Be Flashed Over 6.16.211.XT912.Verizon.en.US" (This will Update you from ICS 6.16.211 ICS 4.0.4 Official OTA Software)
"To Be Flashed Over 98.72.8.XT912.Verizon.en.US" (This will update you from the Leak OTA from Xmas)
Note: Any and ALL Updates will always go on your SD Card as a .Zip File..
While in “Mass Storage” Copy and Paste to SD CARD
Don't Forget to Save ROOT, Use Voodoo OTA root keeper, Root Temp Unroot 4 times!
How Do I get into AP fast boot and Recovery?
  • Turn off the phone
  • Hold BOTH VOL + and VOL – then hit POWER
  • Choose either AP or Recovery hit the VOL + key to enter
  • To enter Into Recover after you have selected “Recovery” Press both VOL+ and VOL- at the same time.
The Update to JB Blur_Version.X.X.XXX.T912.Verizon.en.US.zip
  • Reboot phone into Recovery (See How Do I get into AP fast boot and Recovery?)
  • Install/apply Update from External Card, Say yes if asked
  • Be patients This may take up to 10 min
Having Problems with method 1? Just use Matts 1.90 utility
<----- One Stop Shop brings you from ICS 4.0.4 Official OTA Software to JB Blur_Version.6.16.211.XT912.Verizon.en.US.zip
Why Can't I use 1.82 utility going from any JB version????? Because its ICS ONLY you Will Brick!!!
  • VERY IMPORTANT! Make sure your on Unsafe Side (STOCK Side) then Disable Safe Strap Before you Uninstall it!
DroidRazrUtility1.90 Howto
  • Extract the entire utility to your desktop, open “DroidRazrUtility/Drivers. Install 64 bit or 32 bit (Depending on your OS). When finished reboot your PC
  • Put phone in AP Fastboot. (See: AP FastBoot how to)
  • Run “DroidRAZRUtility.bat”
    , when finished, let phone boot. Be patient, this may take some time
I lost Root How do I root again?
"go to Settings>Applications>Smart Actions and click "Uninstall updates".
With Matt's Utility 1.90
or
How to Root using New JB Exploit
Without Matt's Utility?
  • Put phone in MTP Mode, Go into settings and check off Unkown Sources, USB Debuging, Allow Mock Locations
  • Make Sure You did NOT install any updates with Smart Actions! Uninstall any if so, settings, apps, smart actions.
  • Open CMD.exe again (See Screen shot) (Why run from CMD?, becuase you will get ADB wrong Version notice, Root will FAIL)
  • Follow the Instructions to the T when you start the root exploit!
  • Let the phone reboot and do its thing, remember when asked do what it says Exactly or (Root will fail)
You should now be on Jelly Bean, Depending on what option you took for Rooting You may now Install Safe Strap and Use Roms
Note: as of 3-8-2013 so far for JB ROMS you can use this method (complements of Matt)
Note: If you get FC with Safe Strap, 100% chance your not rooted, DL root checker from play store.
This is a Work in Progress but the basics for now are here I will be making adjustments ASAP
If this helped you, Please take the time to say thanks and or click like so I know this has helped..
Edited by satman80, 12 March 2013 - 11:08 AM.
  • cvhovey, mugsy77, mhotovec and 24 others like this
Site Rules and Guidelines
#2 grn4frk
grn4frk
  • 14 posts
  • Twitter:offenbergerab
  • Google+:113193353093127849150
  • LocationCharlotte, NC (Live in Boone, NC for school)
Posted 07 March 2013 - 01:09 PM
I hope this is the right place to ask this..if not, my apologies.
I'm trying to install this on my buddy's 100% razr (non-rooted), I get into recovery, apply update from SD, click on blur file and instead of asking the usual Yes or No it displays a menu
neta-inf/
patch/
preinstall/
recovery/
system/
Does anyone have an idea of what's going on? Would greatly appreciate it.
#3 aktrazer
aktrazer
    SMod/News Team Leader
  • 537 posts
  • LocationGreensboro, NC
  • Current Device(s):Smasung Galaxy Note 2, ASUS TF700T
Posted 07 March 2013 - 01:11 PM
neta-inf/
patch/
preinstall/
recovery/
system/
Are you coming from ICS (.211) or the JB leak (.8)?
#4 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 07 March 2013 - 01:13 PM
That looks like the inside of the zip file. Is the zip file unzipped on your sd card?? If that's not it you should be choosing "choose zip from SD card" Its possible you are choosing apply update so it is looking for an update. zip file.
#5 aktrazer
aktrazer
  • 537 posts
Posted 07 March 2013 - 01:16 PM
I agree. I think you unzipped it.
#6 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 07 March 2013 - 01:35 PM
Updated again...
#7 ksu1971
ksu1971
Posted 07 March 2013 - 05:31 PM
Forgive the noob question but when you say disable safe strap are you saying to uninstall it?
#8 Memnoch73
  • 5,016 posts
Posted 07 March 2013 - 05:33 PM
Yes. Uninstall from within the safestrap app
#9 Kyle06
Kyle06
  • 37 posts
Posted 07 March 2013 - 06:15 PM
So before I go off the deep end :P
To install the soak release all I have to do is put it on my sdcard
protect my root with voodoo
Then boot through recovery and flash the zip?
#10 Memnoch73
  • 5,016 posts
Posted 07 March 2013 - 06:16 PM
You got it. As long as your on stock. If not you may have to do option 1 on the utility first
#11 Kyle06
Kyle06
  • 37 posts
Posted 07 March 2013 - 06:20 PM
Thank you sir, just wanted to make sure going to let my battery charge alittle more and waiting for the update to be downloaded
#12 oxyd325
oxyd325
Posted 07 March 2013 - 06:31 PM
Another newb question:
So I reverted back to .211, rooted, then protected root and unrooted using voodoo. Will my phone still update if busybox and superuser is installed?
#13 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 07 March 2013 - 07:48 PM
Yes
  • oxyd325 likes this
#14 oxyd325
oxyd325
Posted 07 March 2013 - 07:49 PM
Thank you, sir
#15 cmorty72
cmorty72
    Breaking, bending, and fixing things
  • 133 posts
  • Twitter:z00mer
  • Google+:Christopher
  • LocationIn front of my p.c. or on my Razr HD Maxx
  • Current Device(s):Moto Razr Maxx HD 32G
Posted 07 March 2013 - 09:36 PM
n00b question:
My Razr is completely stock ICS. Downloaded 4.0.4. OTA update onto SD. Went into recovery and located the file which I'm guessing is:
Blur_Version.6.16.211.XT912.Verizon/
When selected, it brings me to ../
Is there something I'm missing here?
USN 1996-2007, OS1 (SW/AW/VBSS)
#16 DrDiff
DrDiff
  • 93 posts
  • Twitter:@DrDiff952
  • Google+:DrDiff
  • LocationNorthWest Indiana
Posted 08 March 2013 - 03:09 AM
Thanks satman80!
#17 T3T3droid
T3T3droid
    D3v3lop3r/Th3m3r/Machin3
  • 1,115 posts
  • Google+:t3t3droid@gmail.com
  • LocationConnecticut
  • Current Device(s):Droid Bionic, Droid Razr M, SGS4
Posted 08 March 2013 - 03:26 AM
Very thorough thank you sat! Someone asked me if dual boot will still work with this but I assume it has to be updated with the new boot image correct?
Sig by Bama
If you like our work please consider
Donating towards
Phones and Site costs :D Thanks!!
#18 DrDiff
DrDiff
  • 93 posts
  • Google+:DrDiff
Posted 08 March 2013 - 05:08 AM
I saw on
that this soak test has became OTA. Maybe that is why the servers are going nuts!
#19 chefed24
chefed24
  • 64 posts
  • Twitter:@EdSadler
  • LocationAustin Texas
Posted 08 March 2013 - 06:20 AM
This was easy as hell. Loving the Jelly, smooth as butter. Thanks to everyone that participates in this site it really is the best go to site.
  • dtomlin likes this
#20 ksu1971
ksu1971
Posted 08 March 2013 - 06:26 AM
Ok I have gotten as far as installed the Leaked update. Now when I try to boot into recovery I get as far as the Droid Bot laying down but when I push the both the volume buttons it never goes beyond that to choose the update from Leak to soak. Any ideas?
