Hey so i rooted my gsm (Retail.en.eu) razr razr yesterday and tried to flash arctic on it a few times.
it never worked i cant figure the reason why but anyways the last time i tried it i used the restore option of safestrap in order to restore to the backup i made earlier this morning now i am stuck on:
Invalid Flash Mode (S) (boot failure)
0A.6c
Battery OK
OK to program
Transfer Moder
Usb Connected (got it plugged in right now)
Invalid CGOTC (CG: webtop): Invalid SP Data
Invalid CG HAB (CG: webtop, status: 0x004E
Invalid CG OTV (CG: webtop
As far as i could figure while readign the other forum posts that i bricked my phone and somehow have to flash new fastboot files.
problem is that i am sor of new to all this and besides my lack of knowledge of terms concerning software i also dont get everything you posted on other threads concerning Unbricking since i am not a native speaker...
i apologise if this is off topic :/
i would really apreciate some advice on how to flash the fastboot files and if i can use the ones from the other threads since i am on gsm.
okay really hope you guys can help me once more
thank you
Ap Fastboot Invalid Flash Mode (S) (Boot Failure)
kutips
, Feb 29 2012 06:21 AM
6 replies to this topic
Posted 29 February 2012 - 06:21 AM
Posted 29 February 2012 - 06:27 AM
you're not trying to flash Arctic in the recovery that came on the phone are you?
Sent From Optimus Prime
:-D :-D
Posted 29 February 2012 - 06:34 AM
no i was using safestrap but i dont get into the safestrap menu anymore
if thats what you mean...
Posted 29 February 2012 - 06:58 AM
I am pretty sure we have GSM fastboot files in the GSM section.
You need that, to download the latest Moto drivers on your comp, and a program called RSD Lite.
When I get to work I'll finish the instructions but for now I gotta go!
:-D :-D
Posted 29 February 2012 - 07:16 AM
So far i couldnt manage to find fastboots for gsm i already downloaded + installed motohelper + rsdlite since i found some instructions of matlgroff .
i just tried to use to matlgroffs utility for windows to restore but it doesnt seem to work :/ hopefully i ll manage to find some fastboot files
i found some roms on the website of eternityproject but if i got it right thats not what i am looking for
thanks for helping me hopefully i ll get this fixed
Posted 29 February 2012 - 09:02 AM
fixed ty for the help
Posted 05 January 2015 - 01:29 AM
how to charge battery
