Error Transferring Within APKs
7 replies to this topic
#1 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
  • Twitter:@usmcamgrimm
  • LocationMassillon, OH
  • Current Device(s):VZW G3
Posted 02 March 2013 - 10:28 AM
For some reason, after I make edits to framework-res and I try to drag them from the new apk to the original, 7zip gives me an error message "not implemented". Tried with winter and it said the file was corrupted. Started over with a new copy of the framework, same issue. The only changes I made were a couple of images and some XML colors.
The framework compiled with no errors. This is the only apk I've had this problem with.
#2 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 03 March 2013 - 11:13 AM
Has anyone seen this error? Anyone know what causes it? Searched on Google but haven't a specific cause yet.
#3 Guest_BDH_*
Guest_BDH_*
Posted 03 March 2013 - 11:22 AM
Have you checked the permissions of the zip file to make sure you can edit it?
#4 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 03 March 2013 - 11:42 AM
I thought something like that might cause it, but no I haven't checked permissions on the zip.
I also thought it might be something in the way 7zip is set up.
#5 Guest_BDH_*
Guest_BDH_*
Posted 03 March 2013 - 12:18 PM
Could be. You should have permission to edit the zip but you never know i guess. Kind of has me baffled as well.
#6 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 03 March 2013 - 03:43 PM
It decompiled and recompiled fine, so I wouldn't think it would be a permissions issue.
#7 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 03 March 2013 - 04:40 PM
Justchecked the permissions for the apk and I do have full permissions to modify the zip
#8 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 03 March 2013 - 06:01 PM
Used VTS to decompile, edit, and recompile. Signed the apk and flashed it. Still don't know why 7 Zip didn't work, but at least I got it with VTS!
Almost....gets stuck in bootloop
Edited by usmcamgrimm, 03 March 2013 - 06:13 PM.
