asking help for an Encryption Unsuccessful error.
Ok so I really gooffed up and installed a program I think it was called Iroot, turned out to be a bad virus, ads, naked pictures, etc. I was trying to delete some of the pre installed programs, well that was a bad idea. So I did a factory wipe/reset erase everything goes well phone boots up, its back to normal, while setting up goolge, it started syncing my account, did not want that, accidently hit the power off button, now I have no phone, it boots up to "Encryption Unsuccessful" hit reset button which does nothing. factory reset 5 times does nothing, been at this for 2 days straight, I have tried rsd lite 6.14 get error message flash failed gpt.bin. so I figure I would try house of moto 4.3 and it did not work. I will post the error message I got from House of moto. PLEASE if anyone can help me I really need my phone, cant afford to buy another one, I dont care about rooting or anything, just want to get my phone working again so I can use it. thanks so much.
dont know if this will be usefull pulled this from rsd.
bootloader version 109b.
technology cdma 1x-evdo
And here is the errors I got when I ran House of moto. I used firmware VZW_XT926_4.1.1_9.8.1Q_39_VQW_CFC.xml which I think is the original stock firmware for the XT926, even took out the "getvar" line. still no go.
sending 'sbl1' (100 KB)...
OKAY [ 0.030s]
writing 'sbl1'...
Failed to erase partition
Failed to flash partition sbl1
FAILED (remote failure)
finished. total time: 0.149s
sending 'sbl2' (126 KB)...
OKAY [ 0.031s]
writing 'sbl2'...
Failed to flash partition sbl2
finished. total time: 0.154s
sending 'sbl3' (512 KB)...
OKAY [ 0.060s]
writing 'sbl3'...
Failed to flash partition sbl3
finished. total time: 0.326s
sending 'rpm' (140 KB)...
OKAY [ 0.031s]
writing 'rpm'...
Failed to flash partition rpm
finished. total time: 0.285s
Flash TZ partition? [y/n]: y
sending 'tz' (192 KB)...
OKAY [ 0.035s]
writing 'tz'...
Preflash validation failed
finished. total time: 0.168s
sending 'aboot' (256 KB)...
OKAY [ 0.040s]
writing 'aboot'...
Failed to flash partition aboot
finished. total time: 0.324s
rebooting into bootloader...
OKAY [ 0.011s]
finished. total time: 0.013s
sending 'partition' (32 KB)...
OKAY [ 0.024s]
writing 'partition'...
finished. total time: 0.159s
OKAY [ 0.028s]
writing 'sbl1'...
OKAY [ 0.031s]
writing 'sbl2'...
finished. total time: 0.175s
OKAY [ 0.060s]
writing 'sbl3'...
finished. total time: 0.360s
OKAY [ 0.031s]
writing 'rpm'...
finished. total time: 0.317s
OKAY [ 0.034s]
writing 'tz'...
finished. total time: 0.186s
OKAY [ 0.040s]
writing 'aboot'...
finished. total time: 0.351s
sending 'boot' (10240 KB)...
OKAY [ 0.790s]
writing 'boot'...
finished. total time: 0.970s
sending 'system' (30720 KB)...
OKAY [ 2.330s]
writing 'system'...
finished. total time: 2.520s
sending 'recovery' (10240 KB)...
OKAY [ 0.790s]
writing 'recovery'...
Failed to flash partition recovery
finished. total time: 1.591s
sending 'modem' (30720 KB)...
OKAY [ 2.327s]
writing 'modem'...
Failed to write mmc
finished. total time: 2.442s
sending 'devtree' (512 KB)...
OKAY [ 0.059s]
writing 'devtree'...
Failed to flash partition devtree
finished. total time: 0.439s
sending 'logo' (1709 KB)...
OKAY [ 0.154s]
writing 'logo'...
Failed to flash partition logo
finished. total time: 0.344s
error: cannot load 'cdrom'
erasing 'modemst1'...
finished. total time: 0.110s
erasing 'modemst2'...
finished. total time: 0.111s
sending 'fsg' (2704 KB)...
OKAY [ 0.224s]
writing 'fsg'...
Failed to flash partition fsg
finished. total time: 0.409s
erasing 'cache'...
WARNING: Choosing yes to this option will WIPE YOUR DATA.
Erase userdata partition? [y/n]: n
erasing 'tombstones'...
finished. total time: 0.113s
rebooting...
finished. total time: 0.009s
Rebooting...
Thanks for using the House of Moto.
Press any key to continue . .
