**fix** Unknown Fastboot Command. (Oem); Phone Connected
42 replies to this topic
#21 prstorero
prstorero
    SuperThemerDevGuy
  • 838 posts
Posted 16 June 2012 - 12:11 PM
i tried deleting the lines and it works through the flash but when it reboots im still in a flash failure mode.
#22 mighkey
mighkey
  • 6 posts
Posted 02 July 2012 - 10:43 AM
Mine too...can't get it to work for anything
#23 mighkey
mighkey
  • 6 posts
Posted 02 July 2012 - 10:50 AM
Mine still doesn't work through flash or reboot past ap
#24 sickenly
sickenly
Posted 07 July 2012 - 07:02 PM
Totally worked for me as well. Thanks guys
#25 chicagonpg
chicagonpg
Posted 14 April 2013 - 06:27 AM
Freakin awesome!! Worked like a charm and I finally got my razr back. Thanks
#26 cakessi
cakessi
Posted 07 May 2013 - 11:42 AM
Thank you sir!  Worked perfectly.  I removed the lines from the .xml manually using Notepad ++.
#27 chubbrock
chubbrock
Posted 18 July 2013 - 07:22 PM
Link is down!!!!
  • luisny likes this
#28 cmh714
Posted 19 July 2013 - 06:04 AM
In the OP are the instructions to edit the file yourself. I know you can do that :)
#29 smca
smca
Posted 04 July 2014 - 04:19 AM
OH my god, your assistance is greatly Apprecriated.
#30 myunlocking
myunlocking
  • Locationxysadfasdf
Posted 17 August 2014 - 09:30 AM
i m stuck here
any idea what to do ?
i just want to update my set from 4.1.2 to 4.4.2
but now stuck on fastboot screen
#31 SamuriHL
  • 44,371 posts
Posted 17 August 2014 - 09:48 AM
Post the contents of your SWDL.txt file in your RSD Lite installation folder.
#32 alexherreraz
alexherreraz
Posted 29 September 2014 - 12:28 PM
Thanks a lot!!! finally i made it work!
#33 optimusolympus
optimusolympus
Posted 01 October 2014 - 06:38 PM
Thanks so much Sir ... but the dropbox link is not working ... any help please sir ... thanks
I really need the fix ... Thanks Sir
#34 rgsgroup2005
rgsgroup2005
  • Twitter:legacytechnow
Posted 30 October 2014 - 03:34 PM
Awesome! I finally was able to flash the 18-8 build over the 18-9 latest OTA update to un-flash this XT894 from 3G Page Plus back to 4G LTE! Thank you so much! You are a life saver! Now my client won't kill me lol. I extracted the XML file and deleted those 2 lines as you said then I replaced the file with the modded one and then ran the RSD Lite 5.9 "Extract Then Flash" option... Easy! I recommend WINRAR for Windows to do this mod. Make sure you deleted your failed extracted folders from earlier before flashing!!!
#35 S3nse1
S3nse1
  • 6 posts
  • LocationIndiana
  • Current Device(s):Motorola RAZR MAXX
Posted 06 November 2014 - 10:11 PM
My RAZR MAXX, like many other people's, suddenly wouldn't ring, speaker phone was silent, etc. Both a Verizon Store and a local phone repair store said things were hopeless. UNLOCKR.com's YouTube video gave me hope - but it didn't pan out until I found your fix.
Thanks so much. What you did here was greatly appreciated.
#36 FareakyGeek
FareakyGeek
  • 29 posts
Posted 31 December 2014 - 10:50 AM
Guys OEM_FIX.rar no download Page 404 error please help :(
#37 Young_Chung
Young_Chung
Posted 12 March 2015 - 05:10 PM
#38 Feturi
Feturi
Posted 01 July 2015 - 01:09 PM
I am not clear about where to get these two files deleted from. Can someone tell me specifically where to get them and delete same.
#39 cmh714
Posted 01 July 2015 - 01:40 PM
Firstly the 173 FXZ mentioned is ancient. Second if you have this problem, follow the OP and edit the xml file that comes with the FXZ appropriately.
GL!
  • spainter likes this
#40 Feturi
Feturi
Posted 01 July 2015 - 01:53 PM
Ok, i have just dihe scovered that these two lines of OEM are in the firmware text file and i have edited and deleted the two lines, but i am still experiencing the same problem:FAILED FLASHING PROCESS, UNKNOWN FLASH BOOT COMMAND. What do i do next.
