How I got XT926 roms working on my XT925
8 replies to this topic
#1 Coolloser
Coolloser
  • 40 posts
  • LocationCanaduh
  • Current Device(s):Razr HD XT925, Atrix 4G, Nexus 7
Posted 25 February 2013 - 09:35 AM
I had been going through flashing withdrawl due to the lack of roms for the XT925 and decided to play around and see what worked. Installing XT926 roms is no problem with safestrap but there were always thing not quite working; only 3G speed and no wifi being the main ones. I found this thread:
but replacing the two files wasn't enough so I played some more and had success!
Getting LTE: Enter *#*#4636#*#* on the dialer and select "Phone Information" scroll down and make sure "LTE/CDMA/EvDo/GSM/WCDMA" is selected under "Set preferred network type:". DO not change anything else here unless you know what you are doing! DO not change anything else here unless you know what you are doing!
Make sure "Global" is selected under "Network Mode" in your Mobile Network Settings. Now enter your APN manually. BOOM you has LTE. I had to keep resetting from GSM/UTMS to "Global" after a reboot, this is fixed by the build.prop changes and factory reset.
Add or change the following lines:
ro.mot.ds.fastdormancy.disable=true
telephony.lteOnCdmaDevice=0
telephony.lteOnGsmDevice=1
ro.telephony.default_network=9
ro.ril.def.preferred.network=9
ro.mot.eri=0
ro.cdma.home.operator.isnan=0
then I removed every line that had "cdma" in it (except the one above)
Now the default_network setting will not be changed unless you factory reset after and if the rom does not have your apns "on file" you will have to fiddle to get data to work on a reboot. This is fixed by replacing the apns-conf.xml file found in /system/etc/ with one that has your carrier setting or editing the existing one.
Note: I tried doing an advanced data restore through Safestrap/TWRP and the connection on boot issue came back. Restoring with Titatnium worked fine
Getting wifi: you need a root browser for this. Back up your original ones by adding ".bak" to the end of the name. Download the zip attached (no it is not flashable, I don't have that expertise) and extract it to your phone somewhere. Copy the Set1 (cfg80211.ko & wlan.ko) files to /system/lib/modules then copy the Set2 (cfg80211.ko & prima_wlan.ko) files to /system/lib/modules/prima
Fix permissions and reboot. (I don't actually know if all four files are needed, just that it works when they are all there!)
"Wifi still isn't working!?" Compare the permissions of the new files to the old ones (you backed them up right?).
Getting rid of "This SIM card is from an unknown source:" delete VzwPhoneService.apk from system/app
Tested with "Foot Through The Floor", "wWidow" and "fusionHD" with safestrap.
Thanks to:
mattlgroff for the clue that it was possible with his Batakang for Atrix HD release
Cambridge2009 for the hint where to start in their Atrix > Razr thread
droidrzr.com for their sweet roms!
pfak for their build.prop tweaks
Observations:
Everything works flawlessly now!
I am not responsible for you borking this process and by extension your device, always have backups to save yer arse if you do. I have messed things up many times with many devices with no sweat because I consistently backup.
  • zooyork0721, aaki_rocker, hleo114312 and 1 other like this
#2 Kadmus
Kadmus
  • Twitter:FelipsK
  • Current Device(s):Motorola Razr HD
Posted 06 March 2013 - 05:59 PM
Hello! I'm always getting three bars (you know from other topic ;))
Here some screenshots:
Stock 3G:
Nexesque 3G:
Nexesque 2G:
Thank you! =)
#3 Coolloser
Coolloser
  • 40 posts
  • LocationCanaduh
Posted 06 March 2013 - 06:26 PM
Alright, here comes Coolz' endless troubleshooting questions:
Can you post a copy of your build.prop?
Did you do a factory reset after changing the build.prop and apns-conf file?
What carrier are you with?
Why don't you have LTE? (I'm guessing your provider is slow lol)
Is the actual signal strength weaker as well or is it just a cosmetic difference?
What did you have for dinner?
Did you bring me a monkey?
#4 vctrrl
vctrrl
  • Current Device(s):Motorola RAZR HD (XT925)
Posted 28 May 2013 - 04:58 PM
Hey Coolloser,
Right now I have no monkey, but the same problem happens to me. I'm running Inflikted ROM on my RAZR HD (XT925). Signal is the same, but the bars shows less signal. How can I fix it?
#5 Coolloser
Coolloser
  • 40 posts
  • LocationCanaduh
Posted 29 May 2013 - 07:08 AM
I want a monkey! I never did figure out sadly.. Just became normal for me.
#6 aaki_rocker
aaki_rocker
  • 10 posts
  • Twitter:aaki_rocker
  • Google+:aakidevil
  • LocationIndia
  • Current Device(s):Motorola Droid Razr™ HD, Nokia Lumia™ 928
Posted 27 September 2013 - 09:11 PM
hi will the wifi files which you've provided work with cm10.1, 10.2 and other roms ?
thanks.. :)
#7 Coolloser
Coolloser
  • 40 posts
  • LocationCanaduh
Posted 28 September 2013 - 11:19 AM
thanks.. :)
CM roms already have 925 versions so no work needed :)
Sent from a non-Apple, PACman device.
  • aaki_rocker likes this
#8 aaki_rocker
aaki_rocker
  • 10 posts
  • Google+:aakidevil
  • LocationIndia
Posted 28 September 2013 - 11:30 PM
ok i sorted it out !
fastboot restored my phone to stock and rooted ! :)
#9 Coolloser
Coolloser
  • 40 posts
  • LocationCanaduh
Posted 02 October 2013 - 07:49 AM
Glad to hear it!
