Matt's unbrick utillity Help Please
unbrick
Best Answer Memnoch73 , 03 June 2013 - 06:35 AM
I tried to go to ICS from JB on my droid razr (big mistake) and now it is bricked. can someone please tell me what I need to do to fix this? I tried to run a program to unbrick it but I keep getting a preflash validation error. I saw on the thread where someone said you had to make sure to know where you were coming from when you bricked to make sure you use the right link. Can someone please tell me what link I need to use?
 Any help would be greatly appreciated.
Thanks!!
Jess
You can use the latest Utility. It's in the post above yours.
Go to the full post
32 replies to this topic
#21 riggsdaruler
riggsdaruler
  • 110 posts
  • Twitter:riggsdaruler
  • Google+:riggsdaruler
  • LocationGeorgia
Posted 17 March 2013 - 09:32 AM
Did you try and reapply the OTA from Recovery after flashing?
Yes you can try Matts JB Utility which has the fastboot files. See here:
#22 thecarlsoncrew
thecarlsoncrew
Posted 17 March 2013 - 05:20 PM
Hello! My Maxx was in the state where I was getting an Encryption Unsuccessful error loop, also courtesy of Razr Bootstrapper.
I had read not to try SBF'ing back to ICS, so I never did that. I ran the JB unbrick utility, booted into recovery manually and did the cache wipe and factory reset. Without leaving recovery, I tried to install the .211 zip file (I had previously installed it manually from my sdcard and it worked perfectly, so I know it's a valid installation file), but I got an aborted installation due to an error that I can't quite remember now. I don't believe it was a signature verification error or the status 7 error...I think it was some sort of package check that failed.
Anyway, now I can't even boot into recovery. All I have is a plain black screen. If I hold the volume up/down buttons and the power button, it flickers once as if it's turning off, then I see the "M" logo for a few seconds, then back to black. If I run the unbrick utility again, it just sits there waiting for the device. How can I get back into the recovery menu?
***UPDATE***
Many thanks go out to spazmeister & Co. in the chat room tonight for getting me back up and running again. You guys are awesome (whether British or not)!
  • spazmeister likes this
#23 lballew9952
lballew9952
  • Current Device(s):razr maxx
Posted 29 May 2013 - 09:02 AM
My phone will not go into recovery and Fastboot is all i can get in to I have ran just about all the utilities and they fail, preflash validation failure errors, Where can I find the unbrick utility at??
#24 johnthehillbilly
Posted 29 May 2013 - 10:15 AM
What does it say on the fastboot screen .... it should give a general reason for only being able to get into fastboot.....
Here is the latest xt912 utility if you need it
RAZR Utility XT912 Jellybean -- Windows + Mac + Linux (All In One!)#entry227369
tapadriving.....hillbilly style
#25 jess_2903
jess_2903
Posted 03 June 2013 - 06:29 AM
Thanks!!
Jess
#26 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 03 June 2013 - 06:35 AM   Best Answer
Thanks!!
Jess
  • jess_2903 likes this
#27 johnthehillbilly
Posted 03 June 2013 - 06:37 AM
If you follow the link in the post directly above your post.... it will take you to the latest utility..... run option 1 and it will wipe and reinstall JB :)
Hmmmm ninj'd by memnoch again LOL :)
  • Memnoch73 and jess_2903 like this
#28 jcs78
jcs78
  • 13 posts
Posted 03 June 2013 - 07:00 AM
***UPDATE***
so what did you end up doing to fix the issue you were having
#29 jess_2903
jess_2903
Posted 03 June 2013 - 06:26 PM
Thank you so much!! I was beginning to think I would never get it fixed! It is now up and running!! =)
Jess
  • johnthehillbilly likes this
#30 Memnoch73
  • 5,016 posts
Posted 03 June 2013 - 06:29 PM
Jess
Glad to hear it.  :)
#31 thecarlsoncrew
thecarlsoncrew
Posted 06 June 2013 - 08:08 PM
Wow, that was a long time ago...!
If I recall correctly, I think I was simply not getting the timing right in pressing the physical buttons to get back into the recovery.  I was doing it right, just not getting them all pressed properly in sync.  Once they pointed that out, I kept trying until I got it, and then all was well.  Not sure how much help that is, but I believe that's what got me going again.
#32 billouteast
billouteast
Posted 09 January 2014 - 01:27 AM
Hi Droid fans and helpers.
I am also in an encryption unsuccessfull loop and have tried several options to get it out.
Installed RSDLite and tried to install several different roms, it comes back with failed at step 6/22 .
I managed to get into the boot menu and tried to "install upgrade from SD Card" several JB roms but they all failed at package validation errors.
it is an xt910 running on optus australia, i think it's gsm.
any help greatly appreciated, thanks
Bill
#33 jocimycin
jocimycin
  • Twitter:@joceemycin
  • LocationNigeria
  • Current Device(s):Droid razr Maxx
Posted 21 October 2015 - 08:52 PM
i had my xt912 droid razr stuck on encrption unsuccessful and after reading series of tutorials and manuals on how to get it fixed (None worked) i came across matts droid razr utility xt912 and just followed its instructions and voila!! am back to life
  • RikRong likes this
Also tagged with one or more of these keywords: unbrick
