[Rom][Toro] Pa Rage (2/15/2013)
No replies to this topic
#1 Guest_BDH_*
Guest_BDH_*
Posted 24 February 2013 - 02:01 PM
This is my version of Paranoid Android! No Paranoid Android source has been changed. Only tweaked. Only thing I did was sync to Paranoid Android, then tweak the build. Added some governors, build.prop tweaks, init.d tweaks. Just my own little twist on this badass ROM.
FEATURES OF 3.0
Hybrid engine
Per app Layout, this will let you choose the UI of any app, that means you can switch apps into their tablet layouts.
Per app Size, scale apps individually, this is especially important if you use tablet apps, go as small or big as you like.
Per app Color, this lets you select statusbar and navbar colors for apps individually, colors will shift when you jump from one app to another.
Hybrid engine makes it possible to use any tablet ready app on your phone, start with your regular Google apps and see what treasures lie hidden in them and just how well they work on your device.
You can use hybrid engine to use all available general interface UI's aswell: Phone, Phablet, Tablet. This is safe as milk, we don't change DPI, we don't trash your market, we don't shrink all your apps or force them into layouts, you don't need to edit system files for that.
Transparent bars and color pickers, new SystemUI drawables thanks to giannisgx89
Theming Engine
Statusbar Settings, Lockscreen Settings
Multiuser support
Quicksettings -> Quicktoggles
4.2 Walls and sounds, Google stock apps
New holo-styled theme chooser
T9 dialer
New PA Preferences app
INSTALL INSTRUCTIONS:
Download ROM:
Download Mirror:
Download PA Gapps:
Perform A Factory Reset (unless you are on PA 2.99)
Wipe Cache
Wipe Dalvik Cache
Flash ROM
Flash PA Gapps
Reboot And Wait, First Reboot Can Take A While
