|RC 1.2| Pi-llama Rom | SmartCpu Control | Smart Battery | 10/07/2013 | ArgenDroid
#81
Posted 20 March 2013 - 07:30 AM
Just hit NO after restoring the Backup, when it asks to disable Recovery Flash and don't fix permissions.
Gesendet von meinem XT890 mit Tapatalk 2
Soundcloud <> Bassgrow
#82
Posted 20 March 2013 - 08:41 AM
- makial likes this
#83
Posted 20 March 2013 - 03:11 PM
#84
Posted 21 March 2013 - 01:38 PM
But, what i need do to move/install my apps in external SDCard ?
#85
Posted 21 March 2013 - 01:41 PM
#86
Posted 08 April 2013 - 12:12 PM
thank you
#87
Posted 08 April 2013 - 01:40 PM
#88
Posted 08 April 2013 - 02:28 PM
hello brother, the truth had not tested in win-64, I use 32 labor issues.did it, was a stupid question. installed smoothly... great rom, very well improved. thank you.
thanks for the tip
Enviado desde mi XT890 usando Tapatalk 2
#89
Posted 08 April 2013 - 04:40 PM
#90
Posted 08 April 2013 - 06:15 PM
I didnt understood that good, lets see. When i choose restart i choose disable recovery or just hit no.?? And to fix supersu what? I fix or choose no too??
Finally we look at flashing the "fix.zip" then you give "no" to "flash recovery dissably"
Hablas español??
#91
Posted 08 April 2013 - 09:45 PM
So to flash it on 64bit Vista / 7 just run the bat file not suing "as Administrator" but just left clicking on it.hello brother, the truth had not tested in win-64, I use 32 labor issues.
thanks for the tip
than k you again, I love this rom, it's too fast.
#92
Posted 09 April 2013 - 09:11 AM
#93
Posted 09 April 2013 - 08:05 PM
ah.. pues mejor jajaja el traductor del google me mata.. lo que tiene que haces en el recovery es seleccionar "no" cuando te pregunte si quieres desactivar el recovery flasYes, hablo español.jiji why?
#94
Posted 10 April 2013 - 05:55 PM
Ah ok gracias bro. Es q no estaba seguro. Aooco tu usas traductor. Q mal..tarda eso mucho no??
#95
Posted 12 April 2013 - 08:38 AM
Max,
Please, take a look at this: http://forum.xda-dev...d.php?t=2225168
Since the deodexed Phone.apk has successfully replaced the original one, do you think you could implement pure and complete one as for example: http://forum.xda-dev...d.php?t=1735507 instead into the next version of ROM?
And is it possible to assign to one of buttons (long press) instant close of the current application? Thanks.
#96
Posted 15 April 2013 - 12:18 AM
Bueno hoy mismo he desbloqueado mi bootloader y acabo de probar esta ROM va muy bien. Gracias a todos los involucrados en el desarrollo y en el testing. UNa consulta, con toda la emocion de la ROM nueva olvide aplicar el Fix desde el recovery, hasta ahora todo me va bien pero me podrian indicar que es lo que modifica o parcha ese Fix. Gracias y saludos desde Peru.
#97
Posted 26 April 2013 - 02:47 PM
hello, i think is very impressive what you are doing so can i use show your firmware in a tutorial? just let me know what do u think about
#98
Posted 17 June 2013 - 10:27 PM
Thanks very much, your ROM is great
#99
Posted 26 June 2013 - 02:57 PM
my device enter on a boot loop and i need restore he. Whats the problem ?
#100
Posted 11 July 2013 - 05:59 AM
updated theme, sorry for neglecting the post
Also tagged with one or more of these keywords: argentdroid, rom, custom, jelly bean, razr i, update razr i
