|RC 1.2| Pi-llama Rom | SmartCpu Control | Smart Battery | 10/07/2013 | ArgenDroid
#21
Posted 23 February 2013 - 02:09 PM
Sent from my XT890 using Tapatalk 2
#22
Posted 23 February 2013 - 03:58 PM
Enviado desde mi XT890
#23
Posted 24 February 2013 - 01:51 AM
It's really nice to see the first development of custom JB ROM for Razri. I would like to ask how much is this ROM deblured. Especially does it still has Motorola's Phone.apk or original stock Phone.apk with Internet Calling function integrated? And what about other functionality which either work in previous ICS or are virtually integrated: FM radio, Flashplayer, HDMI? Don't get me wrong, I admire your work as it is and it is really great. Just wonder about possibilities. Thanks you.
#24
Posted 24 February 2013 - 06:37 AM
yes, you need creatte acount ( with facebook , gmail & tweter)Has 4shared always required registration for free downloads?
Enviado desde mi XT890 usando Tapatalk 2
#25
Posted 24 February 2013 - 06:40 AM
veo que hablas español =), no son solo parches son muchos ajustes que se deben ir probando y ver que consigues, en el sitio web de argendroid podras encontrar ayuda, con gusto te dare una mano.so, i've reading and this is just like a patch adding some applications if wrong correct me please, i want to mode the Phone where should i begun.? some book.? or some Page.? someone tell me please =D
- yondaime_fenix likes this
#26
Posted 24 February 2013 - 10:44 AM
Hi,
HDMI not tried it, I do not have a connector, fm radio does not work and is not integrated flash player but it works. Even with phone. Apk motorola, had not thought about changing it has given me a great idea, I will try to integrate the AOSP. Agradesco your advice and your criticism
- piskr likes this
#27
Posted 24 February 2013 - 12:45 PM
#28
Posted 24 February 2013 - 12:57 PM
#29
Posted 24 February 2013 - 01:18 PM
How did you update camera libs? What changes makes the update? Is it possible just to install the libs? How? Where can I get them?
Libraries are the source, there is the get, then compiled with x86 format
#30
Posted 24 February 2013 - 01:21 PM
Oh, it's not criticism at all. As I said you did a great job. But if you could implement into next version original Phone.apk with internet calling instead of Moto one where this functionality is stripped off it would really help a lot.
No problem, I like criticism, help me to develop as AOSP applications I have, I'll be testing
#31
Posted 24 February 2013 - 07:06 PM
haha gracias le dare un vistazo y asi apoyarlos en lo que pueda
#32
Posted 24 February 2013 - 08:52 PM
Two things.:
- what about deodexing?
-does init.d yet work on v0.2 ??
Please dont stop dev. On razr i ;-)
Regards
#33
Posted 25 February 2013 - 04:12 AM
First : thank you 4 your development! :-)
Two things.:
Regards
I had good experiences with deodex, the problem will be solved with the init.d in the next version (this week)
- HSD-Pilot likes this
#34
Posted 25 February 2013 - 05:32 AM
buen trabajo. gracias.
#35
Posted 25 February 2013 - 05:52 AM
yes, i workis there a possibility to get aworking fm-radio back? it worked in ics but isn't working in jb.
#36
Posted 25 February 2013 - 07:20 AM
Thank you!
I will wait for your update ;-)
#37
Posted 26 February 2013 - 10:14 AM
Can you make a new thread with improving the camera and publish the libraries and a how-to-install there??? Would be great!
#38
Posted 01 March 2013 - 12:46 PM
im wanna installit right now jeje
Ho and a little suggestion, what about a cwm zip intall? Cause a lot of troubles?
Im so happy to see the growing of roms for this amazing phone
#39
Posted 01 March 2013 - 02:13 PM
Do you recommend me to wait for the update?
emm ... happen to me is easier to compile in this way, it's just practicality. I'm trying to improve the framerate of Interfas Motorola, bone would be delivering two versions, one with and the other AOSP style stylish Motorola stock. I would tell you to wait until Wednesday for the new version, since I found Wireless errors between minimal errors.
- Poeth likes this
#40
Posted 01 March 2013 - 05:51 PM
Ook, muchisimas gracias , veo k ablas español jeje, esperare pacientemente
Soy muy gorroso, m permites darte la idea de ke implementes el Cambiar los datos de las apps de la memoria interna a la externa?, es un mod muy usado , hay un post en xda dond lo implementan, talves lo puedas poner como Extra o algo asi
Muchas gracias por tu esfuerzo
Also tagged with one or more of these keywords: argentdroid, rom, custom, jelly bean, razr i, update razr i
