How to transfer messages from Android to computer
android backup android transfer
1 reply to this topic
#1 eveeve
eveeve
  • 10 posts
Posted 10 May 2017 - 12:58 AM
 Messages are very important phone data for us. To avoid lossing text messages, it is neccessary to do a backup of them.
for backup? Here I will introduce Android File Manager tool to help you. Just need 3 steps to finish the work.
Guide: How to
Step 1: Install and run Android File Manager on your computer
Step 2: Connect your Android Phone to PC, and enable USB debugging, you can also connect your phone via wifi.
Step 3: Scan and preview messages, then start exporting.
OK! We have transferred messages from phone to computer now, and these messages were saved on your computer. And we can also use Android File Manager to move other kind of contents from android phone to computer in the same way.
Moreļ¼š
  • kellym likes this
#2 livinginkaos
Posted 10 May 2017 - 01:26 PM
 Messages are very important phone data for us. To avoid lossing text messages, it is neccessary to do a backup of them. How to transfer messages from Android to computer for backup? Here I will introduce Android File Manager tool to help you. Just need 3 steps to finish the work.
Guide: How to Transfer Text Messages from Android to Computer
It would be helpful if you had a link to the Android File Manager you are using.  There are many out there that are not free or are free to try but only provide limited function.
Also tagged with one or more of these keywords: android backup, android transfer
