So, I have a USCC version of the Razr M, the Electrify M. Anywho, I broke my trusty Moto X the other day, so I had to go back to this phone since I am trying to decide what to get now. In the meantime, I have 3 of these XT901 units, and I thought I would try to flash a CM ROM or something to it. I have done this a million times with my X, but never with the M. I got TWRP on it, but never could get a ROM to flash, kep erroring. So, I came across a utility that you can switch from JBBL to KKBL to run the different ROMS but it was for the XT907. I thought since I was using the ROMs and modifying the scripts for my phone, this would work too. So, I flashed it and after it rebooted, nothing. Nothing at all. If it plug it in with RSD lite, it shows QHSUSB_DLOAD, but that's it. Wont start in fastboot or anything. I am guessing it's toast, but I thought i would see if anyone had any ideas.
XT 901 Issue
Posted 13 April 2017 - 07:24 PM
Posted 13 April 2017 - 07:53 PM
That error is the kiss it goodbye and bury it error. There isn't an inexpensive way to get it to work again. Its either replace the mainboard or buy a flashing machine for it. Last I looked you could buy a bunch of working phones for the price of the machine.
Posted 14 April 2017 - 05:29 AM
Alright, that's what I figured. I'm really not too worried about since I have a couple others, and it's like a 6 year old device now anyway. I did find a little deal about using qpst to get it going again, so I may try that this weekend.
