Accidently loaded Custom Rom while Stock ROM active - what now?
Posted 16 February 2013 - 11:30 PM
I hope I haven't screwed up my phone beyond repair.
Long story short, I loaded a custom rom JB 4.2 (CM 10.1) into the stock ROM slot. I didn't realize that was possible. But that is what it seems like I did.
Is there any recovery from this mistake? When I to to boot to stock, there is flash and then it reboots back to safe strap.
I've probably made it worse, but I did a factory reset in the stock recovery.
I think my only hope is that I can get back to a fresh install of the leaked Jellybean OTA ROM (4.1.2) that was running before I made this mistake. If that works, I can at least recover a Titanium Backup I had made.
Any help would be much appreciated.
Posted 17 February 2013 - 01:03 AM
- The Persuader likes this
Posted 17 February 2013 - 02:01 AM
That all went perfectly, but after I had finally restored my backup from Titanium Backup I then restarted my phone. I first noticed that after the SafeStrap recovery option shows up the phone then goes to the stock boot animation, but then it hangs there. I haven't waited it for a very long time but at least 5-7 minutes and it never boots up.
I then was able to get back into the Safestrap Recovery and found that the nickname I had given Slot-1 was still present from before this problem occurred. I wiped the cache and dalvik cache hoping that would help the phone boot. This did not help my situation.
Thanks again for your reply.
Posted 17 February 2013 - 02:10 AM
JB OTA update How To's, With Details for Be
There is some good info as well as a download link for the unbrick utility.
Posted 17 February 2013 - 09:24 AM
Posted 17 February 2013 - 09:28 AM
Update: I wasn't able to boot into the stock ROM,but for testing purposes (and because I needed a phone) I was able to install the C10.1 ROM that caused me to want to get into this mess. This ROM will run from slot 1. The stock ROM will never get past the boot animation. Is the stock ROM bricked? Should I use Matt's utility and just not reinstall Safe strap or is something deeper required? I will read up on the previous link you posted now. Thank you
Its not bricked. Just needs reapplied so to speak. That's where the unbrick utility and redoing the jb leak comes in to play. Basically reapplying the jb leak will fix whatever is broken on the stock side. Fair warning though. You will have to reroot and redo safestrap install and such. Time consuming but will get everything back up and running again.
Posted 17 February 2013 - 10:41 AM
Also, Is it normal for Safestrap to remember a ROM nickname (and presumably other settings) with a total wipe?
I will go ahead and start over and be more cautious with the sequence with which I reinstall stuff.
Posted 17 February 2013 - 02:53 PM
I am wondering if I can use the 4.0.4 SBF to restore? Or am I too far beyond being able to use that? I guess I will work with the Unbricking tools.
Posted 17 February 2013 - 03:35 PM
Posted 17 February 2013 - 03:37 PM
Posted 17 February 2013 - 03:40 PM
Is there any hope?
Posted 17 February 2013 - 03:43 PM
Posted 17 February 2013 - 03:49 PM
Posted 17 February 2013 - 03:56 PM
I got to the point where nothing would boot. The M would show up and the screen would go black. I just finished the Unbricking Util. I was confused and didn't realize that it was different than Matt's other utility. We'll see what it does.
Ah OK. Running the unbrick utility will fix the fastboot failure. Just remember to reapply the leak in stock recovery after running the unbrick utility. Sorry I should have been clearer about the difference in the utilities.
Posted 17 February 2013 - 04:04 PM
"assert failed: apply_patch_space(15008849)
(Status 7)
Installation aborted.
and a whole series of "E:can't mount /cache/recovery/log" and so on
Posted 17 February 2013 - 04:12 PM
Posted 17 February 2013 - 04:14 PM
Posted 17 February 2013 - 04:16 PM
Yes, I wiped in the JB Unbrick Utility. I am trying to load the update from SD card again. I wiped the cache before I started the update again.
OK let me know. I'm just hoping nothing got too messed up when you tried to sbf back to ICS. No errors came up on the unbrick utility when you ran it?
Posted 17 February 2013 - 04:18 PM
I hope don't have a true hard brick situation.
