Connecting Razr M to Ubuntu
Linux ubuntu gMTP
7 replies to this topic
#1 evocop
evocop
  • 60 posts
  • Twitter:floydaccess
Posted 15 February 2013 - 03:40 PM
Wondering if anyone has had any success connecting their Razr M to a computer running Ubuntu 12.10. I have usb debugging enabled and connect my phone as MTP. When I run the gMTP program on Ubuntu and click "connect a device" I get an error something to the effect of unable to read "Raw Device", When I connect as PTP nothing happens either. I can not access, view or transfer the files to and from phone. I do have the latest gMTP program installed and also the computer is recognizing my phone when I check for MTP devices? Am I missing something? Any help would greatly be appreciated!
#2 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 23 March 2013 - 10:58 AM
I got mine to connect using gMPT just fine
#3 evocop
evocop
  • 60 posts
Posted 11 April 2013 - 02:06 PM
Did you do anything special because mine says "Error Detect:Unable to open Raw Device" when I try to connect using gMTP? Ive uninstalled and reinstalled gMTP
#4 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 11 April 2013 - 04:40 PM
tell you what update your ubuntu to 13.04 it supports mtp im using it right now it officially releases april 25th but you can get it right now if you want
#5 fry258
fry258
Posted 14 April 2013 - 03:11 PM
check this out:
works great
#6 evocop
evocop
  • 60 posts
Posted 16 April 2013 - 06:34 AM
check this out:
works great
Would this work Linux Mint 13? I am going to try it. I got rid of Ubuntu 12.10 and installed Linux Mint and I am having the same problems mounting MTP as I did in Ubuntu. I will try it and let you know! Thanks for the support guys.
#7 evocop
evocop
  • 60 posts
Posted 16 April 2013 - 06:47 AM
Update: I get the following after succesfully installing. "There was an error launching the application" Details: Desktop file didn't specify Exec field" and when I try to run as an administrator, It says " Unable to determine the program to run.
The item you selected cannot be open with administrator powers because the correct application cannot be determined."
#8 fry258
fry258
Posted 16 April 2013 - 04:06 PM
This utility is specifically designed for Unity environment. It has to be run from Unity. I assume you are trying to run it from desktop.
Sorry.
Also tagged with one or more of these keywords: Linux, ubuntu, gMTP
