[Cdma Razr][Gingerbread] | Rom | Axi0M [R] | Cm9 | 4.0.3 | 2/17/2012
457 replies to this topic
#1 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 17 February 2012 - 07:57 PM
AXI0M [R]AZR ICE CREAM SANDWICH 4.0.3
READ THIS!
So...Here is my port (KANG) of my GNEX ROM AXI0M based off of ICSRAZR. This IS ALPHA, I am aware of the bugs, no bugs reports are needed. READ the What's NOT working section and Enjoy. It is Fast, Smooth, Sexy, and most of all... Ice Cream Sandwich on the RAZR (#dickslapmoto)
As Always, I start with the system, tuning it, making it fast, fluid and solid. MODS and features are then added.
DHACKER AND HASHCODE FOR BANGIN OUT THE BASE
CYANOGEN FOR SOURCE
MASTURMYND FOR THE MASTURMOD SETTINGS
KEJAR FOR STUB BATTERY
EVERYONE FOR EVERYTHING EVER
FEATURES:
CM9 4.0.3 Source
Advanced Install Script
Integrated Google Apps 4.0.4
Modded Busybox 1.20 (Large File Support/Color Fix)
FULL INIT.D SupporT
MasturMOD Settings
FULL DSP Manager
VZW Support for APPS
Th3ory Go Faster Script (Speed, Fluidity, Battery Life, RAM Management)
Max FPS (240)
Force Home Launcher in GPU (Software)
Disable Kernel logging (Speed)
Max JPEG resolution to 100%
ZRAM Compatible (Settings/Performance)
SD Read Speed
Zipalign At Boot
Shorter Ring Delay (Connect Call Faster)
Proximity Sensor Hack (Light Up Faster)
UI Enhancements
APM
TON of Extras Tweaks
BROKEN:
Camera
USB Mounting
YOU MUST BE ON THE 6.12.17X UPDATE TO RUN THIS OR YOU WILL BRICK
NOTE: For Data go to Settings/Wireless & Networks/More/Mobile Networks/Network Mode/ Select GSM only wait till the screen flashes twice (or it says 4G SIM detected would you like to switch to LTE/CDMA) then switch to LTE/CDMA. Data will come up.
When you apply a UI MOD from the MasturMODs, the systemUI will FC at the end. Its supposed to, that means it worked. Reboot and enjoy.
MasturMOD Settings Fixed:
DO NOT FLASH GAPPS
MD5: 2ee0972954756f4622fecd22616b997f
INSTALL INSTRUCTIONS... FLASH USING BOOT STRAP OR SAFE STRAP.
Put on SD Card
MUST
Wipe Data/Factory Reset
Wipe Cache
Wipe Dalvik
Under Mounts and Storage Format /System
Flash It
Reboot
CHANGE LOG:
* Made It
SCREEN SHOTS:
Posted ImagePosted ImagePosted ImagePosted Image
  • Bignadad, mugsy77, mattlgroff and 5 others like this
#2 bowtieduece
bowtieduece
  • 19 posts
Posted 17 February 2012 - 08:02 PM
Wow first on both threads:) This DL is taking toooo long!
  • tweakhax likes this
#3 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
  • Twitter:@quadjacks
  • LocationFort Drum, NY
  • Current Device(s):Maxx HD
Another Droid Th3ory thing!
#4 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 17 February 2012 - 08:03 PM
Wow! Checking it out asap! Thx DT!
#5 blkghost
blkghost
    Bignadad Beta Team
  • 72 posts
  • Twitter:@blkghost22
  • LocationLos Angeles
Posted 17 February 2012 - 08:06 PM
Thank u
#6 JBeXX
JBeXX
  • 87 posts
  • LocationColorado
Posted 17 February 2012 - 08:07 PM
Awesome! Thanks!
#7 weaponx
weaponx
  • 413 posts
  • LocationTX
Posted 17 February 2012 - 08:14 PM
since you specify the mounts and storage, I'm assuming that you mean install with Safestrap? In bootstrap, it's just wipe data factory reset...please confirm..thanks..
Hey bub, I'm not finished with you yet..... SKNIT!!
#8 Tmc363
Tmc363
  • 182 posts
  • Twitter:@tmc363
  • LocationHouston, Tx
Posted 17 February 2012 - 08:15 PM
As always you are the man!
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here: http://www.droidrzr....-custom-titles/
#9 kl0wn
kl0wn
  • 192 posts
Nice! Will download and flash Sunday when I am home!
#10 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 17 February 2012 - 08:16 PM
Screens are in the OP
  • dcolest44 likes this
#11 weaponx
weaponx
  • 413 posts
  • LocationTX
Curious..is the Market part of the GAPPS? Just wondering, cause if you say don't flash gapps, i just want to make sure we can still download the apps from the market..Gracias..
#12 JBeXX
JBeXX
  • 87 posts
  • LocationColorado
Mounts and storage is also where you go on bootstrap to format system
#13 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
No... Boot Strap Also.
#14 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 17 February 2012 - 08:17 PM
As the Features list states.. GAPPS are integrated
#15 mallkioskguy
mallkioskguy
  • 7 posts
Posted 17 February 2012 - 08:18 PM
Does the HD Video acceleration work? Just wondering. Thank you for all your hard work. ICS looks awesome on my razr.
#16 mallkioskguy
mallkioskguy
  • 7 posts
Posted 17 February 2012 - 08:20 PM
Curious about the mic also.. i use the speech to text a lot! lol
#17 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 17 February 2012 - 08:21 PM
Mic and Speech to text work perfectly.
#18 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Dis some good ish! Thanks for another option for out Razrs DT!
  • mattlgroff likes this
#19 weaponx
weaponx
  • 413 posts
  • LocationTX
Posted 17 February 2012 - 08:24 PM
Does battery mods mean you can change the look of the battery icon? I kinda prefer it without the percentage
#20 blkghost
blkghost
    Bignadad Beta Team
  • 72 posts
Posted 17 February 2012 - 08:25 PM
OMG i just woke up my kid. lol
