[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
368 replies to this topic
#1 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 13 February 2012 - 07:08 AM
READ THIS!
So... Some like to just have a fast, fluid, enhanced, featured stock based ROM, and BETTER remix of Stock. Well, this can be easily achieved with some creativity with mods and my beloved updater-script. I was thinking, why the hell not just convert the stock build into a nice ROM? Less evasive, Less hassle, Same results. Why not? In the process of Deodexing the new base, I get annoyed and take a break by doing something else. (It Sucks)
This will Convert your stock system based on 6.12.173. It will Debloat, And ALL the speed, mods, and enhancements of Go Faster, Zipalign, and give you a choice of a Stock UI or my themed ICS UI all with a simple DATA SAVING flash in CWR. At the end you will end up with my ODEX Build of CLUTCH V1.0.
FEATURES:
6.12.173 BASE
4 Editions of Debloat and UI's
ICS Roboto Clean Font
FULL INIT.D Support
Th3ory Go Faster Script (Speed, Fluidity, Battery Life, RAM Management)
Max FPS (240)
Force Home Launcher in GPU (Software)
Disable Kernel logging (Speed)
Max JPEG resolution to 100%
SD Read Speed
Zipalign At Boot
Shorter Ring Delay (Connect Call Faster)
Proximity Sensor Hack (Light Up Faster)
4 VERSIONS OF CONVERSION
MD5: 0ee63dbe71522dfe606e7e6ce8171394
MD5: d7232032bd5c7f8dcf5800d18e94f7cb
[]Modded ICS UI Standard Debloat[/url]
MD5: 9df57ffcfe46747a1668369b8ad1f451
Modded ICS UI Extreme Debloat[/url]
MD5: 9b446f23cfbad6ff5711a74099824160
MD5: 0a15756660fd7841ef3ea692684ca674
INSTALL INSTRUCTIONS... FLASH USING BOOT STRAP ONLY!! SAFE STRAP DOES NOT WORK WITH INIT.D.
Put on SD Card
ONLY
Wipe Cache
Wipe Dalvik
Flash It
Reboot
CHANGE LOG:
* Made It
SCREEN SHOTS OR UI MODDED EDITION:
Posted ImagePosted ImagePosted ImagePosted Image
  • Bignadad, MrFrankRazr, mugsy77 and 9 others like this
#2 Sgerena
Sgerena
  • 95 posts
Posted 13 February 2012 - 07:31 AM
You are the man DROID th3ory
  • imandroid likes this
#3 RAZRblade
RAZRblade
  • 95 posts
  • LocationPA
Posted 13 February 2012 - 07:44 AM
cant wait DT!
#4 joe2018
joe2018
  • 23 posts
  • Twitter:@joejarka
  • LocationShorewood, IL
Posted 13 February 2012 - 07:50 AM
Can't wait!
  • bballersamy13 likes this
#5 ka1z0ku
ka1z0ku
  • 223 posts
Posted 13 February 2012 - 07:51 AM
this sounds like its going to rock hard. so this is going to be ok to flash over .173 running your GoFaster mod? Can't wait to see those screenshots of the ICS themed version. Ok rambling here so I'll wrap up by saying thanks DT and keep up the hard work!
Sent from my Transformer Prime TF201 using Xparent Cyan Tapatalk
#6 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 13 February 2012 - 07:57 AM
Looking forward to it
#7 Frogman
Frogman
  • 23 posts
  • LocationSan Diego
  • Current Device(s):Rooted Droid Razr with JB Aviator Rom
Posted 13 February 2012 - 08:00 AM
Oh yeah.tic toc tic toc........
#8 Naw.D.Man
Naw.D.Man
  • 32 posts
  • Twitter:@nawdman
Posted 13 February 2012 - 08:36 AM
This sounds amazing can't wait
#9 mattp427
mattp427
  • 79 posts
Posted 13 February 2012 - 08:41 AM
what would be the main difference in the ICS ui than in IC3razr
#10 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 13 February 2012 - 08:43 AM
The main difference would be ICSRAZR is Really Android 4.0.
The UI I am making for this is similar to Absym.
#11 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 13 February 2012 - 08:50 AM
Standard Clutch Debloat is done. Finishing the Heavy Debloat Version now. It will post them and finish the ICS UI Version.
On a good note... All went as planned. :)
  • snives, zllibengood and Rouger like this
#12 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 13 February 2012 - 08:54 AM
Usually I hate Mondays but I love this Monday :)
#13 snives
snives
  • 947 posts
Posted 13 February 2012 - 09:05 AM
Just donned on me... Thank you for going with a different name. I never really though about how many people would end up posting "I tried installing the update and it did XXXXX to me!", (with XXXXX likely involving some sort of probe) as a result of not being on the correct version.
#14 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 13 February 2012 - 09:30 AM
Uploading CLUTCH Conversion Standard Debloat and Extreme DeBloat. Standard is a typical debloat of the BS VZW stuffs in.... Extreme is the Standard along with the Resource eating BLUR Social Networking. Everything else stays intact. :)
#15 tracerfett
tracerfett
  • 46 posts
  • LocationOrlando, Florida
Posted 13 February 2012 - 09:38 AM
Can't wait for it's release! Keep up the good work DT!
#16 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 13 February 2012 - 09:47 AM
Links are in the OP. Read it.
#17 alansirhc
alansirhc
  • 23 posts
Posted 13 February 2012 - 09:50 AM
My stock 748 backup had an error, so I'm slowly working my way back up through the versions. OTA downloading isn't fast here in 3G territory.
Gonna try this out once my phone finishes the cycle.
#18 Rouger
Rouger
  • 55 posts
  • LocationLongmont, CO
Posted 13 February 2012 - 09:54 AM
Downloaded, installed and now waiting on the first boot...
Thanks for the quick work on this...
Trying the Standard first.
#19 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 13 February 2012 - 09:57 AM
NICE Work Th3ory. Crack flashers are happy. :)
Lets the sun and the moon collide! eclipserom.com
#20 trikotret
trikotret
    Droid Elite
  • 1,461 posts
DT I have a dilema. Whats the difference between this update and the update for RazrXV1.2. Too many choices for this addict. :D
