Hello everyone,
I've been fan of this site for a long time and always liked the mods and modders of the razr series of smartphones. So now that I have an issue with mine, this is the place I decided to come.
My issue started this morning, while using my Droid Razr original, with CyanCore 1.5 and safestrap, and I go to reboot it. All is working fine at this point, then it boots up, I continue on the Safestrap Menu, and then just a blank screen. I restart my phone several times before going into the safestrap terminal and finding that it reads, several times: "E:failed to mount /sdcard (Device or resource busy)" along with one or two of : "E:Unable to mount '/sysem' (tw_mount)" and "E:Unable to mount /sdcard when trying to read settings".
Every time I go to reboot, Safestrap warns me that my phone has no OS installed, yet if I try to install one, whether it be stock or custom, it still gives these warnings.
My question is, how do I force the sdcard to mount and enable installation of my OS and other settings? I really need my phone working
Internal SD failure to mount
TheMountainRook
, Dec 31 2012 11:39 AM
sdcard failure to mount Safestrap CyanCore 1.5 error boot
1 reply to this topic
Posted 31 December 2012 - 11:39 AM
Posted 31 December 2012 - 11:52 AM
Hmmm, after mounting usb storage, I used windows to check and repair errors on both SD cards. They seem to be able to mount on Safestrap. Safestrap, however can't seem to find the custom slots I had...probably the source of error.
Also tagged with one or more of these keywords: sdcard, failure to mount, Safestrap, CyanCore 1.5, error, boot
