[Cdma Razr][Gingerbread] |Rom| Abysm 1.1 | Deo |1/30/2012 |
1554 replies to this topic
#1 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 25 January 2012 - 05:22 AM
INFORMATION.. READ THIS!!!
IF YOU ARE A BLUR FAN, THIS ROM IS NOT FOR YOU!
Here is my Deodexed build based off of INFEX. This is a VERY Debloated, Slim and Streamlined build. My Concept for this is something "I" like, the Speed, Size and Fluidity of a pure AOSP build but with the more FULL FEATURED set of Apps. I like them fast but I like Features and Candy, so.... I made this. Enjoy.
AFTER YOU INSTALL, IN THE SETUP WIZARD PROCEED AS YOU NORMALLY DO, AFTER YOU ADD YOUR GOOGLE ACCOUNT IT "MAY" LOOP BACK TO THE ANDROID AGAIN. JUST SKIP THE SECOND EMAIL SETUP BECAUSE YOU ALREADY DID(UNLESS YOU WANT MORE THAN ONE SETUP). IT MAY SAY YOU NEED A DATA CONNECTION, DON'T WORRY AND HIT SKIP. FINISH THE SETUP. AT THE END "MyAccounts" will FC. Hit okay and thats it. there are ZERO issues after that.
I WOULD WIPE EVERYTHING WHEN YOU INSTALL THE ROM.... I CAN SAY WITH 100% CERTAINTY THAT IF YOU DON'T YOU WILL HAVE ISSUES, BUT IT IS YOUR CALL. IF YOU DON'T WIPE, DON'T POST ISSUES UNTIL YOU DO. :)
UPDATES WILL SAVE YOU TIME AND HASSLE. ALL UPDATES THAT ARE NOT MAJOR SYSTEM OVERHAULS OR CHANGES WILL BE PACKAGED IN A SMALL EASY UPDATE PACKAGE. THIS IS GOOD FOR ALL OF US.
Thanks to Everyone, Everywhere for Everything Ever.
As of 1/30/2012
  • Latest OTA 6.11.748
  • DEODEXED
  • Quick Toggles
  • Power Menu Reboot
  • Heavily DeBloated
  • ZipAligned
  • Ultimate Compression
  • Optimized PNG's
  • Full INIT.D
  • GoLauncher is Default (I HIGHLY RECOMMEND THE ICS THEME FOR GO Launcher TO HAVE THE REAL EXPERIENCE)
THE GOOD $#!+/RUNNING CHANGE LOG AND FEATURES
  • OS is now maxed out at 240FPS
  • Less Latency in the OS by forcing GPU to back off from the Kernel and be driven in the Software
  • Killed Logger in Kernel for Speed
  • Maxed the OS to 100% on all jpegs
  • New consolidated INIT.D Script
  • Fresh Busybox 1.20 to provide us all these Swiss Army Knife Moves
  • Enhanced Ring Delay (Quick Call Connect)
  • Updated Apps
  • Pushed SD Card Read A Head Speed
  • Rebuilt Custom UI SystemUI, Framework-res, Dialer, Contacts, Phone
  • Extended Wifi Interval Scan (Battery Saver)
  • Full PNG Rework Cleared up ALL PNG's
  • Bloat removed
  • Cleanup of redundancy in the entire build
  • Symlinked FULL ICS ROBOTO Font
CHANGES AS OF 01/28/2012
  • Corp Email Fixed
  • Calendar and Widget Fixed
  • MOTOCast Removed (Still Working on it, It has to do with the same problem causing the FC in Setup.apk)
  • More Debloat
  • Updated SpeedTh3ory Script
  • Fixed Text Notifications
  • Updated ALL APPS
  • Smoothed Out Animations
  • Misc Edits for Clean up and Speed
CHANGES AS OF 01/30/2012
  • NEW Toggles
  • Clear Button Relocated
  • Header Removed
  • Misc UI Touchups and Changes
  • Yet another attempt at the Smart Dock FC
  • Enhanced GPS Locking
  • More Tweaks and Edits to my INIT.D Script
ROMS:(MUST BE RUNNING BEFORE UPDATE!!)
ABYSM V1.0:
MIRRORS:
MD5: 2de2f2ee80bf4d282b920225ad948d9d
ABSYM 1.0 EXTREME DEBLOAT (Personal Version):
MD5: 01499ff90be77054365f8119bcc178d5
ROM UPDATES: (WIPE CACHE AND DALVIK ONLY!! MUST ALREADY BE RUNNING THE ROM)
ABSYM 1.1 UPDATE PACKAGE:
MD5: 222c852d2137ca4fd92537936b306da5
ABSYM 1.1 EXTREME UPDATE PACKAGE:
MD5: 4a4661c577591cae67a50a3dee39eeb2
ADD-ONS: WIPE CACHE AND DALVIK ONLY!! DO NOT FLASH IN THE SAME CWR SESSION. BOOT ROM FIRST!!
Battery 1% With Stock Icon Including Numbers:
Battery 1% With Stub Battery Including Numbers:
TH3ORY Wallpapers ZIP:
SCREENS:
  • Bignadad, quadjacks, tshow84 and 21 others like this
#2 JBeXX
JBeXX
  • 87 posts
  • LocationColorado
Posted 25 January 2012 - 05:27 AM
THANKS DT!!!!!
#3 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 25 January 2012 - 05:45 AM
Got the Screens in the OP.
  • mattlgroff and PillClinton like this
#4 xiogua
xiogua
  • 57 posts
Posted 25 January 2012 - 05:49 AM
Nice, looks good
#5 snives
snives
  • 947 posts
Beautiful work DT!
#6 Burbank
Burbank
  • 48 posts
  • LocationIthaca, New York
Posted 25 January 2012 - 05:50 AM
Thanks DT. Will give it a try this afternoon.
#7 coloradoflats
coloradoflats
    Willing to Brick for ICS
  • 65 posts
  • Twitter:@KevinVanLear
  • LocationU.S.
Posted 25 January 2012 - 05:55 AM
Looks good Th3ory..
"Did you see what I said?"
#8 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 25 January 2012 - 06:12 AM
Reuploading... I had the wrong link. lol. If you downloaded it prior to 9:20AM... Download it again. :)
#9 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 25 January 2012 - 06:37 AM
LINK IS FIXED. ENJOY
  • mugsy77 and TjNaps27 like this
#10 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 25 January 2012 - 06:42 AM
Great job DT and thanks for yet another option for our Razr!
#11 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
  • Twitter:@quadjacks
  • LocationFort Drum, NY
  • Current Device(s):Maxx HD
Super Nice, d/l'ing now, thanks again for the hard work!
ALSO
Make sure we are aware of the
Razr ,dev Giveaway
check it out here>>>>>>>>>>>>>>> http://tinyurl.com/7tvforf
#12 PWn3R
PWn3R
  • 118 posts
  • Twitter:AllenGeorge
  • Google+:https://plus.google.com/102317230135122177087
Posted 25 January 2012 - 06:53 AM
Th3ory, do we need to wipe data to install this?
#13 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 25 January 2012 - 07:01 AM
I would... It is Deodexed. I can only see issues if you don't
#14 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 25 January 2012 - 07:05 AM
How is performance compared to Infex as I do love the ROM? Thanks.
200th post!!!
#15 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 25 January 2012 - 07:07 AM
200th post!!!
Same CORE system and tweaks so it would be as fast. But, as streamlined and light as it is plus and a small Kernel tweak addition I made to my init.d script. I think it will outperform INFEX.
#16 PWn3R
PWn3R
  • 118 posts
Posted 25 January 2012 - 07:12 AM
Thanks, not sure how I missed your note in the OP --- only read it about 5 times LOL
#17 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Awesome DT. Guess I'll do my wiping and flash this puppy!
#18 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 25 January 2012 - 07:19 AM
I am uploading Beta 2... Simple Cache, Dalvik, And Format System from Beta 1. I figured out how to get true ICS Roboto Font running. tester said it looks clean as hell. :)
  • mugsy77 and mattlgroff like this
#19 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 25 January 2012 - 07:21 AM
Oh damn dude...stopping my download then from my Razr. LOL
  • custompro98 likes this
#20 tshow84
tshow84
  • 12 posts
Posted 25 January 2012 - 07:33 AM
this is a question that i hope doesnt upset you DT, but i was wondering if it was possible to get a deodexed verison of the blur add-on zip...i really only want motocast gallery and music - i am on infex right now (its amazing btw!) and installed the blur add-on just to get motocast music and gallery going and uninstalled through TB the rest of the blur....the real reason that i want to run this rom vs. infex is that being deodexed i can install the 1% battery mod - the one thing i miss from roms that ive had with previous droids...thanks!
