wWidow ICS ([6.16.214 ROM]) w/ 6 custom themes!
Moto based 214 ROM Deodexed Zipaligned Android 4.0.4 ICS Black/White theme CDMA Verizon Xt912
122 replies to this topic
#1 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 October 2012 - 02:02 AM
[[wWidowICS]]
|| Deodexed // Zipaligned // 214 based ROM ||
Thanks & Credit ::
Motorola for the hardware & Google for Android. ..
XDA for all the goodies to learn android. ..
Hashcode for the Safestrap to flash with. .. epic!!
Nitroglycerine33 for the quick notification toggles used in BW. ..
Dhacker for all of the things he does for the android community & answering all my questions on Gtalk!!
spc_hicks09 for all the motivation along the way while creating ROMs, and creating an awesome theme for them. ..
Bytecode for all the help when i was stuck modifying settings and the script for the extra modules. ..
24v and wulf for all the help along the way, and for creating bad A$$ themes for my ROM!
Android Does for APEXlauncher & CyanogenMod for DSP Manager. ..
DroidRZR for the amazing community and the place to call home!!
  50.01KB   899 downloads ::
  • Source: 6.16.214
  • Deodexed, Zipaligned, and Blur removed!
  • Integrated Gapps
  • Gmail v4.1.2
  • Maps v6.12.0
  • Music v4.3.615
  • Play v3.9.16
  • Talk v4.0.4 (Black'd out version, found below)
  • Voice v0.4.2.54
  • YouTube v4.1.23
  • AOSP Calculator
  • AOSP Calendar
  • AOSP Clock
  • AOSP Email
  • AOSP Gallery w/ Blurcamera
  • AOSP MMS
  • APEX Launcher v1.3.3 - APEX Black & APEX White - skin/wallpaper pack for APEX launcher
  • BatteryMod Roboto - 1% accurate battery
  • BW icons - icon/wallpaper pack for APEX launcher
  • Build.prop tweaks (for a fluid/battery sipping experience)
  • City State ID
  • Compass v2.3
  • CPUsleeper
  • Custom Dark theme
  • Custom Bootanimation
  • Custom Boot Logo to replace M-dual core print on boot (found below)
  • Custom Wallpapers/ Custom 'Roboto text' Icons (in system/media)
  • DroidLight v5.6
  • DSP Manager v2.0
  • Easy Voice Recorder v1.5.3
  • Facelock
  • Flash Player 11.1
  • Full Init.d support (sio / pegasusq by default)
  • GPS speed tweaks (for a faster gps lock on)
  • Jelly Bean media sounds (notifications, ringtones, alarms)
  • Juice Defender
  • MaxFPS ((240))
  • No Frills CPU Control
  • Root Browser Lite
  • SMSpopup v1.2.4
  • Swpe keyboard (found in system/media, use a file manager to move into system/app)
  • System Panel Lite
  • 5 custom themes (found below, big thanks to Wulf)
KNOWN ISSUES/ WHAT DOESN'T WORK ::
  • Known to cause black outs nation wide! lol....
  • Repeat in Device Setup for GPS settings, and doesn't open to setup Gmail (add account after, and use TiBu to restore (app only))
  • Exchange Email (download K-9 Mail from Play). ..
  49.96KB   915 downloads ::
Requirements ::
  • You Must be on a Moto ICS system/leak (6.16.211 | .214/.215 kernels supported)
  • You Must use ICS-Safestrap-v2.11 or you will Brick! (Safestrap-ICS-3.0X is also supported)
  • Download and move zip/s to sdcard-ext
  • Reboot into Recovery ([Safe system: Enabled])
  • YOU MUST Wipe Data/Factory Reset
  • Wipe Cache partition
  • (in Advanced) Wipe Dalvik cache
  • (in Mounts and Storages) Format System
  • Install zip from sdcard
  • Flash ROM
  • Reboot System
  52.88KB   1059 downloads
]] :: 2012-10-28 ::
MD5: 88A9AC694BD86B50A41C8FC1A7C69662 *wWidow_ICS.zip
  51.53KB   78 downloads ::
[[ THEME|
]] :: developed by wulf
[[ THEME|
[[ THEME|
[[ THEME|
[[ THEME|
[[ THEME|
]] :: developed by ZKK007
]] :: Download, reboot into recovery, and flash wWidow_addon *after you complete first boot!* (this will black out Gtalk, and add some darkness to the Browser)
]] :: Theme improvements within (MMS, Contacts, SystemUI, Talk, and Gmail). Im trying to go as in depth as possible between the main apps/Gapps. check it out!! download, reboot to recovery, flash, profit!
  51.71KB   881 downloads ::
  • Open Apex Settings, Theme Settings, and apply BWicons (icons/wallpapers), APEX White (skin/wallpapers).
  • Open your app drawer and locate and select CPU sleeper, Enable auto-start on reboot and click on 'Start service' 2x to activate. (this shuts off 1 core while the phone's screen is off to save battery! both cores resume when the screen is turned back on).
  • Go into System Settings, Developer Options [ change Window & Transition animation scale to: OFF ]
  • Open AdFreeAndroid, choose Boot Normally, and then choose Skip, check-mark the options "Check server for updates daily", and "Automatically Apply Updates" (ADS SUCK, so why allow them on our phone?).
  • Open Browser, press menu, open Settings, Labs, and Enable Quick controls (for a better browsing experience).
  • Open your system/media directory for custom 'Roboto text' launcher icons (using apex, long press on the app, edit, change icon).
  • Open SMSpopup, Notifications- default notifcations, disable the Show a popup, enable notifications. (change icon if you want, i choose light blue), then vibrate, can set pattern (i choose custom; 0,800), then can set the LED color to whatever custom color you want, i set it as close to ics blue as possible.... then go back. then back again. (now your back to main menu) then open Additional Settings, and turn off Quick Reply, and disable the Button configurations, disable Screen On for Popup. enable privacy mode, and always use privacy mode (i use it, but its by preference), then check the very last box,.. Restrict Popup.
A truly blacked out experience for the RAZR!
If you enjoy the ROM, please feel free to hit the Like button -----------------VVVVVVVVVV
  • andlaw, jrbxx7, prosaschi and 16 others like this
#2 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 October 2012 - 02:07 AM
Boot Logo to replace M-dual core print on boot ::
]] :: You will need a computer for this task!!
  • Extract zip to Desktop
  • Put phone into AP Fastboot (plug into computer usb)
  • Open Command Prompt
  • cd desktop [enter]
  • cd moto-fastboot [enter]
  • moto-fastboot flash logo.bin BWBOOTLOGO.img [enter]
  • moto-fastboot reboot [enter]
*New* BLACKWIDOWicons and WHITEWIDOWicons
  • Please Login or Register to see this Hidden Content
    :: download, move into your system/app directory with (rw-r--r--) permissions set, open Apex settings, theme settings, and apply BWicons. ..
    :: download, move into your system directory, rename to BWicons, set permissions (rw-r--r--), move into system/app directory. open Apex settings, theme settings, and apply BWicons. ..
  • HSD-Pilot, dylan101 and bradenfontaine like this
#3 jamminjon82
jamminjon82
  • 610 posts
  • Twitter:@jamminjon82
  • LocationGloucester, VA
  • Current Device(s):LG G2, Moto X, Kindle Fire 2,Razr M, Nexus 7, Acer A100
Posted 28 October 2012 - 02:14 AM
reserved. ..
Yes!
  • andlaw likes this
#4 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 October 2012 - 02:18 AM
enjoy! this is my masterpiece~ :ph34r: if only i could have finished modifying settings.apk, but when that comes in the next update, and if any bugs are found... it will be the Final build! so please feel free to leave your feedback. help me, help you! lol B)
  • jrbxx7 and downtheory like this
#5 jamminjon82
jamminjon82
  • 610 posts
Posted 28 October 2012 - 02:24 AM
enjoy! this is my masterpiece~ if only i could have finished modifying settings.apk, but when that comes in the next update, and if any bugs are found... it will be the Final build! so please feel free to leave your feedback. help me, help you! lol
will do!
Downloading now, thanks man.
  • andlaw likes this
#6 dbslsy
dbslsy
  • 48 posts
Posted 28 October 2012 - 03:00 AM
#7 jamminjon82
jamminjon82
  • 610 posts
Posted 28 October 2012 - 03:22 AM
This thing is sick,smooth and gorgeous looking. No issues or lag so far.
#8 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 October 2012 - 03:25 AM
:ph34r: it should only get smoother and snappier once the rom settles. its got sio I/O scheduler and pegsusq governor by default giving the best results possible... along with my widow butter tweaks ;)
#9 detr0yt
detr0yt
  • 93 posts
  • LocationDetroit MI.
Posted 28 October 2012 - 05:00 AM
Forgive me... but what exactly is different between this ROM and your other ICS ROM right below... I'm a little sick with an ear ache and might have missed something...thanks for everything
#10 jrbxx7
jrbxx7
  • 94 posts
  • LocationIdaho
Posted 28 October 2012 - 06:30 AM
This is a masterpiece! Dark!! Great work andlaw as always ...
Sent from my MZ617 using Tapatalk 2
  • andlaw likes this
GOT KRACKFLASHING?
#11 jrbxx7
jrbxx7
  • 94 posts
  • LocationIdaho
Posted 28 October 2012 - 07:01 AM
SeNt FrOm .......OvErFlAsHeD SPYDER Xt912
  • andlaw and psychdroid like this
GOT KRACKFLASHING?
#12 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 28 October 2012 - 08:13 AM
Need more themes!! :P
  • andlaw likes this
#13 jamminjon82
jamminjon82
  • 610 posts
Posted 28 October 2012 - 12:15 PM
Need more themes!!
Get to work! Lol
#14 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 October 2012 - 12:16 PM
Get to work! Lol
hahaha, thats what i was going to say :P
#15 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 28 October 2012 - 12:21 PM
Get to work! Lol
:blink:
Oh yeah, guess that's what I do, lol :P
#16 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 October 2012 - 12:23 PM
:blink:
heh, no pressure! and no rush. .. whatever you come up with im sure it will kick a$$!
#17 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 28 October 2012 - 12:34 PM
Have to decide on what to do.
1.Port existing themes golden droid, shady blue, misty green.
2.Make new colors based on golden droid and shady blue like red, orange or green in that style.
3.Quit android, sell razr and get an Iphone, lol
Decisions, decisions. :)
  • I3igdacidy likes this
#18 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 October 2012 - 12:36 PM
rofl, 3 is out the questioN..
2 sounds good, shady blue was pretty dope! would look killer in red or green. $#!7 i mean all you work is great, do what you wanna do~ ;) or just enjoy it as it is lol.. decisions decisions
#19 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 28 October 2012 - 12:38 PM
Lol. Maybe windows phone?
Orange would be pretty bad arse, just saying. As always, any love and work is most appreciated. Thank you in advance.
#20 dysfunkshun
dysfunkshun
  • 102 posts
  • LocationLas Vegas
Posted 28 October 2012 - 02:24 PM
Just ran it through quadrant again, well done sir!
  • andlaw likes this
Also tagged with one or more of these keywords: Moto based 214 ROM, Deodexed, Zipaligned, Android 4.0.4 ICS, Black/White theme, CDMA Verizon Xt912
