[ROM][UNIFIED][4.4.2] AOSPAL-Remix & Plain Aospa[07-July-14]
17 replies to this topic
#1 cj360
cj360
  • 85 posts
  • Current Device(s):Razr HD
Posted 24 March 2014 - 06:47 PM
What started out as building paranoid android with linaro evolved into its own thing. Now we're based off of pa, with sabermod toolchain and linaro optimizations and our own features. (One of our guys wrote lockscreen notfications :p).
For info on features, stuff I leave out here check the op from the xda thread (that one is long & detailed).
Download from Drdevs server:
Also another Mirror on mega.co.nz with moar builds:
Also, unified means it includes:
So this one build will check on install/boot which device you have and make any needed changes, and will work on all these devices with one build.
Issues / Bugs:
​Nfc and BT issues atm nfc won't turn off nicely and BT won't turn on.
Fixed as of 2014-03-30 build
Also there's a pure paranoid-android build in the
 dir but it has the same issues atm.
Thanks to Tucs for the build server and everyone that donated to keep it going.
And everyone on CM, PA, AOSPAL teams.
  • DroidAddict101, cmh714, RikRong and 3 others like this
#2 cj360
cj360
  • 85 posts
Posted 26 March 2014 - 02:44 PM
Updated op, aospa unified build is up (With pie fyi). But I'll probably be replacing it with a build that has modded aosp keyboard (extra keys & gestures built in).
Also, Andre on G+ started a build bot for aospa-legacy devices I'll paste the link in here once I find it and that way one of us will have the latest build.
#3 fxwrangler
fxwrangler
  • 20 posts
Posted 27 March 2014 - 07:18 AM
Thanks cj360. This is an awesome rom! Love it!
  • cj360 likes this
#4 cj360
cj360
  • 85 posts
Posted 31 March 2014 - 05:31 PM
Newer build is up with fixed bluetooth & nfc
#5 7eregrine
7eregrine
  • 163 posts
Posted 01 April 2014 - 07:39 AM
Gotta flash Gapps separately I assume?
#6 sunkim50
sunkim50
  • 58 posts
Posted 01 April 2014 - 06:03 PM
Yup. Separate gapps. This build is great. Confirmed BT is now working on remix version. I am able to turn off NFC but stays greyed out after disabling.
#7 saycbone
saycbone
  • 68 posts
Posted 02 April 2014 - 11:43 AM
Unlocked Only??
#8 DroidAddict101
DroidAddict101
  • 259 posts
  • LocationBinghamton
Posted 03 April 2014 - 03:38 PM
Unlocked Only??
Yes unlocked bootloader is required
  • saycbone likes this
#9 pazuzuftw
pazuzuftw
  • 38 posts
Posted 27 April 2014 - 03:39 PM
I can't update to the newest version through the paranoid ota. It only finds a new gapps package and not the 4-20 update for the rom.
#10 pazuzuftw
pazuzuftw
  • 38 posts
Posted 27 April 2014 - 03:40 PM
I'll probably just flash the new version tonight since I haven't been able to figure it out since I checked and saw the update being there.
#11 cj360
cj360
  • 85 posts
Posted 30 April 2014 - 04:59 AM
The paranoid ota is only for the pure paranoid builds, it works fine here though the install now option is abit finicky.
No new remix builds for a bit, the source is in need of repair and I'm coming up to college finials.
#12 cj360
cj360
  • 85 posts
Posted 19 June 2014 - 06:28 PM
Edit-- A new build is up!
Warning though, you NEED to have flashed stock 4.4.2 for the latest bootloader as the 3.4 included kernel requires it. Otherwise you'll have a bad time.
  • Noigel likes this
#13 kreul
kreul
  • 7 posts
Posted 02 September 2014 - 03:36 AM
Hey wont you guys be updating your rom with the new wifi,bluetooth and gps fixes?
I love this rom,no other rom has as many features,but wifi is a big deal breaker?please reply...thanks
  • Noigel likes this
#14 cj360
cj360
  • 85 posts
Posted 10 September 2014 - 02:26 PM
I still need to update aospal but plain aospa has all the fixes for our device from cm & dhacker. Plus all the moto devices that are stuck without the offical 4.4.2 update from motorola can use moto_msm8960_jbbl builds now and keep updated on the older bootloader. I need to update the changlog here too...
edit- Sept 21 need to find out why youtube has this grey'd out cutup thing when playing videos and fix the charging led turning on and off while charging. Otherwise the rom is super stable. Plus moto_msm8960 and moto_msm8960_jbbl are supported by the legacy part of pa team so those will receive official updates as long as I keep them updated :).  As for saberdroid/remix builds I need to fix a conflict between archlinux and the toolchains and its one library breaking the build but its so damned annoying I haven't figured it out yet.
Edited by cj360, 21 September 2014 - 05:07 PM.
#15 cj360
cj360
  • 85 posts
Posted 07 November 2014 - 11:02 AM
Last builds for msm8960 & msm8960_jbbl running right now, these will ( most likely) be the last kitkat builds before I try to build lollipop.
Some new features:
  • Dsb ( color change-able status bar + navbar from pa) is included, I would've added card style recents but their gerrit is buggy atm so I couldn't pick it.
  • Added HDR to aosp camera and other custom settings from omnirom.
  • A few changes to kernel msm8960 only, I dare not modify _jbbl builds' kernel since I can't test it.
  • jl90 likes this
#16 kc69
kc69
    Droid Elite
  • 1,057 posts
  • Google+:kcmj6969@gmail.com
  • LocationEast Bernard TEXAS
  • Current Device(s):RAZR HD
Posted 07 November 2014 - 04:22 PM
Is this the 10/12 build? PA 4.6 beta?
TEXAS state of mind
#17 cj360
cj360
  • 85 posts
Posted 07 November 2014 - 10:42 PM
Nope newer then that, but I forgot to post the mirror that has the builds so that's kind of backwards of me. :p There's still some bugs with the newest jbbl build telephony related so once the build server can sync again it'll get another build. (I don't intend to leave it buggy but its hard not to when I have no idea why the bugs are there.)
#18 kc69
kc69
    Droid Elite
  • 1,057 posts
Posted 29 April 2015 - 04:44 AM
I have been digging you r latest 5.1 test builds. Haven't seen any lately hope you haven't given up on it. It was fast and smooth.
TEXAS state of mind
