[Cdma Razr][Gingerbread] [Rom] Razrx V1.2 [2/13/12]
rom Razrx
353 replies to this topic
#1 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 10 January 2012 - 02:27 PM
FLASH THIS AT YOUR OWN RISK!! YOU HAVE BEEN WARNED!! I AM NOT RESPONSIBLE FOR SOFT BRICKING YOUR PHONE!!
Here is a custom ROM for the RAZR. RazrX is now updated to systems .173 It is clean, debloated, init.d support, custom scripts, ICS themed and fast. So.. I bring you RAZRX.
Thanks as always:
Much love to DroidTh3ory for making RazrX and giving permission to update
dhacker for being on Team Th3ory
Hashcode for Safestrap
To all the Tester. You know who you are.
Bignadad for his sweet ICS theme
DETAILS:
Updated MOTO Base to .748 system
Debloated
Zipaligned
Th3ory's Custom SYSCTRL
Th3ory's Custom INIT.D
Th3ory's RAM Script
SD READ Enhancement
Ultimate compression
Optimized PNGS
TH3ORYROM Wallpaper App
Superuser 3.0.7 and binary
Busybox (Modified)
added Bignadad ICS Camera Skin
Changelog:
2/13/11
Updated to MOTO Base .173
debloated .173 system
cleaned up INIT.D scripts
Added back blur facebook sync
Added back Swype Keyboard
READ THIS!!!!
EVERYONE MUST WIPE. IT WILL WIPE EVERYTHING (NOT YOUR INTERNAL OR EXTERNAL SD CARD).
CAUTION!!!! MAKE SURE THE ROM IS ON SD CARD EXT BEFORE BOOTING INTO RECOVERY!!!!
INSTALL THE ROM AND WALK AWAY!!! LET THE ROM SETTLE!!!
RUSHING THE KERNEL WILL ONLY CAUSE YOU ISSUES. AND THE BIGGEST WARNING... KEEP BOTH HANDS ON THE DEVICE AT ALL TIMES.
Installation Via Bootstrap
1) Boot into Clockwork Recovery
2) Wipe Data/Factory Reset
3) Wipe Cache
4) Install zip from sdcard
5) Choose zip from sdcard
6) Select the RazrX_V1.1 ROM zip file
7) After ROM installs, Go back and Reboot
Installation Via SafeStrap
1) Boot into Safestrap
2) Enable Safe System FIRST!
3) Wipe Data/Factory Rest
4) Wipe Cache
5) Under Mounts and Storage, Format /System
6) Under Advanced, Wipe Dalvik
7) Install zip from sdcard
8) Choose zip from sdcard
9) Select the RazrX_V1.1 ROM zip file
10) After ROM installs, Go back and Reboot
Need to Be on system base .173 to flash RazrX V1.2
RAZRX V1.2
md5:2c43ab41b4b4b624301230ec582a0efe
Need to Be on system base .748 to flash RazrX V1.1
RAZRX V1.1
MD5: cb8273fc36fc36a30ec7a9281a77127e
BLUR ADD ON (Gives you back the BLUR Bloat that was removed)
(Brought back for .748 update by mattlgroff)
MD5: 8cd22d2907b4c24936e16324f3c4bf4d
Wipe Cache and Dalvik ONLY!!
EDIT: Blur-Add-On for .748 re-uploaded. R.I.P. Megaupload
- This is exclusive to droidrzr.com-
  • Bignadad, Pieman, GulMiguel and 8 others like this
Lets the sun and the moon collide! eclipserom.com
#2 jtclarke
jtclarke
  • 14 posts
  • LocationBFE Virginia
Posted 10 January 2012 - 02:29 PM
Thanks you guys are awesome. At least the razr still has hope.
#3 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 10 January 2012 - 02:30 PM
Thanks for this well waited update! And, thanks to DroidTh3ory !
#4 jcutter347
jcutter347
  • 72 posts
  • Twitter:@jcutter347
  • LocationSnook Alley, Florida
Posted 10 January 2012 - 02:31 PM
+1. Thanks skiwong20. Of course DT as well
  • atigraph likes this
#5 Pieman
Pieman
  • 12 posts
Posted 10 January 2012 - 02:40 PM
Thanks to all 3 of you guys Ski, DT, big. Keep our phone alive!
#6 chefed24
chefed24
  • 64 posts
  • Twitter:@EdSadler
  • LocationAustin Texas
Posted 10 January 2012 - 02:46 PM
What is preferred bootstrap or safestrap?
#7 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 10 January 2012 - 02:51 PM
SafeStrap is what I always use. Bootstrap used to be dangerous, but with fastboot files it isn't. SafeStrap is nice because if your ROM doesn't work you can always go back to your non-safe stock ROM and be fine when you are away from the computer.
RazrX v1.1 is a great ROM and it will actually even install over 1.0 with no wipes at all needed, but not recommended.
#8 chefed24
chefed24
  • 64 posts
  • Twitter:@EdSadler
Posted 10 January 2012 - 02:55 PM
Thanks can't wait to get home and load this.
#9 snives
snives
  • 947 posts
Posted 10 January 2012 - 02:58 PM
Any known issues? DarkestSpawn had a post detailing 3 issues testers were experiencing previously.
#10 (TSON)
(TSON)
  • 529 posts
Posted 10 January 2012 - 03:05 PM
"CAUTION!!!! MAKE SURE THE ROM IS ON SD CARD EXT BEFORE BOOTING INTO RECOVERY!!!!"
Why?
#11 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 10 January 2012 - 03:06 PM
Thanks skiwong.
Thanks Th3ory, I hope you continue your awesome work as it is always greatly appreciated. Take care.
:-D :-D
#12 pattersonx
pattersonx
  • 266 posts
  • LocationSt. Louis
Posted 10 January 2012 - 03:11 PM
so far so good installed and working now to install backed up apps. Thanx for all the hard work!!
#13 TwoBuells
TwoBuells
  • 153 posts
Posted 10 January 2012 - 03:15 PM
cool!
downloading now :D :D
Better to be a Racer for a moment, Than a Spectator for a lifetime.
#14 snives
snives
  • 947 posts
Why?
The internal memory is /sdcard, while the external card is /sdcard-ext. If you had the file on /sdcard, booted into recovery, and wiped you would not longer have the ROM waiting to flash (would have just been wiped). It is meant as a reminder to this effect I believe.
#15 StigmaShadow
StigmaShadow
  • 27 posts
  • Google+:StigmaShadow
  • LocationBristol, VA
Posted 10 January 2012 - 03:16 PM
If I app2sd all my apps can I sd2phone them back? Or will I lose -everything- installing this ROM? Never upgrade rom before (noob).
  • larrygeary likes this
#16 snives
snives
  • 947 posts
Posted 10 January 2012 - 03:19 PM
With an app2sd setup not 100% of the app necessarily moves. The goal of app2sd is to minimize internal usage, not entirely eliminate it. Also, the reference to that location in the OS would be missing. Better off grabbing Titanium Backup and creating backups of your important data with it, then restore the data after the flash.
#17 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Just don't wipe data before you flash. Its compatible flashing over RazrX 1.0 without wiping. Titanium backup can restore apps+data I am not familar with apps2sd and sd2phone.
#18 tankdroid
tankdroid
  • 36 posts
  • Twitter:@Tank_oZ
  • LocationBirmingham, Alabamastan
Posted 10 January 2012 - 03:22 PM
Already up and running! Thank you DroidTh3ory & Skiwong20!!
  • Bignadad likes this
#19 snives
snives
  • 947 posts
Posted 10 January 2012 - 03:23 PM
Any chance at a hash code before I start flashing this? Here's what I've got.
CRC32: E31E9A4E
MD5: CB8273FC36FC36A30EC7A9281A77127E
SHA-1: 5BB0C0A965B9EE9165EFC9AA9A0FD6F9D93E7797
#20 (TSON)
(TSON)
  • 529 posts
Posted 10 January 2012 - 03:34 PM
Data wipes don't wipe /sdcard/ though, you have to specifically go and wipe it. And bootstrap/safestrap have sd and sd-ext support. I don't get it
Also tagged with one or more of these keywords: rom, Razrx
