* * * * * 2 votes
testing ICS on U8680 / U8730 Huawei MyTouch / Q
162 replies to this topic
#1 magikstar29
magikstar29
    french
  • 61 posts
  • Twitter:@magikstar29
  • LocationDouarnenez / Finistère / Bretagne / France
  • Current Device(s):HTC Desire Z / Alcatel OT-986 / Huawei U8730
Posted 30 September 2013 - 04:10 AM
Hi all,
i have flashed my U8730 (MyTouch Q) with the rom of U8681 and it boot,the phone works better on ICS
what's working almost everything and it's rooted
the device boot in landscape mode instead of portrait mode with hardware keyboard closed.
i have some problem with rotation sensor,need hardware keyboard to be open all time to have auto rotation work
how to fix that? maybe kernel issue. If someone can debug it...
So don't use ICS on Huawei U8730 only for U8680.
How to install the rom:
->download the rom zip http://www.mediafire...3u1/hwu8681.zip
->put it on sdcard
->download cwm recovery http://www.mediafire...c2/recovery.img
-> download boot.img http://www.mediafire...kqindf/boot.img
->put them in image folder into pink screen and delete cust.img
->pull out the battery and replace it
->boot in cwm pressing volume up + power
->wipe all: factory reset, format system, format HWuserdata, and format dalvik cache also.
->reboot device into cwm recovery
->mount system
->flash the rom zip
->reboot system and wait
PS: many thanks to IRX102 for provide me the update.app
PS: to fix auto rotation with physical keyboard we need to edit android.policy.jar and maybe framework-res
i post some screen
  • SamuraiCX, surfer43, fflint and 2 others like this
#2 surfer43
surfer43
  • 22 posts
  • LocationSouth Carolina
  • Current Device(s):Huawei U8680
Posted 01 October 2013 - 01:39 PM
I tried to install the update.app for U8681 on U8680 (Huawei MyTouch). Firmware Update installation failed after going into download mode and unpacking. Is this how you did it? Any ideas?
#3 magikstar29
magikstar29
    french
  • 61 posts
Posted 02 October 2013 - 02:46 AM
i haven't used the dload update tu flash the rom.
i have extracted the rom of the update.app
i have made a special cwm recovery and put it into image folder in pink screen, i have put the ICS boot.img also.
i have boot in cwm,wipe all: factory reset, format system, format HWuserdata, and format dalvik cache also.
i have rebooted the cwm recovery
i have mount system
i have flashed the zip i made
and rebooted the device normaly
#4 magikstar29
magikstar29
    french
  • 61 posts
Posted 02 October 2013 - 02:51 AM
as i don't have U8680, i haven't tested on it,just tested on my U8730 but i may work better on U8680 than U8730 because the hardware keyboard of U8730 make some problem that U8680 may not have.
if someone with U8680 want to test, i can provide the files.
#5 surfer43
surfer43
  • 22 posts
Posted 02 October 2013 - 11:17 AM
I will test it out on U8680 if you will provide the files. Thanks!
#6 magikstar29
magikstar29
    french
  • 61 posts
Posted 03 October 2013 - 12:48 AM
ok that's done, first post updated
tell us how it works on U8680
#7 surfer43
surfer43
  • 22 posts
Posted 03 October 2013 - 01:31 PM
I should install from the sd card in cwm, right? When I try to do that, all I get is "Can't mount sd card". I got to the last step and the phone won't turn on even with the old boot.img and recovery.img.
#8 magikstar29
magikstar29
    french
  • 61 posts
Posted 03 October 2013 - 01:38 PM
yes install from sdcard in cwm.
i haven't the problem you talked about can't mount sdcard.
try to format sdcard and retry
#9 surfer43
surfer43
  • 22 posts
Posted 03 October 2013 - 01:43 PM
how to format sd card when the phone won't boot into Android? CWM can't format or mount the sd card.
#10 magikstar29
magikstar29
    french
  • 61 posts
Posted 03 October 2013 - 01:48 PM
format with your computer
#11 surfer43
surfer43
  • 22 posts
Posted 03 October 2013 - 02:07 PM
yes, but how? the screen is stuck on Android 4G T-mobile booting screen when turned on and none of the phone's files show up on the computer.
#12 magikstar29
magikstar29
    french
  • 61 posts
Posted 03 October 2013 - 02:13 PM
put out the sdcard of your phone,put it (with adaptater) in sdcard reader of your comuter
#13 surfer43
surfer43
  • 22 posts
Posted 03 October 2013 - 02:40 PM
So I installed it, but it is in a boot loop.  :( . For some reason the recovery kept randomly rebooting.
#14 surfer43
surfer43
  • 22 posts
Posted 04 October 2013 - 01:48 AM
The log:
Starting recovery on Fri Oct  4 10:18:45 2013
can't open /dev/tty0: No such file or directory
framebuffer: fd 3 (480 x 800)
ClockworkMod Recovery v6.0.1.3
recovery filesystem table
  0 /tmp ramdisk (null) (null) 0
  1 /cache ext4 /dev/block/mmcblk0p6 (null) 0
  2 /data ext4 /dev/block/mmcblk0p13 (null) 0
  3 /misc emmc /dev/block/mmcblk0p7 (null) 0
  4 /system ext4 /dev/block/mmcblk0p12 (null) 0
  5 /HWUserData vfat /dev/block/mmcblk0p14 (null) 0
  6 /sdcard vfat /dev/block/mmcblk1p1 /dev/block/mmcblk1 0
  7 /sd-ext auto /dev/block/mmcblk1p2 (null) 0
W:Unable to get recovery.fstab info for /datadata during fstab generation!
W:Unable to get recovery.fstab info for /emmc during fstab generation!
I:Completed outputting fstab.
I:Processing arguments.
I:Checking arguments.
I:device_recovery_start()
Command: "/sbin/recovery"
ro.secure=1
ro.allow.mock.location=0
ro.debuggable=0
persist.service.adb.enable=1
ro.emmc=1
ro.runmode=normal
ro.factorytest=0
ro.serialno=
ro.bootmode=user
ro.baseband=msm
ro.carrier=unknown
ro.bootloader=unknown
ro.hardware=huawei
ro.revision=0
ro.service.systemstattool=false
persist.sys.powerup_reason=NORMAL
init.svc.adbd=running
init.svc.recovery=running
init.svc.charge=restarting
I:Checking for extendedcommand...
I:Skipping execution of extendedcommand, file not found...
failed to open /sys/class/android_usb/android0/state: No such file or directory
I:Can't partition unsafe device: /dev/block/mmcblk1p1
I:Can't format unknown volume: /external_sd
I:Can't format unknown volume: /emmc
#15 magikstar29
magikstar29
    french
  • 61 posts
Posted 04 October 2013 - 02:58 AM
:blink:  strange, didn't have this problem on U8730.
So maybe the rom isn't compatible with U8680
#16 surfer43
surfer43
  • 22 posts
Posted 04 October 2013 - 02:36 PM
YEAH!!!!!!! :D  :D :D My phone is working perfectly under Android 4. Thank you magikstar29.
! The first thing I did differently than when it didn't work was replace all of the default files in "image" folder in download mode (see the top post on http://forum.xda-dev....php?p=44380191) for them. Maybe I needed cust.img. Another possible contribution to making this work was flashing the SuperSU zip from the bottom post on the same page from cwm. After I tried flashing the rom of U8681 again, it started blinking the boot screen every 2 seconds in a loop. So, I put the U8681 boot.img into phone in download mode (I had switched out the boot.img from both phones to see if that would help before). And when completing some other troubleshooting change, the phone randomly booted into Android 4 when I least expected it to.  :blink:
It works perfectly and MUCH better than stock.
  • crazygrouzin and ttrout678 like this
#17 magikstar29
magikstar29
    french
  • 61 posts
Posted 04 October 2013 - 03:01 PM
Wonderfull, i'm happy to see it works on your U8680
have happy days with it
#18 SamuraiCX
SamuraiCX
  • 47 posts
  • Current Device(s):Samsung Galaxy S2 Skyrocket (SGH-I727R) (Latest PACMan)
Posted 04 October 2013 - 06:12 PM
thanks so much for this! I will definitely try this as soon as possible!
Sent from my SAMSUNG-SGH-I727
Current:   Samsung Galaxy S2 Skyrocket (SGH-I727R) (Latest PACMan nightly, UVMC6 Radio)
Previous: Huawei T-Mobile MyTouch 4G (U8680) (Stock-rooted, running without cust.img) (still owned)
                Samsung Dart (SGH-T499Y) (Stock-rooted) (still owned)
#19 toquer
toquer
  • 18 posts
Posted 04 October 2013 - 08:52 PM
worked!!! I put cust.img back on afterwards as I've modified it but it doesn't fix the keyboard issue nor the autorotate. but I can deal with those for a few weeks while this gets some work done on it. thanks so much for bringing this phone from the dead back into the distant past... google nexus 5 here we come!!
#20 irx102
irx102
  • 6 posts
  • LocationCanada, Ontario, Ottawa
  • Current Device(s):Ascend u8681(stock root), Nexus 4(cyanogenmod root)
Posted 05 October 2013 - 06:13 AM
Glad to see that you made use of the u8681 rom that I've provided you.
  • SamuraiCX, magikstar29 and surfer43 like this
