1077 replies to this topic
#1 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 28 June 2013 - 09:56 AM
(Aviator CM10.1 Current Version 1.0.2. Aviator KitKat Current Version: NIGHTLY 20140320)
Hi all,
Fly higher with Aviator! Please do not post this anywhere else without prior permission.
Other Aviator Versions:
Click on icon to got to that Aviator Version OP.
I am not responsible for anything that may happen to your device. (... nothing should happen)
These screenshots show Aviator CM10.1
Click to
  • Deodexed.
  • Zipaligned.
  • 4.2.2/4.4 System.
  • Init.d tweaks - Battery and Performance based.
  • ADBD.
  • 1% battery.
  • Reboot in power menu.
  • Volume rocker change music track mod.
  • Titanium Backup (Can be uninstalled, not a system app).
  • Battery Calibration (Can be uninstalled, not a system app).
  • No Frills CPU Control/Performance Control (Baked into settings. I.E. go into settings).
  • CPU Sleeper (Baked into settings. I.E. go into settings).
  • OTA Updater (Baked into settings. I.E. go into settings).
  • Beats Audio (Baked into settings. I.E. go into settings).
  • Superuser.
  • Apollo Music Player.
  • GPS tweaks.
  • Build.prop tweaks.
  • Ad blocker - via modified /system/etc/hosts file.
  • Inverted Calender.
  • Inverted MMS.
  • Custom theme – Wallpaper, boot animation, 3G/4G icons, and semi-transparency.
STS-Dev-Team and Cyanogenmod - Source.
Previously thanked people in Aviator Blur OP.
Testers
arikr - 3G PagePlus Tester
If I have forgotten anyone, PLEASE PM me.
AVIATOR CM10.1 MUST BE INSTALLED IN SLOT 1 ON SAFESTRAP.
Aviator KitKat can go on any slot.
  1. Transfer ROM and gapps zip files to SD card.
  2. Reboot into SafeStrap (3.07, 3.11, or 3.6x).
  3. Delete ROM slot 1.
  4. Recommended: Boot into stock system and attain a GPS fix in Maps. Then reboot back into Safestrap.
  5. Create ROM slot 1.
  6. Install Aviator ROM file.
  7. Flash gapps on top of ROM.
  8. Reboot after installation.
  9. Setup phone. NOTE: If phone hot reboots at WiFi addition, reboot into Safestrap, wipe cache, dalvik cache and fix permissions.
  10. Finish phone setup.
  11. Let phone settle for 5-10 minutes.
  12. For Aviator CM10.1, go into Settings>CPU Sleeper. Check "Enable auto-start on reboot" (First Line), then "Start Service" (Second Line) (Press twice).
  13. Charge to 100% for battery calibration or use battery calibration app.
  14. For Aviator CM10.1, if you want the 1% Aviator battery icon which is in the screenshots, go to settings>system>statusbar>Battery status style and select "Icon."
  15. Enjoy!
Don't forget to read the "Bugs" list for bug fixes.
CM11:
NIGHTLY DOWNLOADS:
Download the latest build here:
(If you don't like the smaller resolution, see post 2)
4.4 GAPPS DOWNLOADS:
Stock GAPPS 20131208:
Stock GAPPS 20131206:
Stock GAPPS 20131120:
CM10.1:
STABLE DOWNLOADS:
Aviator_CM10.1_v1.0.2:
- Based on CM10.1.3.
Aviator_CM10.1_v1.0.2 MIRROR:
Aviator_CM10.1_v1.0.1:
- Based on CM10.1.2
Aviator_CM10.1_v1.0.0:
NIGHTLY DOWNLOADS:
The only changes made between these Nightly builds are from CM.
for CM Nightly change log.
Aviator_CM10.1_20130718_NIGHTLY:
Aviator_CM10.1_20130714_NIGHTLY:
Aviator_CM10.1_20130711_NIGHTLY:
Aviator_CM10.1_20130709_NIGHTLY:
Aviator_CM10.1_20130708_NIGHTLY:
Aviator_CM10.1_20130706_NIGHTLY:
Aviator_CM10.1_20130705_NIGHTLY:
Aviator_CM10.1_20130704_NIGHTLY:
Aviator_CM10.1_20130703_NIGHTLY:
4.2 GAPPS DOWNLOADS:
Aviator GAPPS:
(These gapps have updated playstore and gmail in it.)
Regular GAPPS:
WALLPAPER:
4.2:
4.4:
SEE POST 3 FOR EXTRAS!
Updates:
CM has its own update system; however, if you choose to take a CM update, you may lose some of the Aviator tweaks, etc.
Aviator has it's own OTA updates via OTA Updater:
When an Aviator CM update is available, you will get a notification. You will then download the update using the app. Once downloaded, you will have to manually reboot into safe strap. The download location is sdcard/OTA-updater/Download/[filename].zip
Here is how the Stable and Nightly Updates for Aviator CM will work:
  • If you are on a Stable Aviator CM build, you will only get stable build updates.
  • If you are on a Nightly Aviator CM build, you will get Nightly and Stable updates.
Bugs:
  • WiFi addition makes phone reboot: See installation for fix.
  • Third party Keyboards wont install correctly. Using Titanium Backup, change the AOSP keyboard from a system app to a user app. Reboot and wipe cache and dalvik cache. Install third party keyboard.
  • Status bar icons are not changing: Reboot to see change.
  • WiFi tether stuck on "Turning on...": Reboot. Turn off regular WiFi, then turn on portable hotspot.
  • IF YOU HAVE A GALLERY FC ISSUE, PLEASE TRY MOVING THE CONTENTS OF "DCIM" FROM BOTH SDCARD AREAS OFF OF THE DEVICE.
  • Possible MMS Fix:
    • Dial *#*#4636#*#*, Scroll down and set preferred network type to LTE/CDMA, then exit back to home screen.
    • Open Menu>Settings>More... >Mobile Network>Network Mode and select LTE/CDMA/EvDo
    • Exit back to home screen and reboot.
  • OR TRY:
Click to
4.4 CM11 KitKat Bugs:
  • 3 G may drop out: Go into Settings>More>Cell Broadcasts. Then, uncheck all of the boxes.
  • Some people have been reporting intermittent no audio: No fix yet.
Want to show your Aviator Support with a custom Aviator signature image?
Instructions:
Edit your droidrzr.com profile and go to the signature option.
Copy and paste this text:
Save and enjoy!
Kanging Policy:
Please feel free to use anything here for your personal, or public use. If you do use something from this thread, all I ask to to be given credit where it is due. You do not need to ask for written permission unless it is otherwise stated as part of a forum's kanging policy.
Don't forget to "Like" -->
Or if you want to Donate, click on signature image. Thanks!
  • mugsy77, wolve17, disstoncity and 12 others like this
Donate? Click on signature :)
#2 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Changing Screen Resolution (DPI):
Want to change the screen resolution back to the regular resolution?
  1. Use a file explorer to edit system/build.prop.
  2. Search for ro.sf.lcd_density.
  3. Change the value to 240.
  4. Save file and reboot.
CM change Log:
  • ExtraMedium, Redalert, coded and 2 others like this
#3 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Aviator Boot Logo: BLUR, AOKP, CM10.1 and CM11.
Anyone want an Aviator splash screen?
this:
and follow the instructions here:
Splash image example:
Safestrap Splash Screen: BLUR, AOKP and CM10.1.
Instructions:
  • Save the above images as "background-safe.png" and "background-nonsafe.png". Make sure they are 540x960.
  • Save to ext SD card.
  • Reboot into Stock ROM.
  • Use a root explorer (ES File Explorer, etc) and navigate to the pictures. MAKE SURE YOU HAVE R/W PERMISSIONS (Menu>root explorer>mount R/W).
  • Press and hold on the pictures, and copy the pictures.
  • Navigate to /system/etc/safestrap/res.
  • Paste and overwrite the existing files (Make a copy of the originals if you wish).
  • Reboot and profit!
Custom Aviator Widgets: BLUR, AOKP and CM10.1.
These were made in UCCW. Please download UCCW from the play store in order to use these files:
Instructions:
  • Download:
  • Unzip to get 2 .uzip files (weather and stat widgets)
  • Move .uzip files to /sdcard/UltimateCustonClockWidget/
  • Create widget by long pressing on screen, select Widgets, then UCCW. Choose 2x2 size.
  • Press menu, "Open uzip"
  • Navigate to /sdcard/UltimateCustonClockWidget/ and select the appropriate .uzip
  • Enjoy!
  • johnthehillbilly, outpost31 and cyber_06_wolf like this
#4 johnthehillbilly
Posted 28 June 2013 - 10:01 AM
Great job once again :)
#5 lazer
lazer
  • 287 posts
  • LocationWestern PA
Posted 28 June 2013 - 10:09 AM
Rom is looking and feeling good so far! :)
#6 SoccerRef12
SoccerRef12
  • 529 posts
  • Twitter:@SoccerRef12
  • LocationLampasas, TX
Posted 28 June 2013 - 11:46 AM
I'm looking forward to giving this a test flight!
Sent from my Droid Razr Maxx using TapaTalk 2
"If you truly learned from your mistakes, I would be a genius by now!"
#7 rickw
rickw
    corvette dude
  • 1,951 posts
  • Google+:rickwebb001@gmail.com
  • LocationDelaware
  • Current Device(s):S4 dev edition,moto x dev,Nexus 6
Posted 28 June 2013 - 04:07 PM
way to go 007
#8 ddmclw
ddmclw
  • 10 posts
Posted 28 June 2013 - 06:08 PM
Running great! Thanks :)
Sent from my XT912 using Tapatalk 4 Beta
#9 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 28 June 2013 - 07:52 PM
sir before flashing ROM can I need to wipe cache dalvik factory etc if yes tell me the order after creating ROM slot 1
#10 OldBaldy
OldBaldy
  • 425 posts
  • LocationSouth Carolina
Posted 28 June 2013 - 09:15 PM
You sir are monopolizing my phone! I now have Aviator running in slots 1,2 and 3 (3 being blur). Great roms all.
  • Einsteindks and mattkilla like this
#11 rugman55
rugman55
  • 40 posts
  • LocationBrunswick, Ga
  • Current Device(s):Razr Maxx, BlackBerry PlayBook
Posted 28 June 2013 - 11:15 PM
What's the difference in AOKP and Moto blur?
#12 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 29 June 2013 - 03:06 AM
Just follow what the instructions and you shouldn't have any issues :) As long as you delete the ROM slot, you will not need to wipe cache/system. But, if you get a reboot when trying to add WiFi, then you will need to wipe cache, dalvik cache, and fix permissions. Hopefully you get it up and running :)
  • aneeshmbabu likes this
#13 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 29 June 2013 - 03:09 AM
They are all based on different builds. Blur is Motorola's android base. AOKP and CM are custom build made by their respective teams. They all have slightly different mods and user options. Blur is indeed 100% stable, while AOKP and CM will still have a small issue or two floating around. They are still stable enough for daily driving though :)
  • Einsteindks and The Persuader like this
#14 hdkilner
hdkilner
  • 35 posts
Posted 29 June 2013 - 05:30 AM
Is Bluetooth not working a problem with all AOKP/ Cyanogen based Roms? I really like these roms but Bluetooth ALWAYS  stops working. Is there a permanent fix for this?  Nice Rom BTW wish I could have kept it.. Thank for the good work
#15 Einsteindks
Einsteindks
  • 340 posts
Posted 29 June 2013 - 05:33 AM
I can't speak for the entire Bluetooth experience, but I have had a Bluetooth speaker paired quite successfully.
sent via RazrMaxx over Tapatalk, y'all!
#16 Einsteindks
Einsteindks
  • 340 posts
Posted 29 June 2013 - 05:35 AM
Anyone have a clue why the flashlight toggle is greyed out on the power widget? Is there some sort of stock flashlight that's missing?
#17 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 29 June 2013 - 07:26 AM
is over clocking possible on this ROM??
#18 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 29 June 2013 - 07:54 AM
I haven't tried it myself, but it should be. Head on over to
and look under the CM10.1 links.
#19 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 29 June 2013 - 12:49 PM
Battery life isn't too bad on the stock kernel either! Two hours of screen time and still 62% remaining on an OG Razr (Only 3hrs of total time though, I was playing Final Fantasy IX :p)
#20 Einsteindks
Einsteindks
  • 340 posts
Posted 29 June 2013 - 12:55 PM
Making my RazrMaxx earn it's keep. Truck speedometer, satellite radio, dash-cam, cell phone, dang I had it smokin'! sent via RazrMaxx over Tapatalk, y'all!
