(Aviator AOKP Current Version 1.0.4)
Hi all,
Fly higher with Aviator! Please do not post this anywhere else without prior permission.
Other Aviator Versions:
Click on icon to got to that Aviator Version OP.
I am not responsible for anything that may happen to your device. (... nothing should happen)
- Deodexed.
- Debloated.
- Zipaligned.
- Init.d tweaks - Battery and Performance based.
- ADBD.
- WiFi hack baked in (Use stock hotspot).
- 4.2.2 Toggles.
- 1% battery.
- Reboot in power menu.
- Volume rocker change music track mod.
- Animation on notification pull down (hold the bottom bar on pull down) - Pictures removed, but code remains.
- ES File Explorer (Can be uninstalled, not a system app).
- Titanium Backup (Can be uninstalled, not a system app).
- Battery Calibration (Can be uninstalled, not a system app).
- No Frills CPU Control (Baked into settings. I.E. go into settings).
- CPU Sleeper (Baked into settings. I.E. go into settings).
- OTA Updater (Baked into settings. I.E. go into settings).
- Beats Audio (Baked into settings. I.E. go into settings).
- SuperSU.
- Apollo Music Player.
- GPS tweaks.
- Build.prop tweaks.
- Custom theme – Wallpaper, boot animation, 3G/4G icons, and semi-transparency.
STS-Dev-Team
Dhacker and Hashcode - AOKP Spyder Maintainers.
Previously thanked people in Aviator Blur OP.
Travp - inverted calender.
If I have forgotten anyone, PLEASE PM me.
- AVIATOR AOKP MUST BE INSTALLED IN SLOT 2 ON SAFESTRAP.
- Transfer ROM and gapps zip files to SD card.
- Reboot into SafeStrap (3.11 or 3.07).
- Recommended: Boot into stock system and attain a GPS fix. Then reboot into Safestrap.
- Delete ROM slot 2.
- Create ROM slot 2.
- Install Aviator ROM file.
- Flash gapps on top of ROM.
- Reboot after installation.
- Setup phone.
- If you have no WiFi on initial boot: In Safestrap, wipe cache/dalvik cache and fix permissions.
- Go into Settings>CPU Sleeper. Check "Enable auto-start on reboot" (First Line), then "Start Service"(Second Line) (Press twice).
- Let phone settle for 5-10 minutes then reboot for best results.
- Charge to 100% for battery calibration or use battery calibration app from Play Store.
- Enjoy!
Please view the AOKP bugs section under "NOTES", specifically the GPS issue and MMS issue. There are recommended installing instructions to ensure no GPS bug issues arise and a possible MMS fix..
ZKK007's Public Folder:
DOWNLOAD v1.0.4:
DOWNLOAD Aviator GAPPS:
DOWNLOAD Aviator AOKP Wallpaper:
TEST v2.0.0:
- Boot animation will seem to stop on boot. Be patient, the boot animation doesn't want to loop, but everything is ok.
- As soon as the "Welcome" screen appears, Reboot into Safestrap and fix permissions.
- If you experience other issues, reboot into Safestrap, wipe cache and dalvik cache, and fix permissions. This should fix 99% of issues.
- MMS fix is listed under the "bugs" section.
- DOWNLOAD:
SEE POST 3 FOR EXTRAS!
Want to show your Aviator Support with a custom Aviator signature image?
Instructions:
Edit your profile and go to signature.
Copy and paste this text:
Save and enjoy!
Kanging Policy:
Please feel free to use anything here for your personal, or public use. If you do use something from this thread, all I ask to to be given credit where it is due. You do not need to ask for written permission unless it is otherwise stated as part of a forum's kanging policy.
Don't forget to"Like" -->
Or if you want to Donate, click on signature image
