I did a factory reset in safestrap and had no backup and lost my OP system......PLEASE HELP ME
deleted OP system on my Driod Bionic did a factory reset in safestrap with no backup
Posted 22 May 2013 - 03:34 PM
Posted 24 May 2013 - 05:00 AM
Go here -
and find the device you were on (looks like cdma Bionic) and in that area download the version OS you were on or higher (If you were on ICS 4.0.4 you can go 4.0.4 or 4.1.2, you just can't go backwards like from 4.1.2 to 4.0.4)
Use RSD Lite and flash the FXZ you just downloaded to your phone in APFastboot mode.
If you know anything of the HoB, you could use that as well.
Posted 24 May 2013 - 10:53 AM
when im in APfastboot my RSD does not find my device .....but when i go into BP SBF Flash mode (S) 0a.78 it comes up.....how do i get RSD to find my device
Posted 25 May 2013 - 08:41 AM
Make sure you have the latest drivers, factory cable and not in a usb3 port.
Posted 31 May 2013 - 07:26 PM
Posted 13 June 2013 - 04:15 PM
Go here -
Noobish question here, but is this download rooted? Somehow, I goofed my Bionic to the point where I had to fxz back to stock Jelly Bean. I've been looking all over the net for an easy way to root the thing, but haven't really found anything that doesn't require being on a network or something. One of the methods I found required inputting some stuff into the "Remote Storages" section of the built-in Files app, but it didn't work. If this isn't rooted, is there an easy one-click method out there I haven't been able to find yet?
Posted 13 June 2013 - 04:26 PM
It is not rooted. This are the stock fastboot files. There is not one click. The only way to root JB is the one posted on this forum. It requires Linux to to it also.
Posted 13 June 2013 - 07:19 PM
That's what I was afraid of. My problem with using the method posted here is I don't have a wifi connection at home, I just tether my phone to the computer. Also, like I said about the Files app, when I open the app and tap Remote Storages, I get a screen that says Add Storage at the bottom. I hit it and it asks me to connect to a wifi network, which again I don't at home. I know there isn't a one-click method, yet, but is there a way to make this work without the Files app step? I should mention that the screen that follows after hitting the Add Storage button, my options are to activate wifi, tap the plus button at the bottom right corner to add a network, and setup security. I don't have any fields to enter the information displayed in the tutorial at this link:
Posted 13 June 2013 - 07:38 PM
Man I don't know. I'm a Razr guy and I don't even have that phone anymore. Haha..
You can try posting in the Bionic root thread. Maybe someone can help...
Posted 14 June 2013 - 03:25 AM
Unfortunately, due to how the root exploit works, you have to have the WIFI and shared connection. If you happen to have another phone that you can use as a hot spot, you can join your PC and Bionic to that network and the exploit will work (I've tried this). You don't need to access the internet to download anything, you just have to be able to see both devices on the same network for the Remote Storage. The only other thing I could think of is maybe hit up a library or mall and take advantage of a free WIFI.
Posted 14 June 2013 - 03:38 AM
Careful on the public WiFi suggestion. Most of those block the ability to run scripts cross connection.
Posted 14 June 2013 - 06:53 AM
yea, but maybe he could get lucky and find one that will let him slip through the cracks! I know that there is no other way to get the root exploit to work.
Posted 14 June 2013 - 09:18 AM
Using a friends phone for hotspot is the trick. Most people don't have to look to far to find that option.
Posted 14 June 2013 - 09:54 AM
Providing his laptop has a wireless adapter..
Google pixel 32 gig....
Posted 14 June 2013 - 12:08 PM
This is true.
Posted 14 June 2013 - 08:53 PM
__________________sent from my bionic with dub_________________
Also tagged with one or more of these keywords: safestrap, Bionic factory reset
