[Cdma Razr][Gingerbread] |Rom| Black Widow Ics ([Gingerbread 2.3.6]) 6/19/2012
DARK AOKP DROID RAZR/MAXX ICS 4.0.4 Spyder Custom ROM
1285 replies to this topic
#1 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 27 March 2012 - 11:26 PM
POPULAR
Android is all about choices. And here's another choice for AOSP ROM!
Thanks & Credit
Aokp for the source
STS-Dev-Team for the port
Dhacker for letting me hit his Gtalk with all my questions
24v for the help when stuck theming
XDA-Developers for all their goodies to learn android
Android Does for Apex Launcher
Cyanogen Mod for DSP Manager
DroidRZR for the amazing community!!
  • Source: (4.0.4) AOKP Build 39
  • Integrated Gapps (20120429)
  • FULL INIT.D Support
  • Max FPS (240)
  • APEX Launcher v1.2.2
  • SMS Popup
  • ICS Browser+
  • Camera ICS+
  • DSP Manager
  • ES file Explorer
  • AdFree Android
  • Flash Player 11
  • Phasebeam live wallpaper
  • Custom Monochrome theme
  • New design on circleMOD
  • BatteryMod Roboto - accurate battery 1%
  • Big Black Widow ICS keyboard
  • 2 Custom Wallpapers (navigate to your system/media directory)
  • 10 Custom Launcher Icons 'Roboto text' (navigate to your system/media directory)
  • Custom Boot Animation
  • Custom Boot logo (available below)
KNOWN ISSUES/ WHAT DOESN'T WORK:
  • Better Camera function (video recording in-progress)
  • HW Acceleration (in-progress)
  • Bluetooth on but not connected = loss of all audio (in-progress)
  • Answer screen in portrait mode (slider image broken, use BIG! caller ID until I get a fix)
  • Chances are if you have a question, its probably already been asked! so please read the thread first~
Requirements:
  • Android Version 2.3.6 (6.12.17x - 6.12.181)
  • Safestrap 1.09 or Bootstrap v2 (safestrap 1.07 will not work)
  • Download and move zip/s to sdcard-ext
  • Reboot into Recovery
  • Create a Backup! (dont say i didnt warn you)
  • YOU MUST Wipe Data/Factory Reset
  • Wipe Cache partition
  • (in Advanced) Wipe Dalvik cache
  • (in Mounts and Storages) Format System
  • Install zip from sdcard
  • Flash ROM (do not flash Gapps or DarkGapps)
  • Reboot System now
Wait for Data to connect, then begin Device Setup for the best results!
LTE Connection on boot is in-progress, you might need to toggle from "GSM-only" to "GSM/CDMA auto (PRL)" in Phone Info ( shown on
) *use this method anytime needed!* If you cant get data through this method, [reboot into Recovery and Wipe Cache partition and Dalvik cache, then reboot] Phone Info method isnt just about toggling, its all about timing!*
]] - 2012-06-19
MD5: 51D2BF83542568CE3471E6A7EF15E971 *BW_ICS-B39-FULL.zip
  • DarkGapps is optional! If you want a fully blacked out experience to match the ROM for PLAY and Talk, flash DarkGapps After you complete Device Setup!
]] :: 2012-07-05 :: *Do Not Flash Old Zip! It contains an Outdated Google Play and will cause FC on boot*
md5: F4D572EE6E321969A34C2C5D8D5CE931 *DarkGapps.zip
  • [(- reboot into recovery, wipe cache and dalvik, flash DarkGapps; Enjoy the darkness -)]
A few Suggestions:
  • Open your app drawer and locate and select CPU sleeper, Enable auto-start on reboot and click on 'Start service' 2x to activate. (this shuts off 1 core while the phone's screen is off to save battery! both cores resume when the screen is turned back on)
  • Open Apex Settings, theme settings, and apply BWicons (icons/wallpapers)
  • Go into System Settings, Developer Options [ change Window & Transition animation scale to: OFF ]
  • Open AdFreeAndroid, choose Boot Normally, and then choose Skip, check-mark the options "Check server for updates daily", and "Automatically Apply Updates" (ADS SUCK, so why allow them on our phone?)
  • Open Browser, press menu, open Settings, Labs, and Enable Quick controls (for a better browsing experience)
  • Open your system/media directory for custom 'Roboto text' launcher icons (using apex, long press on the app, edit, change icon)
  • Open SMSpopup, Notifications- default notifcations, disable the Show a popup, enable notifications. (change icon if you want, i choose light blue), then vibrate, can set pattern (i choose custom; 0,800), then can set the LED color to whatever custom color you want, i set it as close to ics blue as possible.... then go back. then back again. (now your back to main menu) then open Additional Settings, and turn off Quick Reply, and disable the Button configurations, disable Screen On for Popup. enable privacy mode, and always use privacy mode (i use it, but its by preference), then check the very last box,.. Restrict Popup.
A few Extras:
    ]] only for ICS ROMS! flash through Recovery* **included in BW*
    ]] Install like a normal APK and enable it from the Language and Input settings. Make sure to set it as Default*
    ]] place the APK in your system/app directory with permissions rw-r--r--* **included in BW*
  • Boot Logo to replace M-dual core print on boot:
how to install boot logo!*
Dark Aokp Spyder. A truly blacked out experience for the RAZR, with a touch of ICS. [[BLACKWIDOWICS]]
Posted ImagePosted ImagePosted Image
Posted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted Image
]] - 2012-05-17
md5: 143B221D5A24E1873D7729097D6C4132 *BW_ICS-B36-FULL.zip
]] - 2012-05-07
md5: 8E87ACBE1D63EBC547F097C71F40DC84 *BW_ICS-M5_FULL.zip
Approved by Vanten Kiest Whipped by andlaw repeatedly Repairing this post :ph34r:
If you enjoy the ROM, please feel free to hit the Like button -----------------VVVVVVVVVV
Edited by VantenKiest, 22 October 2012 - 09:23 PM.
Repaired By Vanten under strict Guidlines by Andlaw :D
  • MrFrankRazr, mugsy77, bstrong and 33 others like this
#2 ThaTwizzla
ThaTwizzla
  • 13 posts
  • LocationMinnsota
Posted 27 March 2012 - 11:37 PM
oohhhh Looks nice man!
yup, broke my previous phone.
accidently threw it at a wall tryin to get over to gummy from this rom.
wont make that mistake again (:<
  • andlaw and ThaTwizzla like this
First-Sixth Bravo Co."Hit Em Hard Boys" Semper Fi - We Will Never Forget
#3 Gerland the Oracle
Gerland the Oracle
    Co-Owner and Support Specialist for Team Rage
  • 212 posts
  • Twitter:gerlandh
  • Google+:gerland.hardin@gmail.com
  • LocationJerome, Idaho
Posted 28 March 2012 - 12:19 AM
Andlaw! This Rom is GREAT!!! it is the most user friendly ics rom i have tried! thanks for all your hard work man!
  • andlaw likes this
#4 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 March 2012 - 02:33 AM
Boot Logo to replace M-dual core print on boot: You will need a computer for this task!!
It is a larger image for a Higher Quality look, dark as hell just the way i like it!
this is what you will now see on boot.
  • Extract zip to Desktop
  • Open Command Prompt.
  • Put phone into AP Fastboot (plug into computer usb)
Command prompt lines:
  • cd desktop [enter]
  • cd moto-fastboot [enter] - you should now be in \Desktop\moto-fastboot>
  • moto-fastboot flash logo.bin BWBOOTLOGO.img [enter]
  • moto-fastboot reboot [enter]
custom wallpaper's with a touch of ICS!
DarkAokp bg:
DarkAokpICS bg:
Edited by andlaw, 30 June 2012 - 04:17 PM.
updated Boot Logo!
  • PillClinton and joeblow like this
#5 Gerland the Oracle
Gerland the Oracle
  • 212 posts
  • Twitter:gerlandh
Posted 28 March 2012 - 02:38 AM
How do i download this!!
#6 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 March 2012 - 02:45 AM
Whichever wallpaper you want, you click on it and it will load the image in its own little window, and at the bottom is a Save option. from there you can then drag the file onto your phone and place on sdcard or in the camera folder with the rest of your images, and then you can set it as wallpaper by locating it in the gallery. Also for the users who like it really dark, i left my custom smoke wallpaper in the ROM, it can be located by using a file manager and going into your system/media folder, there is where you will find an image mini_bg.png (i edited the image to where all you have to do is line up the 2 blue bars and the image will be centered with the best look! (users with 1 homescreen)
#7 Gerland the Oracle
Gerland the Oracle
  • 212 posts
  • Twitter:gerlandh
Posted 28 March 2012 - 03:01 AM
That worked great thanks man!!
#8 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 28 March 2012 - 03:23 AM
no problem! :)
#9 Gerland the Oracle
Gerland the Oracle
  • 212 posts
  • Twitter:gerlandh
Posted 28 March 2012 - 04:19 AM
Everybody needs to try this black widow rocks!!!
Sent from my rooted razr running black widow 4.03!
#10 zephyrus14
zephyrus14
  • 216 posts
  • Twitter:@johnmarciniak
  • LocationThe Region
Posted 28 March 2012 - 05:09 AM
The screens look amazing! Once ppl stop texting me I'm flashing it!
#11 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 28 March 2012 - 06:14 AM
I flashed this Rom this morning. I have had it on a couple of hours. I don't see any difference from the other AOKP ICS Rom...Could somebody tell me what the unique features are about this rom. Don't get me wrong. It runs great....Just wondering... :)
#12 RAZRblade
RAZRblade
  • 95 posts
  • LocationPA
Posted 28 March 2012 - 06:58 AM
Very nice work. ^^ if flashed right Google apps have a black background instead of white
#13 en7gm4
en7gm4
  • 137 posts
  • Twitter:https://twitter.com/#!/en7gm4
  • LocationtEXas
Posted 28 March 2012 - 07:30 AM
dang my dyslexia i flashed the dark gapps first then the regular one. doesnt seem to have screwed up anything but will see later on.
#14 zephyrus14
zephyrus14
  • 216 posts
Posted 28 March 2012 - 07:48 AM
Is there a mirror? I keep getting an error in SS when I try to install..
I'm installing from sd-ext and the md5 checks out on the file I'm using
#15 rickyheferle
rickyheferle
  • 60 posts
  • Google+:rickyheferle
Posted 28 March 2012 - 09:52 AM
Same here. Installation Aborted.
#16 Random_Khaos
Random_Khaos
  • 6 posts
Posted 28 March 2012 - 10:43 AM
Finally got it booted up last night way too late... But well worth it! Amazing ROM andlaw, I really appreciate your work.
  • andlaw likes this
#17 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 28 March 2012 - 10:48 AM
So, what happened to the posts from last nigh?
Anyhow, using Bootstrap, I flashed and said in OP. I have not had any problems and I have 4G data! Running very smooth, so now just adding apps and making it how I want it.
Way to go andlaw!
EDIT...I'm using Bootstrap and NOT Safestrap.
#18 eckdawg5
eckdawg5
  • 110 posts
  • Twitter:twitter.com/eckdawg5
Posted 28 March 2012 - 12:48 PM
Nice work andlaw...
#19 tucstwo
  • Google+:tucstwo@gmail.com
Posted 28 March 2012 - 01:59 PM
Has anyone had any success flashing this with Bootstrap? I have seen people saying their installations have failed, are you guys using Boot or Safe strap with failures? Thanks
#20 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 28 March 2012 - 02:05 PM
Has anyone had any success flashing this with Bootstrap? I had it abort three times however, the directions say to use Safestrap (Which I'm not set up for). I have seen people saying their installations have failed, are you guys using Boot or Safe strap with failures? Thanks
I used safestrap and had no problem whatsoever :)
  • jbstutes likes this
Also tagged with one or more of these keywords: DARK AOKP, DROID RAZR/MAXX, ICS 4.0.4, Spyder, Custom ROM
